#21 | |
John the Builder
Rewards Points: 4,280
Re: ****ty Floor...Quote:
Even the notorious Chin Brothers (Koreans - dont ask) "try-fit" as they go. About 1/2 of a room is laid out, butted up to check for fit and match, then pulled into the row being laid. Very fast, and I suspect faster than what you are achieving.
All my Life loving Hippie friends turned into soul-sucking Conservatives - or died. Same difference. "Mornin' ladies, my goodness don't you look happy. Must be cuttin' somebody up pretty good." - Andy Griffiths |
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. ContractorTalk.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task! |
Advertisement |
#22 | |
Trade: General Remodeling
Rewards Points: 130
It seems like any sort of fitting ahead of time to discern a 1/16" difference would be rather hard and time consuming... |
#23 |
Focusing on solutions.
![]() Trade: hardwood floor contractor & so much more
Rewards Points: 384
Re: ****ty Floor... |
The Following User Says Thank You to pinwheel For This Useful Post: |
sparehair (08-21-2018)
#24 | |
John the Builder
In the mid-2000s, Bruce was shipping product that wouldn't pass for fire starter. Now their quality is back up, but now I'm using all hand finished plank. The water born finish has made it damned near competitive with pre-finished, because of turn around time.
#25 |
Rewards Points: 384
Re: ****ty Floor...
Picky & bruce are not usually used in the same sentence.
![]() Only time I even consider laying it, is when the client provides their own wood. |
SmallTownGuy (08-19-2018)
#26 |
Rewards Points: 384
Re: ****ty Floor...
We're sanding a lot of bruce floors that were laid 10-20 years ago. All have sun fading. Sanding aluminum oxide off sucks ass.
The Following 2 Users Say Thank You to pinwheel For This Useful Post: |
asevereid (08-18-2018),
#27 |
Trade: Painting, flooring
Rewards Points: 1,358
Re: ****ty Floor...
16 Gauge nailer? Like the 16 gauge crown stapler for 3/8 engineered?
Try a 15 gauge stapler, heavy hammer, 95 psi and hit that f'er! It'll bend a board 1/4" if you mean it. You'll need wall jacks as well. Dont buy the powernail wall jack for $200. The amazon off brand is 20$ and it works just fine. Sent from my SM-N950U using Tapatalk |
#28 |
Re: ****ty Floor...
There is also some technique to pulling a crowned board tight.
Start where the board is tight and work out from that. You want to pull the bow in incrementally from where its close rather than nailing at the point with the most gapping. Sent from my SM-N950U using Tapatalk |
The Following User Says Thank You to sparehair For This Useful Post: |
asevereid (08-21-2018)
#29 |
Re: ****ty Floor...
Fill your cracks with color putty and wipe with a rage lightly dampened with spirits to remove the residue.
#30 | |
![]() ![]() Sent from my SM-N950U using Tapatalk |
pinwheel (08-21-2018)
#31 | |
Rewards Points: 384
sparehair (08-22-2018)
#32 |
Flooring Installer
Trade: flooring
Rewards Points: 56
Re: ****ty Floor...
One thing about LL. At least all those 18" pieces are not heavy.
Flooring installer since 1973 Armstrong certified |
The Following 2 Users Say Thank You to rusty baker For This Useful Post: |
pinwheel (08-23-2018),
SmallTownGuy (08-23-2018)
#33 | |
John the Builder
I will say the finish itself held up well. So yeah, 300 ft or so of Bruce replaced on that one - on my dime. In the market I serve, it was in high demand.
The Following User Says Thank You to SmallTownGuy For This Useful Post: |
pinwheel (08-29-2018)
#34 |
Rewards Points: 130
Re: ****ty Floor...
Reporting back with surprisingly good news...
LL replaced all the flooring free of charge, including enough to replace the floor we installed. They came out to the house and loaded in the new and took out the old. They confirmed that it was a bad batch regarding the milling. They are also paying $500 towards our labor costs on installing the bad floor. Not at all how my friend or I saw this working out. Still a PITA but honestly for how it's all working out, it's not too bad. |
The Following 8 Users Say Thank You to Xtrememtnbiker For This Useful Post: |
asevereid (08-29-2018),
onmywayup (08-30-2018),
Peter_C (08-29-2018),
pinwheel (08-29-2018),
rrk (08-30-2018),
Sisyphus (08-31-2018),
SmallTownGuy (08-29-2018),
Stryker1-1 (09-02-2018)
#35 | |
Rewards Points: 1,356
![]() Tom |
#36 |
Rewards Points: 384
Re: ****ty Floor...
That's great news, glad it turned out well.
#37 | |
John the Builder
Impressed.
#38 |
Rewards Points: 130
#39 |
Box Builder
Rewards Points: 9,482
Re: ****ty Floor...
Let us know when they actually cut you a check
The Following User Says Thank You to Morning Wood For This Useful Post: |
Xtrememtnbiker (08-29-2018)
#40 |
Trade: general contractor
Rewards Points: 932
Re: ****ty Floor...
Just run it, the cracks will be filled with dirt and dog/cat hair in no time
![]() Good to see LL stepped up. Does $500 cover ripping up all the newly laid flooring as well? Advertisement |
Display Modes | Rate This Thread |
Thread | Thread Starter | Forum | Replies | Last Post |
Need recommendations to fix newly but poorly finished concrete floor | MikeGC | Concrete & Paving | 20 | 03-08-2014 07:11 PM |
exterior prehung door replace - uneven floor | artinall | Windows, Siding and Doors | 19 | 12-24-2012 11:38 AM |
FS: Panther Floor Stripper Scraper 6280 HD | Allfloorremoval | Contractor Swap | 1 | 07-16-2012 08:45 PM |
Second floor water heater drip pan and T&P drains | bob_cntrctr | Plumbing | 7 | 08-01-2009 09:58 PM |
Cross-laminated PE vapor barrier under floating floor after leveling with sleepers | sjkm | Flooring | 11 | 06-14-2009 10:03 AM |
Go to Page... |
