Ring-Shank Nails Vs Staples For Underlayment - Page 2 - Flooring - Contractor Talk
Old 12-07-2018, 02:31 PM   #21
madmax718's Avatar
Trade: General
Rewards Points: 3,276
Re: Ring-Shank Nails Vs Staples For Underlayment
curious as to when you'd need a quarter inch underlay....
madmax718 is offline
Old 12-07-2018, 06:21 PM   #22
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 2,048
One has to be careful with Ring shanks, yrs ago in my own house used r/s with commercial Armstrong flooring , did not skim coat the floor and after a while could see every nail spot.
Randy Bush is offline
The Following User Says Thank You to Randy Bush For This Useful Post:
Seven-Delta-FortyOne (12-07-2018)
Old 12-07-2018, 07:13 PM   #23
madmax718's Avatar
Trade: General
And you think it's because of the ring shanks? Ya, not sure about that...
Old 12-07-2018, 07:13 PM   #24
madmax718's Avatar
Trade: General
I should clarify, if it's visibile, it's probably because it was nailed flush and then the wood subfloor shrank or compressed.
Old 12-07-2018, 07:31 PM   #25
avenge's Avatar
Rewards Points: 130
See post #10 pretty much the norm under vinyl/linoleum and any time you needed a smooth substrate.
I've never seen anything but crown staples, I hate it when luan comes up in pieces and all the staples are still in the subfloor.
avenge is online now
The Following User Says Thank You to avenge For This Useful Post:
Old 12-07-2018, 09:07 PM   #26
Tom M's Avatar
Rewards Points: 8,158
Dash patch was always recommended to cover joints and fasteners to prevent visual flashing
Tom M is offline
Old 12-12-2018, 11:19 AM   #27
Flooring Installer
rusty baker's Avatar
Trade: flooring
Rewards Points: 108
Originally Posted by cedarboarder View Post
I've never seen anything but staples or glues on underlay
Sent from my SAMSUNG-SM-G891A using Tapatalk
Underlay should never be glued. It can cause humps. Same for screws, it can cause puckers. I have used ringshanks and staples. Both work fine. Both will warranty.
Flooring installer since 1973
Armstrong certified
rusty baker is offline
The Following 2 Users Say Thank You to rusty baker For This Useful Post:
Metro M & L (12-14-2018), Seven-Delta-FortyOne (12-12-2018)
Old 12-12-2018, 11:20 AM   #28
Flooring Installer
Trade: flooring
Rewards Points: 108
Always used under sheet vinyl or there is no warranty.
Armstrong certified
Least Protruding Button Cap Staples / Nails that won't "show up" under shingles MrCreosote Tools & Equipment 0 09-10-2017 07:59 PM
Professional Dumby here, siding / nails RhettMan General Discussion 34 10-30-2013 09:41 PM
Sheeting nails brendanstl Framing 16 06-19-2011 10:59 AM
hand nails or 18 gauge staples, in cedar shingles woodworkbykirk Carpentry 19 09-19-2009 10:26 AM
Screw or Ring Shank ? We Fix Houses Decks & Fencing 8 05-20-2009 11:46 PM
