Stair Landing Nosing - Flooring - Contractor Talk
Old 02-24-2013, 12:53 AM   #1
Tom M's Avatar
Rewards Points: 9,562
Question for you floor guys.
I have a 3 sided opening and need to install new bull nosing around the perimeter for my hardwood guy. Top step, side landing and then return. Its U shaped.
Should the pieces be glued and biscuted together? And should I use a grooved or tongued profile for flooring to marry into? I have only found square edged pieces.
Tom M is offline
Old 02-24-2013, 12:58 AM   #2
tenon0774's Avatar
Trade: Remodeling Carpenter
Rewards Points: 2,270
Re: Stair Landing Nosing
Yes.
and about the square edged pieces?
slot cutter router bit.
-Scott
tenon0774 is offline
The Following 2 Users Say Thank You to tenon0774 For This Useful Post:
pinwheel (02-24-2013), Tom M (02-24-2013)
Old 02-24-2013, 09:35 AM   #3
ccoffer's Avatar
Rewards Points: 1,140
If the floor is consistently level around the opening, you can just nail it down and be done with it, but if its off even a hair, it's best to spline it. I suppose that biscuit doohickey would suffice.
ccoffer is offline
Old 02-24-2013, 09:50 AM   #4
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 146
Originally Posted by tenon0774 View Post
Yes.
I build all my own stair nosings & use a 1/4" slot cutter with a bearing on top. All nosings get glued down as well. Floor should all be locked together so when something moves, it all moves together.
pinwheel is online now
The Following User Says Thank You to pinwheel For This Useful Post:
Tom M (02-25-2013)
Old 02-24-2013, 11:55 AM   #5
Tom M's Avatar
Well I am going to picture frame the landing so I wanted join those corners with either pocket screws or biscuits. I decided biscuits. I also plan on making a tedious effort on getting them to lay fairly flat. I will back bevel the bottom edge reguardless so the floor butts up nice. My guy is going to use the landing as a starting point for this hallway so one side will get a spline and go in the other direction. I wasnt sure if the installer typically routes the slot or the groove on site.
I would think he who installs it would make the call.
Tom M is offline
Old 02-25-2013, 08:47 AM   #6
judyfholmes's Avatar
Trade: Housing
Biscuit doohickey always worked in my case and problem, go with it, it has very less chance of failure, though you may have to check out the ground leveling problem first.
Moving with Earth. Laminate Flooring
judyfholmes is offline
Old 02-25-2013, 04:45 PM   #7
astor's Avatar
Trade: FI
Rewards Points: 704
Let the floor guy take care of those. Don't forget to pay though
astor is offline
The Following User Says Thank You to astor For This Useful Post:
Tom M (02-25-2013)
Old 02-26-2013, 09:02 AM   #8
ccoffer's Avatar
The vast majority don't. Very few wood installers have a router on their truck.
ccoffer is offline
1/2 story steel fire escape stair App-ironworks Specialty Trades Picture Post 6 03-09-2013 09:34 AM
stair nosing rondon Flooring 8 03-05-2012 10:19 AM
Spiral stair set up questions festerized Welding & Steel Trades 18 01-19-2012 10:51 PM
Options for Stair nosing in kitchen? sbcontracting Tiling 5 10-02-2011 11:22 AM
How to Cut hardwood for round stair nosing!! winnabowboy Flooring 3 09-17-2007 07:21 PM
