Separating Glued Engineered Flooring - Flooring - Contractor Talk
Old 09-28-2018, 10:46 AM   #1
rblakes1's Avatar
Rewards Points: 2,492
I have a small repair I need to do and the original installer put little dabs of glue in the joints. Is there any trick to getting the boards apart without destroying them? My main concern is for where I'll need to meet the existing floor after the patch is done
I have no idea what type of glue that used, almost looks like regular wood glue
rblakes1 is online now
Old 09-28-2018, 12:39 PM   #2
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 1,998
Re: Separating Glued Engineered Flooring
Looks like shlt, the whole floor should be ripped out. Who in their right mind would think that was a good idea?
Big Johnson is online now
The Following 3 Users Say Thank You to Big Johnson For This Useful Post:
A&E Exteriors (09-28-2018), avenge (09-28-2018), onmywayup (09-29-2018)
Old 09-28-2018, 12:57 PM   #3
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 1,003
If it's wood glue, heat will soften it up enough to get it to separate. Hair dryer on high, or heat gun on low would do the trick.
rescraft is offline
The Following 2 Users Say Thank You to rescraft For This Useful Post:
rblakes1 (09-28-2018), TheConstruct (09-29-2018)
Old 09-28-2018, 11:13 PM   #4
rblakes1's Avatar
That's the bottom of the boards.
First time I've seen glue used in the t&g, but according to Google it's somewhat common
The Following User Says Thank You to rblakes1 For This Useful Post:
Big Johnson (09-30-2018)
Old 09-28-2018, 11:20 PM   #5
rblakes1's Avatar
More flooring will be coming up, after I removed what I needed to for my repair I found this. Looks like the added vapor barrier under the floating floor was not a good idea.
After I found that, I told them to call a remediation company since I am not equipped to handle mold.
asevereid (09-29-2018)
Old 09-29-2018, 06:26 AM   #6
rrk's Avatar
Rewards Points: 686
back in the early 90s late 80s that was the way it was done all floating over 1/8" taped foam underlayment. Every f'n edge had to be glued, took forever
rrk is online now
Old 09-30-2018, 09:43 AM   #7
rblakes1's Avatar
Yeah, that doesn't sound fun, especially with the close to 2000 sf of this stuff installed in this house.
Old 09-30-2018, 09:52 AM   #8
That makes more sense. Perfectly acceptable to use glue.
There’s laminate flooring glue at $10 bottle or titebond II at $3/bottle which my flooring supplier told me is the same thing.
rblakes1 (10-01-2018)
Old 09-30-2018, 11:17 AM   #9
tang's Avatar
Trade: Remodel contractor
Rewards Points: 379
I repaired a floating bamboo floor that was separating at the but joints. I used a suction cup and a rubber mallet. Got the suction cup handle from Amazon prime for 14 bucks. Tapped them apart, tite bond, tap'em together. worked great.
tang is offline
The Following User Says Thank You to tang For This Useful Post:
Old 10-14-2018, 08:18 PM   #10
rblakes1's Avatar
Just to give an update, I'm not going to have to deal with that at all. Remediation company came in and they ended up having to remove all the flooring, close to 2000 sq ft. Of both the floating and original glue down
Vinyl Flooring Adhesive Question josephdan General Discussion 1 03-05-2013 05:36 PM
seem treatment for 5/8" plywood and vinyl plank flooring GO Remodeling Flooring 5 01-11-2013 10:51 PM
Heavy machinery & Engineered flooring....? PrestigeR&D Flooring 14 03-06-2012 09:34 PM
Engineered flooring PA woodbutcher Flooring 9 10-23-2010 12:19 AM
laminate flooring placement nwksremodeler Flooring 7 06-19-2009 09:24 AM
