Orbital Versus Drum Hardwood Flooring Sander--Which Is Better? - Flooring - Contractor Talk
Old 11-08-2014, 08:47 AM   #1
tonyc56's Avatar
Trade: Window Treatments
Rewards Points: 3,686
According to the following website it states that an orbital sander is lighter and easier to use. If true why do flooring professionals still use the heavy drum sander to sand floors.
http://www.u-sand.com/u-sand/superbee.aspx
tonyc56 is offline
Old 11-08-2014, 09:21 AM   #2
Mark122's Avatar
Rewards Points: 464
Re: Orbital Versus Drum Hardwood Flooring Sander--Which Is Better?
because they are lighter and dont have the weight required to sand down some kinds of woods.
We just watched a guy try and sand down 1 1/2'' x 3/4'' unfinished hickory with one of those lighter machines...2 days later he got a drum. He obviously was not very seasoned in finishing floors.
Mark122 is offline
Old 11-08-2014, 03:56 PM   #3
ccoffer's Avatar
Rewards Points: 1,140
You're basically talking about a square buffer. They aren't worth a crap on anything harder than cypress. I prefer a belt sander, personally.
ccoffer is offline
The Following 2 Users Say Thank You to ccoffer For This Useful Post:
pinwheel (11-09-2014), tenon0774 (11-08-2014)
Old 11-08-2014, 04:39 PM   #4
nickko's Avatar
Trade: remodeling-cabinet maker
Rewards Points: 789
I am in the process of refinishing some white oak floors right now.
I rented the U sand random orbit sander and ran it for about five minutes before I realized it was worthless. Went and rented a soft drum put on some 20 grit and went to town.
Nicko
"Quality work for those who know the difference"
nickko is offline
Old 11-08-2014, 07:05 PM   #5
MIKE ANTONETTI's Avatar
Trade: FLOORING CONTRACTOR
Rewards Points: 3,514
That drives me crazy renting something, starting it, and it doesn't do what you need it to, or its way too slow.
MIKE ANTONETTI is offline
Old 11-08-2014, 07:13 PM   #6
tenon0774's Avatar
Trade: Remodeling Carpenter
Rewards Points: 2,270
...and the people renting it are more often that not to shuck the company line.
Those orbital sanders SUCK! for removing finish from oak.
I wanted to beat the guy that talk me into "this new technology".
All things being equal; it was my decision so I can't get to hacked off.
(...even though I was content renting the drum sander, having used them before;
...and before the mape that rented it to me started in on his schtick.)
-Scott
tenon0774 is offline
Old 11-08-2014, 10:07 PM   #7
VinylHanger's Avatar
Rewards Points: 11,134
Yeah, we wasted two days and 300 bucks on an orbital/vibrating sander. Useless POS.
VinylHanger is online now
The Following User Says Thank You to VinylHanger For This Useful Post:
tenon0774 (11-09-2014)
Old 11-09-2014, 12:58 AM   #8
Designer/Contractor
Rio's Avatar
Rewards Points: 98
Also, and I'm sure the pros know this but some of us who just get roped into it for one reason or another might not, all drum sanders are definitely not the same.
The local construction rental shop has really nice ones, I think the brand is Silver and we used those for several rentals we were maintaining with no problem and then used a drum sander from another shop that was a different brand as it was closer to the project and it didn't work good at all, spun too fast which gummed the paper and had a tendency to bounce. It was so bad we took it back and got the Silver sander and............. voila, worked like a charm which was a relief as the thought had crossed our minds that the problem was with the finish and not the crummy sander.
Rio is online now
Old 11-09-2014, 08:12 AM   #9
tonyc56's Avatar
Curious how the heck would you lift a 200lb drum sander three flights of stairs even with two guys unless your a body builder...
tonyc56 is offline
Old 11-09-2014, 09:11 AM   #10
ccoffer's Avatar
If you're a grown man who can't carry a hundred pounds, you should get a desk job.
ccoffer is offline
The Following 4 Users Say Thank You to ccoffer For This Useful Post:
jslusher (12-28-2014), Metro M & L (11-09-2014), PrecisionFloors (11-09-2014), tenon0774 (11-09-2014)
Old 11-09-2014, 10:39 AM   #11
Mark122's Avatar
Rewards Points: 464
you saying you and one other guy cant carry 200lbs??? wow our understanding of heavy is VERY different!
Mark122 is offline
Old 11-09-2014, 12:40 PM   #12
I don't care who you are, carrying objects up and down stairs is no easy task, the guy walking backward it's awkward, the guy walking up from the bottom has most of the weight.
Old 11-09-2014, 12:53 PM   #13
tonyc56's Avatar
Exactly...but i guess we have a lot macho men on this board...
tonyc56 is offline
Old 11-09-2014, 12:55 PM   #14
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 66
Ever heard of a 2 wheeled dolly?
Orbitals have their place, but its not in the rough sanding portion of the job.
They good for helping to blend drum lines with edger swirls. They're good for cleaning up edger swirls in tight areas where you can't get a drum.
When I'm sanding a floor, I don't have days to pisss away waiting on an orbital to do what a drum will do in less than a day.
pinwheel is offline
Old 11-09-2014, 12:59 PM   #15
Brother I'm Mr. Wheels, I may have up to 500 if I counted em all.
The Following User Says Thank You to MIKE ANTONETTI For This Useful Post:
pinwheel (11-13-2014)
Old 11-09-2014, 01:00 PM   #16
Mark122's Avatar
Rewards Points: 464
or a lot of kitty men...
Mark122 is offline
Old 11-09-2014, 01:02 PM   #17
tonyc56's Avatar
......lol
tonyc56 is offline
Old 11-09-2014, 01:03 PM   #18
How old are you "Mark"
Old 11-09-2014, 01:09 PM   #19
Mark122's Avatar
Rewards Points: 464
old enough to carry a sander up some stairs...and not puss out and be a beoch about it.
Mark122 is offline
The Following User Says Thank You to Mark122 For This Useful Post:
Old 11-09-2014, 01:14 PM   #20
pinwheel's Avatar
Rewards Points: 66
I'm not Mark, but I' 50 years old & my helper is my 48 year old wife. From the sounds of it, she's tougher than some of the guys in the thread because she's on the other end of the sanders when we gotta take em up stairs. It's usually 2 sanders we're packing in too.
pinwheel is offline
Best flooring option over old 3/4 hardwood floor. Spencer Flooring 61 02-09-2014 09:42 PM
hardwood flooring question pre/unfinish sbrodacz Flooring 23 12-05-2013 05:18 PM
Hardwood Flooring over Hardwood Flooring? Craftmark Flooring 25 10-15-2012 10:39 PM
Orbital sander for use in RRP work. VinylHanger Tools & Equipment 8 10-11-2011 02:59 PM
Hardwood flooring help tthomas Finish Carpentry 0 04-03-2010 06:42 PM
