Re-set Toilet - Page 4 - Flooring - Contractor Talk
Re-set Toilet
Old 12-04-2012, 08:06 PM   #61
The Sheriff
Jaws's Avatar
Trade: Builder
Rewards Points: 16,150
Re: Re-set Toilet
Originally Posted by ClaytonR View Post
Hahaha. That did sound a little pompous now that I re-read it. I'm no hotshot, and my response wasn't so much about how much to charge, but in regards to the idea that was being put forth on this thread that if you aren't a plumber, you can't re-set a toilet. The idea of calling and paying a plumber $250 bucks (or even $150) to re-set a toilet because you don't want to be liable for screwing it up or some such seems crazy to me.
If I'm doing a job that requires me to remove the toilet and put it back I'd probably add $100 bucks, and I'd do it myself. Depends though, I might do it for $35 if I was in a good mood, had the time, and it just kind of fell to me to do it.
As to how I install it- assuming the flange and shut off are in good repair- I always buy the best wax ring I can find. I like the ones with a rubber boot going down in the hole a bit. If I have to level it, it's usually not much, and I use plastic shims. (I like the composite door shims) After it's bolted down and I'm sure it's not leaking, I like a nice bead of white silicone around the bottom. I generally use the braided steel flex lines for a supply, unless I'm just hooking the old one right back up. I've set I don't know how many toilets, in my houses and in customers houses, and I don't remember ever having a problem.
I used to think the same way and understand your thinking. Im also not going to lie and say I wont re set a toilet on a remodel if im slow. But on a project of any significance, the re setting or changing of fixtures is included in my plumbers bid. How much are you generating in year setting toilets? Not that signicant really.
Say what you want, but chit happens ALL THE TIME and a simple supply leak could cost you many thousands
If i was slow and needed to keep the dollars on a project , carpentry, floors, EVEN painting would be on my list before plumbing.
Although I did set two toilets yesterday, because the plumber got hung up and I needed it done.
Im kind of 50/50. Never had leak that caused damage, but dont want it on my wallet if I do.
"The sound of the saftey clicking off is the only warning your gonna get......., so cover your ears" Northeast Wyoming 2016
John
Jaws is online now
The Following User Says Thank You to Jaws For This Useful Post:
Old 12-04-2012, 08:12 PM   #62
rselectric1's Avatar
Rewards Points: 950
Re: Re-set Toilet
This thread is searchable by any homeowner who has access to a computer. Do we really want to go throwing around pricing numbers like this? Homeowners will tend to use the lowest number on this thread as the gospel without taking into account all the details.
(And the prices for a licensed plumber to set a toilet and back up his installation is higher IN MY AREA). See where I'm going?
rselectric1 is offline
The Following 3 Users Say Thank You to rselectric1 For This Useful Post:
Jaws (12-04-2012), MAULEMALL (12-04-2012)
Old 12-04-2012, 09:05 PM   #63
MIKE ANTONETTI's Avatar
Trade: FLOORING CONTRACTOR
Rewards Points: 3,514
Re: Re-set Toilet
That's like going to Mercedes and saying Kia can sell me a car for way less, my question is where are those cheap cars from 10 -20 years ago, I'm still looking for them, they're about as rare as a Ferrari in my neck of the woods
MIKE ANTONETTI is offline
Old 12-04-2012, 10:15 PM   #64
adams,b's Avatar
Trade: hardwood floors
Rewards Points: 250
Re: Re-set Toilet
Can I ? Yes I can. And I do in my house, but not in a customers home. We will pull it, but not re set it. That's for the plumbers, not the floor guys.
adams,b is offline
Old 12-05-2012, 06:32 AM   #65
fcfc's Avatar
Trade: Flooring
Rewards Points: 81
Re: Re-set Toilet
We run into this all the time. Our response is generally, we pull em for free (the labor is factored into the floor bid) but the customer is responsible for arranging the re-install (little ole ladies, houses with one toilets, etc, seem to be constant loopholes, since if I am not personally co-ordinating with the plumber, I will often-time reset toilets out of sheer necessity) I do not charge to reinstall because I do not want to be liable. I have had the misfortune of paying for a bathroom floor that myself and one of my original trainers installed over our own objections and with numerous verbal warnings to the client. Since our objections were not noted in writing and we were silly enough to itemize it on our bid, even though the fault lay in the broken flange that was not properly supported to boot, we paid for that floor twice before we were off the hook. The only toilet leaks I have personally encountered with a reinstall involved faulty or improperly supported plumbing (or in some cases, where the plumbing was considered structure, but thats another storey). Yet not being a plumber, nor having the bond or license for it, it seems completely natural to let that be something separate for the homeowner. Theres a reason they are paid the big bucks for their time, and the same goes for our time as well. I get paid to floor. Not plumb. Nor bob.
