Underlayment Under Marble - Flooring - Contractor Talk
Old 04-14-2015, 07:55 AM   #1
music9704's Avatar
Trade: class b contractor
Rewards Points: 591
Hey what's best plywood under marble. I'm reflooring a 12x15 bathroom. Hardi board will be used. Also can wire floor heat be used under marble?
music9704 is offline
Old 04-14-2015, 01:52 PM   #2
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Re: Underlayment Under Marble
Typical framing won't handle a stone tiled floor. If you have room to raise the floor height, that might help. Shoring up the framing from below is optimal.
Angus
angus242 is offline
The Following 2 Users Say Thank You to angus242 For This Useful Post:
music9704 (04-15-2015)
Old 04-14-2015, 02:01 PM   #3
madmax718's Avatar
Trade: General
Rewards Points: 3,276
would depend heavily on the thickness of the marble. How thick are the beams?
madmax718 is offline
The Following User Says Thank You to madmax718 For This Useful Post:
Old 04-14-2015, 02:21 PM   #4
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
The thickness of the tile is not relevant. The structure of the framing is.
Angus
angus242 is offline
music9704 (04-15-2015), rusty baker (04-14-2015)
Old 04-14-2015, 03:57 PM   #5
Business Owner
JD@SBS's Avatar
Trade: Schluter Systems ASD, General Bathroom Remodeling
Rewards Points: 330
What is supporting the floor? 2x8's , I Beams, Open web trusses? Ands at what centers? 16", 19.2", 24"? You need to make sure the installation we be safe first...
JD
JD@SBS is offline
The Following User Says Thank You to [email protected] For This Useful Post:
Old 04-15-2015, 12:07 PM   #6
music9704's Avatar
Rewards Points: 591
Thanks guys. This is a remodel, everything is down to 2x4 walls, and true 2"x8" joist. I believe they're 19"C. I can add more joist NP, however I couldn't add more beams. The span is about 12'. I have some play room on the height.
Old 04-16-2015, 10:22 AM   #7
music9704's Avatar
Rewards Points: 591
Found thishttp://inspectapedia.com/BestPractices/Best_Kitchen_Bath10.htm
Subflooring Requirements for Tile Floors
To meet TCA stiffness requirements, floor framing should be no more than 16 inches on-center with minimum 19/32 -inch plywood subflooring. Upgrading to 23/32- inch plywood will stiffen the subfloor by almost 80% and provide a more solid feeling floor. The subflooring should be level to 1/8 inch in 10 feet. (TCA specs now permit 1/4 inch in 10 feet, but this can be problematic for the large tiles popular today.)
To avoid tile cracks caused by tight-fitting plywood joints, it is best to use square-edged subflooring under tile and leave an 1/8-inch gap between sheets (unless the setting material specifications require tight joints). Lay the plywood with its long dimension across the joists and use solid blocking at all open joints.
Two-Layer Subflooring System for Ceramic Tile Floors
To meet the stiffness requirements for natural stone floors may require two layers of subflooring screwed and glued together, with the upper layer serving as the underlayment.
Two layers of 19/32 inch plywood glued and screwed together on 6-inch centers is several times stiffer than a single layer (and over four times as stiff as a single layer of 23/32-inch plywood). Offset the upper layer so the joints do not line up with the joints in the lower layer or the joists.
Also, screws in the upper layer, which serves as underlayment for the tile, should penetrate the subfloor only and not the joists. Use underlayment- grade plywood or plywood rated C-C Plugged or Plugged Crossbands, with a smooth face and no voids.
Old 04-16-2015, 07:13 PM   #8
Tile Contractor
HS345's Avatar
Trade: Ceramic and Natural Stone Tile Contractor
Rewards Points: 886
Where did this info come from? While a second layer of ply is required for natural stone tile, I certainly wouldn't bond directly to this second layer. A more suitable underlayment should be used in addition to a second layer of plywood.
Greg
HS345 is offline
The Following 2 Users Say Thank You to HS345 For This Useful Post:
music9704 (04-18-2015)
Old 04-16-2015, 07:55 PM   #9
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
AND....
none of that addresses the insufficient framing.
