Radiant Heat Under Ceramic Tile - Flooring - Contractor Talk
Old 11-26-2013, 01:25 AM   #1
Do Work!
martymc's Avatar
Trade: kitchen/bath remodeling
Rewards Points: 25
we have done several heated floors under ceramic tile using the mats and have had fairly good luck with keeping the tiles plumb.
We use a 1/2" trowel where there is no mat and use a 3/8" trowel over the mat.
the last bathroom we did, we used a cable system... IT WAS AWFUL!!!! not only did the guy sell us WAY to much cable we had no idea what we were doing. We installed the cable 4 times before we got the proper lay out. We had 2 rolls of cable 1 did 60sqft the other did 70sqft (its a pretty big bathroom). We tried the 60sqft roll twice before we realized it wasn't enough, and then used the 70sqft roll and eventually made it work. We could have used both rolls but its not recommended to install it under tubs and cabinets.
After the cables were installed we used floor leveler to cover the cables and a small area surrounding the cables. when we went to lay the 18x18 tile it was a nightmare to get the tiles level with one another.
is there a better way to level the tiles? should we have just used a ton of floor leveler on the whole floor?
martymc is offline
Old 11-26-2013, 01:38 AM   #2
KennMacMoragh's Avatar
Trade: Repair/Remodel
Rewards Points: 3,278
Re: Radiant Heat Under Ceramic Tile
The tile guy I talk to says he uses Easy Mat for bathroom tiled floor heating, along with Fusion Pro grout. Remember, don't use a wax seal on the toilet.
KennMacMoragh is offline
Old 11-26-2013, 09:07 AM   #3
Builder/Remodeler
ChrWright's Avatar
Trade: Builder/Remodeler
Rewards Points: 2,030
I've used both mat systems and loose lay cable systems and I prefer the latter.
That said, it is more of a PITA from a labor perspective. The manufacturer should have provided a spacing guide based on the square footage you were covering, and the length of cable--but I know it still takes a little thought and sometimes t&e to get it just right.
In answer to your last question--yes, you'll get a much better result by leveling the entire floor to the depth of the cable. Once the cable is installed, we run screws throughout the room around 2' o.c.--leaving them up at the height we want the top of the leveler pour.
With an uneven floor, a cable system kills two birds with one stone. Even coverage throughout the space, and a perfectly level floor.
Hope that helps.
Christopher Wright, CR: President @ WrightWorks, LLC
www.WrightWorks.net - Facebook - Instagram - Carmel Remodeling
Indianapolis Kitchen Remodeling Contractor - Master of the Home Feature
ChrWright is offline
Old 11-26-2013, 10:08 AM   #4
tjbnwi's Avatar
Rewards Points: 4,240
With a loose cable system you have to start in the center of run then lace both directions. The center of run may not be the center of the room.
SLC on the entire floor. I mix mine in a plastic tote, usually 3 bags at a time. The fewer times you have to mix the better.
I do use wax rings on the toilet, just keep the cable 6" from the flange.
tjbnwi is offline
Old 11-26-2013, 11:31 AM   #5
CarpenterSFO's Avatar
Rewards Points: 2,044
What cable system do you use?
- Bob
CarpenterSFO is offline
Old 11-26-2013, 12:36 PM   #6
tjbnwi's Avatar
http://www.suntouch.com/warmwire/
I also use their mats. Their products are rated for wet environments, I use them in showers.
tjbnwi is offline
CarpenterSFO (11-26-2013), Floormasta78 (11-28-2013)
Old 11-26-2013, 01:10 PM   #7
Originally Posted by tjbnwi View Post
[url]... I use them in showers.
I'm going to try to start working that into pied-a-terre/bachelor pad remodels. High-rise condos are all about those touches.
- Bob
- Bob
Old 11-26-2013, 01:14 PM   #8
tjbnwi's Avatar
Next you'll be doing heated mirrors in the shower niches…..
tjbnwi is offline
Old 11-26-2013, 01:37 PM   #9
Keep going; I'm writing these down.