fcfc is offline
The Following 2 Users Say Thank You to fcfc For This Useful Post:
LConstruction (12-05-2012), MIKE ANTONETTI (12-05-2012)
Old 12-05-2012, 08:02 AM   #66
BamBamm5144's Avatar
Trade: Everything Exterior, Mostly Roofing.
Rewards Points: 2,786
Re: Re-set Toilet
It doesn't matter if you got paid for doing it or not. Anything you touch, you own.
BamBamm5144 is offline
The Following User Says Thank You to BamBamm5144 For This Useful Post:
Old 12-05-2012, 08:25 AM   #67
PCI
PCI's Avatar
Trade: contractor
Rewards Points: 848
Re: Re-set Toilet
I was tangled in a lawsuit that involved a broken toilet supply line that did $130k worth of damage. Plumbers ins settled for half because he supplied the faulty supply tube.
My ins comp told me if I put it in then I wasn't covered under my policy. I'm glad I don't set toilets.
PCI is offline
The Following User Says Thank You to PCI For This Useful Post:
Jaws (12-05-2012)
Old 12-05-2012, 09:37 AM   #68
The Sheriff
Jaws's Avatar
Trade: Builder
Question
Re: Re-set Toilet
It matters to insurance (mine) if a licensed plumber was the one doing it.
John
Jaws is online now
Old 12-05-2012, 10:56 AM   #69
Re: Re-set Toilet
I was replying to the post above mine.
Jaws (12-05-2012)
Old 12-05-2012, 05:32 PM   #70
GO Remodeling's Avatar
Rewards Points: 96
Re: Re-set Toilet
My insurance will cover if I reset a toilet but you better check to be sure. Like a previous post a leak will cost thousands. Why take the chance when insurance isn't that much?
GO Remodeling is offline
Old 12-05-2012, 07:23 PM   #71
Orlando Car
Floormasta78's Avatar
Trade: certified floor covering installer.
Rewards Points: 1,154
Re: Re-set Toilet
Wow, I unsubscribed because the topic was getting idiotic.
Now , insurance to re set a toilet..
Hahahahaa !
This is hilarious. I like it !
http://www.facebook.com/#!/certifiedfloorcovering
Certified Floor Covering
Serving All California
( 510 ) 760 - 6810
Floormasta78 is offline
Old 12-05-2012, 07:44 PM   #72
rugaddict's Avatar
Trade: flooring
Re: Re-set Toilet
heres my tale for whats its worth---the lady had a plumber all lined up but the store ordered the wrong floor--she didnt want to pay a plumber twice so i said id do it ---nine months later---NINE MONTHS LATER---the flex water supply burst and she wanted to come after my insurance---that was a decade ago and i havent set a toilet back since
rugaddict is offline
Old 12-05-2012, 07:55 PM   #73
Re: Re-set Toilet
The stainless braided supply line has a plastic end that attaches to the tank valve. Seriously manufacture braided stainless steel and put a plastic screw on connector, where's the weakest link in this product? If the length is incorrect and you have to put a little twist or loop, there's uneven pressure pushing sideways weakening the plastic causing fatigue and burst open an insurance claim.
Old 12-05-2012, 08:03 PM   #74
Orlando Car
Re: Re-set Toilet
Is this thread , it should be in the plumber thread
( 510 ) 760 - 6810
Old 12-05-2012, 10:59 PM   #75
Rewards Points: 96
Re: Re-set Toilet
I know it's only a toilet but mistakes happen- even to pros. Just ask your insurance agent.
Tile guy I know disconnects one piece toilet. Cracks the base--$500 out of his pocket. Another tile guy is begged to reconnect a toilet by a realtor showing home. Tells her no at first then relents. Drip from connection leaks all weekend flooding bath. Good intentions need good insurance IMO.
