Ply On Slab ....yeah I Know - Flooring - Contractor Talk
Old 02-05-2013, 07:31 PM   #1
InterCounty's Avatar
Trade: Hardwood Flooring Contractor
Rewards Points: 896
I know a lot of guys dont like the idea of ply affixed to slab but I have a HO that wants a hw floor level to his kitchen.
The kitchen floor is about 1 1/8" higher then the slab.
He wants to put 3/4 ply down with glued engi to the ply.
Sleepers are out bc of height to high.
Glued engi is out bc of height to low.
Floating engi is out bc HO hates the idea.
Years ago I did several ply on slab and nailed solid 2 1/4" down.
I troweled the entire slab with Karnak #79AF wood block mastic, dropped on the ply and ram set them every 12" bc Hammer bolts seem way to slow. (NO call backs!)
Now I usually sell a floating or engi slab glued with Bona R851, but HO wants height to be right.
I read about double floating 1/2" ply but am skeptical about movement (bounce) and I doubt HO would go for it.
Plus, it would throw off the height.
Should I use Bostiks Best, Titebond 811 or another urethane adheasive or is that overkill/overprice for ply?
Wondering what other guys do, or would do, here?
"Of course to want it done today....... if you wanted it done tomorrow, you'd wait until then to call me"
http://www.InterCountyFloors.com
InterCounty is offline
Old 02-05-2013, 10:34 PM   #2
jamestrd's Avatar
Trade: wood flooring
Rewards Points: 1,280
Re: Ply On Slab ....yeah I Know
Do what you know works..like I do.
i have yet to EVER have problem with an affixed ply to slab..
it is till in the NWFA specs and has not been removed.
those are the guidelines that set OUR industry..
anybody else's logic/and or rocket science don't matter.
they don't represent us in court..but our proven practices and approached governed by our Worldwide organisation does.
PS..
Karnak...thought i was the only one still using it...
their home is here in NJ...
James Hernandez
All Flortec Inc.
West Milford,NJ
www.flortechardwood.net
jamestrd is offline
Deep fill under garage slab lazerguy Masonry 25 08-06-2014 08:37 AM
Filling large voids in a concrete slab Terrorron Flooring 4 10-14-2011 01:17 PM
Installing a Door Slab CookeCarpentry Finish Carpentry 62 07-11-2010 07:23 AM
Spray foam under a slab for insulation -- Mike Finley Construction 22 01-10-2010 02:39 PM
sub floor over radiant heat slab benvolio Decks & Fencing 6 12-17-2009 10:39 AM
