Porcelain Tile Chips - Page 2 - Flooring - Contractor Talk
Old 01-06-2020, 11:21 PM   #21
Stunt Carpenter's Avatar
Rewards Points: 2,740
Re: Porcelain Tile Chips
That looks like he was cleaning out the grout joint with something a drove it into the tile.
Or used pliers to pull the clip.
https://builddaley.com/
Stunt Carpenter is online now
Old 01-06-2020, 11:25 PM   #22
tjbnwi's Avatar
Rewards Points: 3,980
On floors, I have found nothing better than a moderately swift kick.
As I said in an earlier post, only times I have a clinger is when I get sloppy with the mortar in the joints.
tjbnwi is online now
Dstempr (01-07-2020)
Old 01-07-2020, 12:10 AM   #23
I agree on the swift kick. For showers I use a 1/2 lbs dead blow. I find it leave less marks than a rubber mallet
I have had a few that I over tightened that pre breaks one side and that leaves a little nub that can be tricky to remove.
The Following User Says Thank You to Stunt Carpenter For This Useful Post:
Old 01-07-2020, 12:27 AM   #24
tjbnwi's Avatar
If the nub is sticking up above the tile, use a 5/16 or 3/8 maple dowel rod to break it off. Little tap and it will snap right off.
It is helpful to soak the clips in water over night when you first get them.
Old 01-07-2020, 10:00 AM   #25
Dstempr's Avatar
Trade: Daniels floor covering service
Rewards Points: 8
Thanks Tom.I purchased the burn in kit and will give that a shot.What type of mortar and trowel size do you recommend when installing 12x24/large plank porcelain tiles?Ive been using full contact by tec and 1/2" trowel to get better coverage.
Sent from my SM-G935V using Tapatalk
Dstempr is offline
Old 01-07-2020, 10:02 AM   #26
Dstempr's Avatar
Rewards Points: 8
One of the helpers used an oscillator.
Dstempr is offline
Old 01-07-2020, 10:06 AM   #27
Dstempr's Avatar
Rewards Points: 8
Originally Posted by MarkJames View Post
There really isn't one, besides replacing tiles. Is someone at fault, or is this just a repair request?
Nobody's fault but mine
Dstempr is offline
Old 01-07-2020, 08:28 PM   #28
tjbnwi's Avatar
Pratice with the burn in kit. A fine to medium tip soldering iron is your best heat source choice on that chip. I use a nib file to get the patch cleaned up, again something that takes pratice to use properly.
For any large format tile (LFT is difined by the NTCA and TCNA--as a tile 16x16 or has one dimension 15" or larger), I use either the 1/2x1/2 or a Rubi Euro trowel. My go to mortars are Schluter All Set or Mapie (which Mapie depends on what and where I'm setting). All Set is closer to a mid set than thin set.
I've read/heard great things about Laticrete mortars, no supplier local to me.
All proclien tile MUST be at least back buttered. Back troweling in not normally necessary.
Old 01-16-2020, 10:43 AM   #29
Commercial Flooring Guy
Mitch15's Avatar
Trade: Flooring
Rewards Points: 66
Very true!
Mitch15 is offline
Old 01-16-2020, 10:46 AM   #30
Mitch15's Avatar
Trade: Flooring
Rewards Points: 66
Good advice!
Mitch15 is offline
The Following User Says Thank You to Mitch15 For This Useful Post:
Big Johnson (01-16-2020)
Old 01-24-2020, 07:50 PM   #31
zmusashi's Avatar
Trade: carpentry, remodeling
Rewards Points: 59
This just happened to me on a laundry room tiled floor- I mostly thought it was the tile quality/ glaze being that she purchased it at Home Depot? Two chips, one tile I replaced the other grouted in fine, but I installed it carefully (for me :-D)
zmusashi is offline
