Ring-Shank Nails Vs Staples For Underlayment - Flooring - Contractor Talk
Old 12-04-2018, 10:43 PM   #1
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 766
Is there some compelling reason, besides cost, to use narrow crown staples for 1/4" underlayment?
I'd much prefer to use ring-shank nails. I've pulled enough underlayment in my life to know how easily it comes up when it's stapled down.
Anything I'm missing?
Old 12-04-2018, 10:46 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 368
Re: Ring-Shank Nails Vs Staples For Underlayment
haven't seen staples used for quite some time.
friend had a floor installer tell him there would be no warranty because the underlayment was stapled down.
griz is online now
The Following 2 Users Say Thank You to griz For This Useful Post:
hdavis (12-05-2018), Seven-Delta-FortyOne (12-04-2018)
Old 12-05-2018, 12:10 AM   #3
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 412
Curious what material of underlayment are you talking here? Plus what is going over the top of it?
Peter_C is offline
Old 12-05-2018, 01:27 AM   #4
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 240
The compelling reason is speed and ease of application.
While I won't deny the greater tenacity of ring-shanks, IMO they're simply not necessary most of the time. Properly sized staples used with appropriate density will have you cursing just as much when doing demo.
Not that I necessarily agree that ease of demo directly reflects the quality of the initial installation.
Tinstaafl is offline
The Following 2 Users Say Thank You to Tinstaafl For This Useful Post:
Big Johnson (12-05-2018), sparehair (12-05-2018)
Old 12-05-2018, 01:34 AM   #5
Fire up the BBQ
griz's Avatar
Rewards Points: 368
in my world been an architect spec to use ringers....
as i said earlier, been a long time since i've seen staples even in residential...
could be a west coast thing....i don't know
griz is online now
Old 12-05-2018, 01:35 AM   #6
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 528
All the stapled down underlayment that I’ve ripped up was a bitch. Maybe the stuff you did was light on the staples.
Big Johnson is online now
The Following 3 Users Say Thank You to Big Johnson For This Useful Post:
pinwheel (12-05-2018), Robie (12-07-2018), sparehair (12-05-2018)
Old 12-05-2018, 01:37 AM   #7
Fire up the BBQ
griz's Avatar
Rewards Points: 368
Originally Posted by Big Johnson View Post
All the stapled down underlayment that Iíve ripped up was a bitch. Maybe the stuff you did was light on the staples.
in my experience ripping out ANY underlayment is a bitch....
griz is online now
Big Johnson (12-05-2018), hdavis (12-05-2018)
Old 12-05-2018, 02:54 AM   #8
VinylHanger's Avatar
Rewards Points: 11,470
I always use staples for loan, but screws for anything else.
VinylHanger is offline
Old 12-05-2018, 06:48 AM   #9
Tom M's Avatar
Rewards Points: 7,104
Ive only used ring shank nails
Tom M is online now
Old 12-05-2018, 10:14 AM   #10
Trade: Highwayman
Rewards Points: 766
It'll be 1/4" plywood, probably Birch, with commercial vinyl plank over.
I was going over the project with my floor sub the other day, talking about fixing some issues in the subfloor, etc., and he just mentioned stapling underlayment.
I was a little surprised, because I kinda thought that had given way to ring shanks.
Another thing is, on my current project, there is old redwood T&G, then particle board, then some old asbestos vinyl tiles, and who knows what else, some areas patched with 3/4" plywood, and probably more random stuff in there, hence I'll be using 8D ring shanks.
Gotta make sure to get through all that crap.
hdavis (12-05-2018)
Old 12-05-2018, 11:13 AM   #11
Tom M's Avatar
I would use sixes. 8 is long.
Ring shank is the way to go. You're dealing with quarter inch sheet good the head of the nail is going to be holding the board down if you staple it you'll have to countersink it which is half the thickness of it.
Tom M is online now
Old 12-05-2018, 06:15 PM   #12
sparehair's Avatar
Trade: Painting, flooring
Rewards Points: 1,358
I've always laid loan with staples. Never had a problem but I'm not laying vinyl, usually Im nailing right back through it laying a blind nail hardwood floor.
Good friend of mine whose been laying vct on luan daily for years used a crown stapler.
sparehair is offline
Old 12-05-2018, 06:16 PM   #13
sparehair's Avatar
Also, the drywall joints get taped with 90 min and paper.
Old 12-05-2018, 07:59 PM   #14
hdavis's Avatar
Rewards Points: 1,534
Staples are no longer recommended. I haven't seen that it voids any warrantee. Birch isn't going to be stamped as underlay, so I doubt it matters.
hdavis is offline
Old 12-05-2018, 08:01 PM   #15
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 1,543
Easy. Ring-shanked staples.
rescraft is offline
Old 12-05-2018, 08:22 PM   #16
test
cedarboarder's Avatar
Trade: General
Rewards Points: 1,729
I've never seen anything but staples or glues on underlay
Sent from my SAMSUNG-SM-G891A using Tapatalk
cedarboarder is online now
Old 12-05-2018, 08:37 PM   #17
Dan_Watson's Avatar
Rewards Points: 2,746
Only seen RS once, always staples around here for luan.
Dan_Watson is online now
Old 12-05-2018, 08:50 PM   #18
TimNJ's Avatar
Rewards Points: 5,598
Around here, staples when lauan directly over plywood subfloor and nails when going through multiple layers of flooring.
TimNJ is offline
Old 12-05-2018, 09:16 PM   #19
spazman
spazman's Avatar
Trade: floorcovering installer
Rewards Points: 44
I haven’t used ring shanked nails to install underpayment for years and no installers that I know have either. Staples are a much quicker and consistent install. Nail heads would often show through some of the sheet vinyls that were being sold back in the day. That said, I would think that ring shanks would be fine under a floating vinyl plank.
spazman is offline
Old 12-05-2018, 10:38 PM   #20
Trade: Highwayman
Rewards Points: 766
Yea.....But.....I don't think any of my guns shoot 2".
And I'm not about to hand nail 42+ sheets.
Edit: Never mind. I just looked it up, and they will.
Least Protruding Button Cap Staples / Nails that won't "show up" under shingles MrCreosote Tools & Equipment 0 09-10-2017 07:59 PM
Professional Dumby here, siding / nails RhettMan General Discussion 34 10-30-2013 09:41 PM
Sheeting nails brendanstl Framing 16 06-19-2011 10:59 AM
hand nails or 18 gauge staples, in cedar shingles woodworkbykirk Carpentry 19 09-19-2009 10:26 AM
Screw or Ring Shank ? We Fix Houses Decks & Fencing 8 05-20-2009 11:46 PM
