Tackstrip On Concrete - Flooring - Contractor Talk
Old 04-12-2010, 10:15 PM   #1
VeloFlooring7's Avatar
Trade: Flooring
My company is wasting valuable time and resources spending hours struggling with installing tackstrip on concrete subfloors. Has anyone found a technique or tool that has seemed to help at all? Thanks!
VeloFlooring7 is offline
Old 04-13-2010, 06:29 AM   #2
Anti-wingnut's Avatar
Rewards Points: 3,422
Re: Tackstrip On Concrete
Originally Posted by peterjames View Post
This design results in an easy installation that can be completed by just about anyone with a hammer.
Anti-wingnut is offline
Old 04-13-2010, 06:42 AM   #3
Flooring Installer
rusty baker's Avatar
Trade: flooring
Rewards Points: 106
This site is for pros. If you don't know the different ways to install tack strip on concrete, you are not a pro.
Flooring installer since 1973
Armstrong certified
rusty baker is offline
Old 04-13-2010, 07:45 AM   #4
Pompass Ass
bwalley's Avatar
Rewards Points: 1,000
Installing tackstrip is not difficult, you may just need a bigger hammer.
bwalley is offline
Old 04-13-2010, 07:52 AM   #5
Fixed it for you
Another reason why tack strip application licenses should be mandatory. I personally am certified in both tack strip application and direct glue-down carpet administration in four counties.
Old 04-13-2010, 09:54 AM   #6
Pompass Ass
bwalley's Avatar
Originally Posted by Anti-wingnut View Post
Fixed it for you
I am a State Certified Contractor, so my licenses are valid in 67 counties, not just 4.
bwalley is offline
Old 04-13-2010, 12:37 PM   #7
Grand Rapids Remodeling
Paulie's Avatar
Rewards Points: 2,052
OK, I just went out and got a 16lb sledge, now what do I do?
Paulie is offline
Old 04-13-2010, 12:43 PM   #8
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Hammer time?
Angus
angus242 is offline
Old 04-13-2010, 06:42 PM   #9
Money Changer
bert0168's Avatar
Trade: Residential Remodeling
For the best grip, the side with all the little sharp spikes goes into the concrete, right?
bert0168 is offline
Old 04-13-2010, 07:15 PM   #10
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 144
SLSTech is offline
Old 04-13-2010, 09:54 PM   #11
nuwest's Avatar
Trade: Flooring+Interior Finishing
Anyone else use a concrete T-nailer. Bex, Basso or Spotnails
nuwest is offline
Old 04-15-2010, 08:20 PM   #12
Knowledge Factory
Floordude's Avatar
I use my 32oz. Estwing, that I've had for 25-30 years.
Seems to work well.
Sometimes you have to hold your mouth just right to make it work.
http://www.AustinFloorguy.com
Floordude is offline
Old 04-25-2010, 06:23 PM   #13
custom installations
Taurus Flooring's Avatar
Trade: Flooring
Rewards Points: 127
The most effective way I've found to install concrete tack strip, is by using PL Premium as a back up. If the nails are busting up the concrete or just not getting thru properly, I use some PL and it grabs it real well. When there are small pieces of TS to be installed, again I use PL. It takes a little bit of time to grab, but once it does, good luck getting it off. I also install all of my door metals with it. It's usually the 1st thing I do, when I start the job...faster, easier and does a nicer job (no dings)...
Taurus Flooring is offline
Old 02-23-2019, 06:29 PM   #14
Nouveau Eccentric
Diamond D.'s Avatar
Trade: masonry/hardscaping
Rewards Points: 3,006
Anything new on this front?
I'm extending a fireplace hearth, on concrete slab, to accommodate a pellet stove.
I did not include carpet cutting or re-laying with this job.
It's not in my job description and I don't have the tools to do the job, however I told the customer I would help him out.
I have called several carpet guys and no one will return a call, (contractors ) and even a carpet store, the woman said she would call me back with info. .
Anyway, I wanted to put down the tack strip before I laid the border with overhang as to not take the chance on chipping the bricks.
The concrete just spalls, even with a big hammer.
I figured I'd bring in the Hilti on Monday, but was a little hesitant thinking that would just obliterate the tack strip.
So meanwhile I'd thought I'd check in here.
I was wondering, has any one has used the peel and stick tack strips and how do they hold up?
After reading this thread I may go with nuwest and Taurus, T-nailer and/or PL.
Any other tricks or tips welcomed.
Thanks,
D.
" ROCK YOUR WORLD "
fb
Diamond D. is offline
Old 02-23-2019, 06:51 PM   #15
Texas Wax's Avatar
Rewards Points: 1,934
Thanks,
D.
err Tapcons
...as the page loads, so go the days of our lives, at CT
Texas Wax is online now
Old 02-23-2019, 07:55 PM   #16
TheConstruct's Avatar
Rewards Points: 1,372
PL for sure.
TheConstruct is online now
Old 02-23-2019, 08:33 PM   #17
FloorsByAlex's Avatar
Trade: Flooring
Rewards Points: 132
Contact cement. Easy peezy.
Sent from my LG-LS993 using Tapatalk
FloorsByAlex is offline
The Following User Says Thank You to FloorsByAlex For This Useful Post:
TheConstruct (02-23-2019)
Concrete Company delivered junk concrete. How best to pursue? marcomjl Concrete & Paving 47 06-03-2014 10:17 PM
Concrete with Fly Ash vs. Concrete without? cdkyle Concrete & Paving 19 07-28-2010 09:57 PM
Tire line in concrete after finishing. aydin_eng Flooring 34 03-09-2010 10:03 PM
4x4 posts in concrete vs. saddles Strongarm Decks & Fencing 20 08-31-2009 09:41 PM