Old 12-05-2012, 11:30 PM   #76
BKM Resilient's Avatar
Trade: Flooring
Rewards Points: 836
Re: Re-set Toilet
Originally Posted by MIKE ANTONETTI View Post
Not every toilet R&R is the same, a supply line and seal is 10 bucks, you can absorb that if profit is good enough but getting paid by square foot is for tile, no toilet included, furniture usually included in rooms, less if empty, fridge -extra, oven -extra, sealing grout -extra, toilet install minimum should be 35 no matter where your at and that's a bargain, the max I would think 150.
I throw bleach in the bowl prior to touching and a little in tank, spray bleach around seal, remove wax stuck under bowl, new bolts, wax seal, level bowl, quick setting white grout.
Hi Mike.
WAX GASKET
I realize the residential subcontractor lives a very different life than a commercial, hourly employee. I handle one or three wax gaskets every 5-10 years in my line.
SERIOUSLY, as soon as I hear or read the words WAX GASKET on the work order my lifelong affliction with BURSITIS starts acting up and I need a few days off-------til THAT job falls off the shop schedule. I wish I was so rich I could retire. I'm able to live a few days here and there without a paycheck.
Bursitis is a bitch condition to live with.
https://www.google.com/search?q=burs...w=1155&bih=614
BKM Resilient is offline
Old 12-06-2012, 12:03 AM   #77
KennMacMoragh's Avatar
Trade: Repair/Remodel
Rewards Points: 3,386
Re: Re-set Toilet
Originally Posted by Osito
How many of you charges to re-set toilet after tiling bathroom? A flooring company I sub for says that should be part of the tile job, I say it's extra. I need in put.
Don't question yourself on how you price your work, it's your decision not theirs. Your lack of confidence is going to show. To answer your question, yes I charge extra to re-set a toilet, I clearly show it to them the price of each, tile work, toilet, floor prep, etc. mainly because that's how my estimating software works. I haven't subbed for other G.C's very often, but when I have I've found a lot of them will think of creative ways to haggle your price down. It's pretty easy to deal with, just say no.
KennMacMoragh is offline
Old 12-06-2012, 06:18 AM   #78
Big Shoe's Avatar
Rewards Points: 2,122
Re: Re-set Toilet
Little story for you.
GC calls me to do a water damage repair. Toilet leak. I do the repair. $600
Check comes from the tile guy
I told him not to set any more toilets.
Expect the Unexpected
Big Shoe is offline
The Following User Says Thank You to Big Shoe For This Useful Post:
Jaws (12-06-2012)
Old 12-19-2012, 06:52 PM   #79
Re: Re-set Toilet
Ok I thought this post was over but I have couple more things.
With all this talk about problems leaking etc., I stopped installing toilets and let my brother install them and said its your insurance.
Checked Home Depot for all metal supply lines , only faucets are all metal and toilets have plastic end fittings to the toilet . Then went to lowes and noticed they had supply lines with built in valve that closes if the line bursts, still with plastic end fitting (weak link) 6.39$ for 12" stainless, I bought 4.
Flange height is important if it is low a regular seal will leave a gap. Also have to look under the bowl and scrape the previous seal
Last thing is it is important to get a hepatitis vaccine, I don't know which one A,B or C, and it is a series of 2 or 3 shots over several months then booster shots after so many years.
I grout the bowl if it won't sit flat on floor for stability, white fast setting grout or patch, I caulk with mildew resistant tub n tile (urethane) caulk if she sits nice and snug on floor, and never over tighten .
Old 12-20-2012, 11:38 AM   #80
Re: Re-set Toilet
Is he a licensed plumber? I don't know how it works where you are but around here any plumbing work that I do is not covered by my insurance, my GC insurance only covers building not plumbing. If I installed a toilet that leaked and caused $10,000 worth of damage, my insurance would say too bad.
Where do you keep your toilet snake? Everend Plumbing 12 07-12-2012 11:04 PM
Is Access to a Toilet a ‘Basic Human Right’?: (This isn't a joke!) MAULEMALL Off Topic (Non Trade) 50 05-28-2012 02:42 PM
Easy, toilet replacement fireguy Plumbing 21 05-12-2011 08:03 AM
Toilet seal gnxtc2 Plumbing 6 04-01-2011 03:25 PM
Toilet Challenge Vermaraj Plumbing 40 11-09-2007 09:04 PM