- Bob
The Following User Says Thank You to CarpenterSFO For This Useful Post:
Gary H (11-26-2013)
Old 11-26-2013, 02:00 PM   #10
tjbnwi's Avatar
Both these mirrors have the hot water line that supplies the shower mixing valve sandwiched between (but not touching, that would be bad) 2 aluminum plates running behind them. Both are 4 runs on the bottom ⅓. I did pad out the wall ¾" so the shelf would be deep enough. Next one I'll take progress pictures.
Also found a picture of the SunTouch mat on the shower floor. The dark is plastic lath, the rest of the area will get the same.
radiant heat under ceramic tile-img_2431.jpg   radiant heat under ceramic tile-img_0278.jpg   radiant heat under ceramic tile-img_0219.jpg
tjbnwi is offline
The Following 3 Users Say Thank You to tjbnwi For This Useful Post:
CarpenterSFO (11-26-2013), Floormasta78 (11-28-2013), MTN REMODEL LLC (11-26-2013)
Old 11-26-2013, 09:29 PM   #11
ArtisanRemod's Avatar
Rewards Points: 582
Laticrete NXT level
ArtisanRemod is offline
The Following User Says Thank You to ArtisanRemod For This Useful Post:
Old 11-26-2013, 09:52 PM   #12
tjbnwi's Avatar
Lacitcrete does not require primer and lath over wood?
I use Mapie, they require primer and lath. They manufacture a plastic lath for use with electric heat.
tjbnwi is offline
Old 11-26-2013, 09:55 PM   #13
Rewards Points: 582
Primer yes, no lathe required
Old 11-26-2013, 10:03 PM   #14
tjbnwi's Avatar
Okay, I find that interesting as the wood and cement product move at different rates.
tjbnwi is offline
Old 11-26-2013, 10:06 PM   #15
Rewards Points: 582
I'll have to reread the specs. I went with my suppliers suggestion, and he hasn't steered me wrong yet.
Old 11-28-2013, 06:56 AM   #16
Orlando Car
Floormasta78's Avatar
Trade: certified floor covering installer.
Rewards Points: 1,154
I'm starting a heated floor shower also that will have heat in the shower area also... pictures to come. Wish me Luck, it might be SHOCKING experience..
http://www.facebook.com/#!/certifiedfloorcovering
Certified Floor Covering
Serving All California
( 510 ) 760 - 6810
Floormasta78 is offline
Old 11-28-2013, 07:31 AM   #17
Rewards Points: 582
I read the nxt specs and a lathe is required over plywood.
Old 11-28-2013, 07:37 AM   #18
Orlando Car
Good!! You can read. You get a good boy star for that..
Haha !
( 510 ) 760 - 6810
The Following User Says Thank You to Floormasta78 For This Useful Post:
ArtisanRemod (11-28-2013)
Old 11-28-2013, 07:47 AM   #19
builditguy's Avatar
Rewards Points: 1,440
I've had the best luck with the loose wire systems. Can't remember the brand. I don't do many, but when I do, I use a hot glue gun to glue the wires down. It comes with sticky holders that are spaced evenly, but I always want the wires fastened between the holders. Then we pour leveler over the entire floor. Works great. Gives me a perfect base for the new tile and covers the wires.
builditguy is offline
Old 11-28-2013, 08:05 AM   #20
tjbnwi's Avatar
That's why I went to the SunTouch system. Their system is UL listed for in shower use.
tjbnwi is offline
Commercial Ceramic tile on concrete slab removal TD40 Tiling 5 03-18-2018 07:26 AM
commercial ceramic tile removal fshrs1 Flooring 9 07-21-2012 08:48 PM
Foil "insulation"? Tinstaafl Insulation 22 03-07-2011 11:01 PM
how many courses for ceramic tile shower walls? Bazooka Joe Tiling 19 02-14-2009 11:06 PM
Ceramic Tile Bumps Unit 138 Tiling 7 12-28-2008 05:55 PM
