Repairing Gouge In Textured Vinyl Floor - Flooring - Contractor Talk
Old 08-04-2019, 08:42 PM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 1,030
Continuous roll.
Apparently a sort of thumb-shaped flap was cut into the surface. Must have either been a helluvan drop an intentional strike.
The color of the vinyl is mixed tan and the surface texture is almost granular. And the gouge is right smack in the center of the area.
It stands out as a dark perimeter...that I intend to clean it with bleach or whatever?
As far as what to patch/seal with and possibly lay down with some weight - I found some marine adhesive with the disadvantage of being clear.
What could help conceal with a more solid color to help hide the sign of impact?
artinall is offline
Old 08-04-2019, 09:12 PM   #2
Mordekyle's Avatar
Rewards Points: 6,006
Re: Repairing Gouge In Textured Vinyl Floor
Area rug?
Mordekyle is offline
Old 08-04-2019, 09:33 PM   #3
artinall's Avatar
Originally Posted by Mordekyle View Post
Area rug?
Unfortunately can't. Unit's entirely vacant.
artinall is offline
Old 08-05-2019, 02:32 AM   #4
VinylHanger's Avatar
Rewards Points: 12,984
IIRC, my floor guy just uses seam sealer. Or the glue he used on the floor. I got a hole like that once when my boot lace hook ripped a hole just as I was finishing an entryway. Very last thing, very last moment and we were done.
Called him and he said just push it down and it will be fine.
I'd go with seam sealer on an old floor. Especially if it is a rental.
VinylHanger is offline
The Following 2 Users Say Thank You to VinylHanger For This Useful Post:
artinall (08-05-2019), TheConstruct (08-05-2019)
Old 08-05-2019, 05:39 AM   #5
hdavis's Avatar
Rewards Points: 1,198
Seam sealer or cut a patch in and seam sealer.
hdavis is online now
Old 08-05-2019, 09:38 AM   #6
artinall's Avatar
Any particular kind?
Hopefully comes in tan...unless I can find a way to add color to it.
artinall is offline
Old 08-05-2019, 11:48 AM   #7
No idea. Never thought to ask.
Old 08-05-2019, 11:57 AM   #8
MarkJames's Avatar
Rewards Points: 18,987
MarkJames is offline
The Following 2 Users Say Thank You to MarkJames For This Useful Post:
artinall (08-05-2019), Sisyphus (08-06-2019)
Old 08-05-2019, 01:01 PM   #9
tang's Avatar
Trade: Remodel contractor
Rewards Points: 517
I have taken a "Dutchman" from under the stove or fridge, following the pattern. Seen it a few times sliding appliances....
tang is offline
Old 02-18-2020, 10:07 AM   #10
artinall's Avatar
As a follow up, went with a 'CalFlor VinylFix' kit and nobody could detect it - pointing out the generally vicinity.
THX MarkJames
artinall is offline
The Following User Says Thank You to artinall For This Useful Post:
TheConstruct (02-18-2020)
