Tiling Over Exposed Aggregate Concrete Large Control Joints - Flooring - Contractor Talk
Thread Tools
Old 05-19-2019, 10:34 PM
Nhubbell2's Avatar
Trade: Tile
Rewards Points: 2
We have an approx 30x12 exposed aggregate patio. It consist of 6x6 individual concrete pads with 2 inch wood filled joints separating each pad. There is only 1 piece of rebar connecting each 6x6 pad to the next. We would like to tile over this area but are worried about the movement of each individual pad that would possiably crack the 12x24 tiles that would overlay the joints. Is it possiable to tile this area safely? Our orginal plan was to remove wood and fill all the 2 inch gaps with cement, use self level to correct any low spots and tile over the area. The patio is about 40 years old.
Nhubbell2 is offline
Old 05-19-2019, 10:41 PM
Bull Trout's Avatar
Rewards Points: 522
Re: Tiling Over Exposed Aggregate Concrete Large Control Joints
Maybe hire a professional and do what they suggest
Bull Trout is online now
Old 05-19-2019, 10:43 PM
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,050
That's a tough one. You would need to treat each pad like it's own system using expansion joints to bridge the gaps. I probably wouldn't touch it personally without ripping it our and replacing with a solid slab.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
The Following User Says Thank You to TNTRenovate For This Useful Post:
Calidecks (05-19-2019)
Old 05-19-2019, 11:19 PM
GC/carpenter
Calidecks's Avatar
Rewards Points: 18,244
My guys could have ripped out and ready to pour next day.
Mike.
_______________
Calidecks is online now
griz (05-19-2019), Seven-Delta-FortyOne (05-20-2019), TNTRenovate (05-20-2019)
Old 05-20-2019, 09:49 AM
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 1,319
If you tile over the joints it will crack. How about tiling each "pad" separately, with an expansion gap around each perimeter?
For the gaps, maybe use the same material used around pool coping--that stuff is pretty durable,flexible, exposed to chemicals, water, sun, etc.
I'm sure you could get a close color match/contrast. Ask a pool building company.
rescraft is offline
Old 05-20-2019, 10:49 AM
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 2,184
Mike.
_______________
Right there.
Much better to do it right, from the beginning.
Get Off My Lawn.
"There are no big projects. There are only small machines". - R. G. LeTourneau
Old 06-13-2019, 08:51 AM
jmalehorn's Avatar
Trade: Flooring
Rewards Points: 16
If tearing out and re pouring is not an option for you then the next best thing would be to treat each "pad" as its own and leave expansion gaps as suggested above. I would start over and do it right from the beginning. So, shortened version, I agree with the advice given.
jmalehorn is offline
The Following User Says Thank You to jmalehorn For This Useful Post:
TNTRenovate (06-13-2019)
Thread Tools
Rate This Thread
Sealer removal advice over exposed aggregate and stamped? oktex56 Concrete & Paving 10 01-14-2013 03:57 PM
Exposed Aggregate CJKarl Concrete & Paving 2 04-13-2011 08:40 PM
Misaligned control joints Big Andy Flooring 0 11-17-2010 11:56 PM
exposed aggregate epoxy bobbrown Concrete & Paving 0 03-13-2009 12:57 PM
