Screw It? - Flooring - Contractor Talk
Screw It?
Old 04-25-2010, 05:53 PM   #1
All Floors's Avatar
Trade: All Floors
Screw It?
New to the forum.. I always screw my hardi board with tyvek or senco strip hardi-board screws. I have never used a nail for hardi board. I recently quoted a new construction job and the contractor used the framing crew to install the hardiboard to save some $. They used 1 1/2'' galvanized roofing nails on the 1/4'' hardi. Before I start the job I would like some input, are the nails just as good? Thanks for the input
All Floors is offline
Old 04-25-2010, 06:01 PM   #2
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 1,011
Re: Screw It?
What does the manufacturer say to use. Anything else will void the warranty.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Old 04-25-2010, 06:07 PM   #3
MattMatt
mwhafner's Avatar
Trade: Remodeling/Renovation
Rewards Points: 75
Re: Screw It?
I have always used screws as well, but the instructions say that a minimum 1 1/4" corrosion-resistant nail can also be used.
mwhafner is offline
Old 04-25-2010, 06:13 PM   #4
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 156
Re: Screw It?
Did the framers set it in thinset also? No, then its a fail
Nails or screws are fine and I generally just nail it off - if the nails work free, then you have bigger issues then screws would fix
SLSTech is offline
Old 04-25-2010, 06:54 PM   #5
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Re: Screw It?
Galvanized roofing nails are allowed and used by many.
Very important to do what SLS said....embed in thinset
Angus
angus242 is offline
Old 04-25-2010, 07:12 PM   #6
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,744
Re: Screw It?
I use peanut butter and 20d spikes.
Nails and thinset are also a way.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 04-25-2010, 07:29 PM   #7
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Re: Screw It?
What?
Oh, well as long as it's not crunchy....
Angus
angus242 is offline
Old 04-25-2010, 09:46 PM   #8
BuildersII's Avatar
Trade: General
Rewards Points: 250
Re: Screw It?
If the hardibacker is set in thinset, then I wouldn't think you'd need much at all in the way of fasteners. That said, I wouldn't trust nails alone. Screws are far superior for this kind of application, and they will not allow the layers to separate over time under normal conditions.
BuildersII is offline
Old 04-26-2010, 05:07 PM   #9
Paul
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Rewards Points: 1,004
Re: Screw It?
The thinset is only there to fill voids, it is not there as an adhesive.
Precision Floors
(772) 237-9900
PrecisionFloors is offline
The Following 2 Users Say Thank You to PrecisionFloors For This Useful Post:
angus242 (04-26-2010), FlooringGuy (04-26-2010)
Old 04-26-2010, 06:12 PM   #10
Bathroom Remodeler
srwcontracting's Avatar
Trade: Bathroom Remodeling
Rewards Points: 560
Re: Screw It?
I've used liquid nail and roofing nails like an idiot for years....Can't say I really had any problems, but those were for investors that were selling homes, so I never followed up with the buyers. I'd be a little worried knowing what I do now!
srwcontracting is offline
Old 04-26-2010, 07:23 PM   #11
AustinDB's Avatar
Rewards Points: 1,426
Re: Screw It?
I've used the roofing nailer for jobs large enough to warrant pulling out the compressor-it sure saves time and back soreness. Only drawback is getting the heads set 'just right'. I would personally think the screws are more secure-and they are not regular screws-the special coated ones. If I recall, its a acidity problem, that and sheetrock screws don't have the tensil strength the special hardi screws do.
AustinDB is offline
Old 04-26-2010, 09:44 PM   #12
FlooringGuy's Avatar
Trade: flooring
Re: Screw It?
I prefer to use a roofing nailer for the sake of speed. Screws do hold better in the subfloor but I question whether they are better than nails. When I have driven screws into backerboard I noticde a big difference between the grab a nail provides and a screw. When you drive a screw near the edge of the board it seems the board wants to pull up into the thread and once the screw approaches level with the board it seems the head just wants to break through without really holding. Whenever I hammer a nail in, whether by hand or with a gun, it seems to go in and hold better because of the head. I was very skeptical at first because I was always told to sell screws with hardibacker and such when I worked for Lowes. I now think it's a gimmick to get contractors to buy an $8 box of screws for every four sheets of board they put down. I'll stick with roofing nails. I haven't been doing it long but I have never had issues using them. Plus who wants to sit and screw a 500 sq ft job?
FlooringGuy is offline
Old 04-26-2010, 09:45 PM   #13
Trade: flooring
Re: Screw It?
...or you could forget the whole thing and use ditra...
Old 04-26-2010, 09:53 PM   #14
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Re: Screw It?
oh no he didn't
Angus
angus242 is offline
Old 04-26-2010, 09:54 PM   #15
I like Green things
Re: Screw It?
Oh Snap!!!
Warner Mill Works
Facebook
YouTube
Old 04-26-2010, 09:58 PM   #16
Trade: flooring
Re: Screw It?
Aww **** i went there bought the shirt and sent y'all a postcard!!!!1!!!
Old 05-01-2010, 03:08 AM   #17
chris374's Avatar
Trade: Ceramic Floor Tiling
Re: Screw It?
I would stay with the screws.
Chris
Backsplash Tile
chris374 is offline
Old 05-03-2010, 03:10 PM   #18
KG007's Avatar
Trade: Flooring & cabinetry
Rewards Points: 268
Re: Screw It?
My tile guy prefers nail for the same reason Flooring Guy stated. He guarantees his installations for life. Never had a callback on one of his jobs from a related issue in 8 years, so I guess I'll let him have his way. I don't see anything wrong with screws, though.
KG007 is offline
Tags
hardiboard , nails , peanut butter , screws , tile
Screw holes showing hoferbuilder Drywall 76 05-08-2011 10:21 AM
stocking service trucks MO-AMPS Electrical 23 11-25-2009 10:39 PM
drywall screw length vs vapor barrier blacksheep Drywall 7 02-08-2009 09:01 PM
Screw length for fastening 2 x Ipe? Chris G Decks & Fencing 9 09-18-2008 06:50 PM
Auto feed screw guns vs. pneumatic screw nailers sk8park Tools & Equipment 9 04-07-2008 10:41 PM
