Seem Treatment For 5/8" Plywood And Vinyl Plank Flooring - Flooring - Contractor Talk
Old 01-09-2013, 06:11 PM   #1
GO Remodeling's Avatar
Rewards Points: 96
To meet an existing floor, I am going to use 5/8" plywood as the underlayment for (3/16" x7.5"x48") Engage Plank floating vinyl flooring. I intend to gap the sheets of ply with a nickel spacing between sheets. Should I fill the gap with something or just leave it? Options include caulk, sealing over the open gap with self stick membrane or cement product (Ardex). What would you use?
GO Remodeling is offline
Old 01-09-2013, 07:28 PM   #2
ccoffer's Avatar
Rewards Points: 1,140
Re: Seem Treatment For 5/8" Plywood And Vinyl Plank Flooring
A dime would be more appropriate, but there's no need to fill it with anything. Just make sure it's sanded flat.
ccoffer is offline
Old 01-09-2013, 09:10 PM   #3
Rewards Points: 96
Thanks.
Old 01-09-2013, 10:04 PM   #4
ArtisanRemod's Avatar
Rewards Points: 582
I dont do much vinyl. What is the reason for the gap?
ArtisanRemod is offline
Old 01-10-2013, 08:56 AM   #5
Rewards Points: 96
expansion gap. Usually I use 1/4" ply so I wasn't sure if I needed a bigger gap.
Old 01-11-2013, 10:51 PM   #6
Paul
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Rewards Points: 1,004
Yep - most times a telegraphing underlayment joint is from the patch
Precision Floors
(772) 237-9900
PrecisionFloors is offline
