Raising A Subfloor - Flooring - Contractor Talk
Raising A Subfloor
Old 02-23-2013, 09:55 PM   #1
bumslayer's Avatar
Trade: painter
Raising A Subfloor
Hello guys im kinda new to this site i need a little help here I am a paint contractor by trade and to make ends meet ive taken on a few tile jobs and now ive got one that has me baffeled a bit. i have a bathroom in a homa build in 1948 and it has slab flooring with hard wood floors on top best i can tell from the rotting in the floor in the bathroom the slab is 3 inches below the finished floor. my ? is what is the best method for raising my subfloor level up 2.5 inches so i can lay tile any advise or imput would be helpful thank you guys very much. and please no bashing or trashing and negativity i dont have time for it i get enough of it from painttalk please.
bumslayer is offline
Old 02-23-2013, 11:39 PM   #2
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,484
Re: Raising A Subfloor
Three sheets of plywood and some extra mortar on the tile?
Metro M & L is offline
Old 02-24-2013, 12:05 AM   #3
skillman's Avatar
Rewards Points: 1,968
2 by sleepier's on floor them plywood . Atfer that wonder board or ditra on floor under tile . Just play the numbers game to get your hieght your looking for .
skillman is offline
Old 02-24-2013, 12:07 AM   #4
Fire up the BBQ
griz's Avatar
Rewards Points: 1,044
Fill it with concrete & be done with it....
griz is offline
thezoo (02-24-2013)
Old 02-24-2013, 12:16 AM   #5
Keeyter's Avatar
Trade: Home Remodels
Rewards Points: 851
Im with Griz - level with a concrete or better build up with concrete and overlay a self leveling cement. Sleepers for that much in a bathroom is a pit for water.
Keeyter is offline
Old 02-24-2013, 08:01 PM   #6
bumslayer's Avatar
Trade: painter
is it very hard to lay concrete in bathroom and get it level
Old 02-24-2013, 09:51 PM   #7
MIKE ANTONETTI's Avatar
Trade: FLOORING CONTRACTOR
Rewards Points: 3,514
Dry pack mud bed just like for shower floors.
Slurry Portland paste on slab then mix Portland and sand 1 part Portland 4 parts sand, mix it then add water with a sprinkle can while mixing till when you pick it up and squeeze it in your hand it sticks together, then dump buckets full and pack it down using a trowel .
Outline the perimeter for your height then fill in middle and use edges as screed boards. Let it set up then thinset your tile to the mud bed. Key in the thinset to the mud bed by using the flat side of trowel then flip and comb the appropriate notched trowel
MIKE ANTONETTI is offline
Subfloor with unstaggered joints: Laminate to be installed. asevereid Flooring 2 11-12-2012 07:34 AM
Uneven Concrete Meets Subfloor Handy Hero Flooring 6 09-30-2012 04:59 PM
subfloor problem jimh Flooring 21 02-25-2011 12:22 AM
Removing Porcelain Tile on Stapled and Glued Subfloor ParaDiddle777 Flooring 20 11-08-2008 09:48 PM
Raising a subfloor issues? Seminole Flooring 2 05-16-2008 02:01 PM
