Underlayment Under Marble - Page 2 - Flooring - Contractor Talk
Thread Tools
Old 04-18-2015, 05:41 PM
Tile Contractor
HS345's Avatar
Trade: Ceramic and Natural Stone Tile Contractor
Rewards Points: 886
Re: Underlayment Under Marble
Originally Posted by angus242 View Post
Actually, you're not.
2x8; 12" OC, 12' span is NOT close.
Last time I'll say it. In this case, marble is not the material to use.
Yep, 12" O.C. only gets to just over L/400. As I said before, he would need to triple sister glue and screw every joist.
Greg
HS345 is offline
Old 04-18-2015, 11:59 PM
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,268
The nightmare bathroom comes to mind.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
The Following User Says Thank You to TNTRenovate For This Useful Post:
angus242 (04-19-2015)
Old 04-19-2015, 10:15 AM
music9704's Avatar
Trade: class b contractor
Rewards Points: 591
Ok I must have been reading the calculator wrong. Anyway Its all good. I tell the HO and see what they want to do. If their heart is set we may change the joist to 2x10. I don't think it will be that hard anyway. I just hate telling a HO I can't .....
music9704 is offline
Old 04-19-2015, 11:27 AM
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
You're better off tripling 2x8.
You also should address the 1/2" subfloor. At 19.2" OC, you will also have big deflection between joists.
I hate that guys are afraid to tell a HO "no". It's your job as a professional to tell the HO (& designers) when they're are going against industry standards. By giving in and risking a failure, nobody comes out on top.
Angus
angus242 is offline
The Following 3 Users Say Thank You to angus242 For This Useful Post:
PrecisionFloors (04-19-2015), TNTRenovate (04-19-2015)
Old 04-19-2015, 02:52 PM
music9704's Avatar
Rewards Points: 591
1/2" subfloor? There is no plywood down right now. I plan on using 3/4 TG or two layers 5/8 TG. I don't have a problem telling a HO no, after I've exhausted all possible ways. They are paying me to make it happen, If I can I will, not say well its to hard, sorry.
Anyway not to beat a dead horse, but if I added a traditional 2x8 to the
true 2"x 8".
I know today's 2x8 are 7.25- my span is also actually under 12'.
Thank you for using the John Bridge Forums Deflect-O-Lator :-)
For joists that are SYP or Douglas Fir, in good condition, 8 inches tall, 3.5 inches wide, 18 inches on center, and 12 feet long between supports, the deflection calculated is 0.179 inches.
This translates to a deflection of L / 806.
Sin
Old 04-19-2015, 07:26 PM
music9704's Avatar
Rewards Points: 591
So is this any good?
http://www.johnbridge.com/vbulletin/deflecto.pl
If it's OK and I'm correct it will cost less the $60 plus extra labor.
HO gets what they want, provided they're willing to pay extra cost.
Old 04-20-2015, 08:46 AM
Tile Contractor
HS345's Avatar
Rewards Points: 886
I trust the John Bridge deflection calculator.
3/4" subfloor alone is not enough. Add a layer of 1/2" plywood to that, plus your underlayment, and you're golden.
Greg
HS345 is offline
The Following User Says Thank You to HS345 For This Useful Post:
music9704 (04-20-2015)
Old 04-20-2015, 10:45 AM
music9704's Avatar
Rewards Points: 591
Thanks.
Back to the original question. What type of ply subfloor- OSB, Advantech, Plywood.
I guessing Advantech or ply. Also type of ply for second layer. BTW. I'm not installing the marble; I'll hire it out. Me and my guys are just doing the framing. My job though.
Old 04-20-2015, 05:30 PM
MIKE ANTONETTI's Avatar
Trade: FLOORING CONTRACTOR
Rewards Points: 3,514
Supposed to be exterior grade glue plywood .
underlayment under marble-imageuploadedbycontractortalk1429569037.491455.jpg
MIKE ANTONETTI is offline
The Following User Says Thank You to MIKE ANTONETTI For This Useful Post:
Old 04-28-2015, 08:21 AM
GO Remodeling's Avatar
Rewards Points: 96
true 2"x 8".
Sin
Those are some weird dimensional lumber sizes you've got.
Since you say you can use 2x10, double the 2's and set 16" o.c. Add the 3/4 plywood glued and screwed then ditra and tile.
GO Remodeling is offline
The Following User Says Thank You to GO Remodeling For This Useful Post:
music9704 (04-29-2015)
Old 04-29-2015, 10:11 PM
music9704's Avatar
Rewards Points: 591
yeah It's an old home, back when a 2x8 was 2"x8".. I was able to use 2x10 sister joist, because the original joist were on jacks. I just shot each corner, pulled a line.... We're good, Level floor & ceiling underneath. Blocks between joist @2'oc, 2 layers ply glued screwed. The Tile guy can lay hardie or concrete, whatever he likes best. I've moved on to the second bath, Almost done with it.
Thanks for all the help.
Old 04-29-2015, 10:43 PM
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Glad to hear you took care of it instead of just doing what the client wanted without regards to the materials.
Angus
angus242 is offline
The Following User Says Thank You to angus242 For This Useful Post:
music9704 (04-30-2015)
Old 05-03-2015, 08:23 AM
Thunderlane123's Avatar
Trade: commercial flooring. Vct. carpet tile , broadloom , hardwood, concrete staining/sealing..
Make sure you choose your plywood correctly.. Because I quickly realized that the marble needed to breath.. The plywood can absorb moisture could expand or contract, stressing The marble.. Good luck.
Thunderlane123 is offline
Thread Tools
Rate This Thread
Underlayment for marble tile SMLWinds Tiling 10 04-25-2013 06:35 PM
Epoxy for tumbled marble CarpenterSFO Flooring 7 01-19-2013 09:26 AM
Best Epoxy Repair for Marble / Terrazzo We Fix Houses Tiling 0 10-25-2012 04:33 PM
Marble Wall / Floor Grout Maintenance ? We Fix Houses Tiling 4 08-14-2012 12:00 PM
Thin brick adhered to marble? accentstonework Masonry 6 05-27-2011 12:05 AM
