Removing Dents In New Hardwood Floor - Flooring - Contractor Talk
Old 05-30-2010, 07:19 PM   #1
frankster's Avatar
Rewards Points: 75
Doing a floor and kitchen cabinet remodel. The downfall is the homeowner is living in the house while we try to do this. 1200 square of hardwood floor (OAK prefinish nail down). HO being there also means lots of furniture moving back and forth so no paper or cardboard protection during install.
Problem is this. We laid out cardboard runners to roll the fridge out of the kitchen area to finish wood floor and in doing so it appears the wheels of the fridge are riding on the outer edges of the wheels instead of flat to surface and left railroad tracks across the new floor. YIKES!!!
Owner is not to worried about it but it bothers me. I have started useing a steam iron and wet towel to try to lift the grain, with some success. Looking for any other ideas to help raise the wood grain back up
frankster is offline
Old 05-30-2010, 07:38 PM   #2
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 5,123
Re: Removing Dents In New Hardwood Floor
Steam it out like you are doing or sand it out. Those are your two easy choices.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
neolitic (05-30-2010)
Old 05-30-2010, 07:50 PM   #3
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 94
Steaming it out is a good way to cause finish failure & potentially void the warranty on a prefinished floor. The only real solutions is to replace the damaged boards. It's really not that hard to do. Length cut 2 cuts per board with your skill saw to remove. On replacement boards, remove the tonge & put a 10-15 degree back bevel on the tongue side. Cut to length & use a little construction adhesive below them to hold them down. Personally, I like bostiks best in the tube for this.
pinwheel is online now
Old 05-30-2010, 07:52 PM   #4
LRG WoodCrafting
Leo G's Avatar
I missed the prefinished part.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 05-31-2010, 01:58 AM   #5
finaltouchfloor's Avatar
Trade: Flooring & Remodeling
Rewards Points: 75
We always use masonite when rolling a fridge or any other heavy objects across wood floors. I buy a 4 x 8 sheet 1/4" thick for $10. Cut into half & put one in front of the other. It has saved me from all the bull with soft bamboo or thin 5/16 or 3/8" wood which you problably installed.
I make good money repairing damage like this due to painters or plumbers. I charge $350 to $550 to cut out the damaged wood & re-install. The only right way to fix it is to cut it out & replace.
We also use masonite when rolling hevy objects across tile like travertine or slate which cracks easy. Prevention is also the easiest solution.
finaltouchfloor is offline
The Following User Says Thank You to finaltouchfloor For This Useful Post:
pinwheel (05-31-2010)
Old 05-31-2010, 06:31 AM   #6
pinwheel's Avatar
Rewards Points: 94
yep, yep, yep, I agree. We do the same. Masonite or luan. If I need a long runner, I keep a spare roll of quietwalk in the trailer & roll it out, then lift the heavy object with my piano dollies & roll it right down the runner & into place.
Old 05-31-2010, 12:45 PM   #7
Paul
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Rewards Points: 1,004
I got you all beat...I use an airsled
Seriously, I'm in agreement. Only way to truly fix it is plank replacements and an ounce of prevention goes a helluva long way on pre-finished hardwood. It scratches and dents with an angry look.
Precision Floors
(772) 237-9900
PrecisionFloors is offline
Old 05-31-2010, 12:55 PM   #8
Dan
ApgarNJ's Avatar
Rewards Points: 2,000
get yourself a set of those appliance slides the appliance installers use them all the time. they work great, cardboard is way too soft.
sorry about your damage, i'd suggest cutting out the boards and installing new ones.
ApgarNJ is offline
Old 05-31-2010, 09:12 PM   #9
frankster's Avatar
Rewards Points: 75
The HO doesnt want to bother with replacing the damaged boards. The fridge was a small fridge but the problem discovered after the fact was the wheels are rideing on the outside edges on not on the whole wheel like it should. I do agree about a masonite type product being used. We did not have it on hand and the small fridge was the only appliance that needed to be moved the way it did and truely felt it was not a problem. Wont make that mistake ever again.
The area we test steamed worked rather well and did not damage the prefinish. That was part of my fear when we walked in this morning. The product is 3/4" solid oak.
Old 05-31-2010, 09:18 PM   #10
Dan
ApgarNJ's Avatar
masonite is too thick. these heavy plastic appliance strips are heavy duty and work wonders. the first time i saw them was several years ago and I knew I had to get some. last thing i'd want to do is scratch a floor i just put down. you can use them for all sorts of appliances and they are thin enough that it rolls right up on to. masonite is ok if you have nothing else but it's still thick enough to give you trouble with a heavy appliance getting it up over the lip edge.
ApgarNJ is offline
Old 06-27-2010, 11:07 PM   #11
RhodesHardwood's Avatar
Trade: Hardwood Floors
Rewards Points: 594
The right way to do it is to patch the boards and sand the floor
RhodesHardwood is offline
Hardwood floor loose Mcdonoughman Flooring 6 02-27-2010 08:39 AM
What is waterborne hardwood floor finish? hardwoodfloors Flooring 3 07-14-2009 10:03 AM
squeaky hardwood floor help master mason Flooring 3 03-08-2008 11:07 AM
floor not level for hardwood laminate sterling stone Flooring 14 02-18-2007 05:41 PM
Removing asbestos floor tile: Space suits needed? Ted W General Discussion 19 01-29-2007 02:38 PM