Angus
angus242 is offline
TNTRenovate (04-18-2015)
Old 04-16-2015, 08:07 PM   #10
Tile Contractor
HS345's Avatar
Rewards Points: 886
Originally Posted by angus242 View Post
AND....
This is true. A simple deflection calculator tells the story every time.
Basically, the maximum unsupported span for a 2x10 is 10 feet, for a 2x12 it's 13 feet. Engineered joists, you need to consult the manufacturer.
Greg
HS345 is offline
Old 04-16-2015, 08:31 PM   #11
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
He's talking about 2x8's with 19.2" OC.....
Angus
angus242 is offline
Old 04-16-2015, 09:05 PM   #12
Flooring Installer
rusty baker's Avatar
Trade: flooring
Rewards Points: 110
Craaaack!
Flooring installer since 1973
Armstrong certified
rusty baker is offline
Old 04-17-2015, 05:47 AM   #13
Tile Contractor
HS345's Avatar
Rewards Points: 886
I missed that part. That doesn't even make it for ceramic. Even sistering every joist doesn't quite make it. You would need to double sister every joist to make it suitable for natural stone.
Greg
HS345 is offline
The Following User Says Thank You to HS345 For This Useful Post:
Old 04-18-2015, 12:56 PM   #14
music9704's Avatar
Rewards Points: 591
I was answering a question about the joist. Yes they are old true 2"x8" 19 oc. I stated that I could add joist, (sister, 12" oc) whatever it takes. I can't add a beam under the joist though. Again, a remodel and everything is down to 2x4 walls and joist. As far as the type of stone, I'm not for sure, probably 12" marble. I do plan on using hardie board or concrete board. The page was inspecitda (something like that) I posted the link for the page, it didn't hyperlink tho.
I'm not trying to argue, I just wanted to know the best, safest way. I appreciate all the help.
The Following User Says Thank You to music9704 For This Useful Post:
HS345 (04-18-2015)
Old 04-18-2015, 01:03 PM   #15
Tile Contractor
HS345's Avatar
Rewards Points: 886
It's cool bro, I didn't think you were trying to argue, neither am I. Just having a friendly discussion with fellow tradesmen.
Greg
HS345 is offline
Old 04-18-2015, 01:07 PM   #16
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
The best way to install to not get a failure is....
don't install the marble.
There is no arguing, the marble is absolutely the wrong material for this scenario. You will still have to beef the hell out of the floor just to install ceramic. Marble is not an option. But what the heck do I know....
Angus
angus242 is offline
Old 04-18-2015, 01:42 PM   #17
Tile Contractor
HS345's Avatar
Rewards Points: 886
If you were able to beef up the structure to meet L/720, why would marble not be an option?
Greg
HS345 is offline
Old 04-18-2015, 01:46 PM   #18
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
You could. I'm making the assumption paying for what it would take to make that trampoline of a floor L/720 not an option. Even adding 2x8 to be on 12" OC isn't close enough to install marble.
Angus
angus242 is offline
Old 04-18-2015, 02:51 PM   #19
music9704's Avatar
Rewards Points: 591
I'm getting a better picture here. I took a look at deflection calculator. Now if I just knew what dense selection numbers meant. It looks like I'm pretty close with 12" oc. Southern pine.
Also, sorry, its all good. I've been under the house fixing someone's mess......ugggg
Old 04-18-2015, 04:20 PM   #20
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Actually, you're not.
2x8; 12" OC, 12' span is NOT close.
Last time I'll say it. In this case, marble is not the material to use.
Angus
angus242 is offline
Underlayment for marble tile SMLWinds Tiling 10 04-25-2013 06:35 PM
Epoxy for tumbled marble CarpenterSFO Flooring 7 01-19-2013 09:26 AM
Best Epoxy Repair for Marble / Terrazzo We Fix Houses Tiling 0 10-25-2012 04:33 PM
Marble Wall / Floor Grout Maintenance ? We Fix Houses Tiling 4 08-14-2012 12:00 PM
Thin brick adhered to marble? accentstonework Masonry 6 05-27-2011 12:05 AM
