New Federal Lead Law - Are Floors Guys Affected? - Flooring - Contractor Talk
Old 04-27-2010, 08:31 AM   #1
InterCounty's Avatar
Trade: Hardwood Flooring Contractor
Rewards Points: 896
Does anyone know if the new EPA lead rules that went into law last week will effect hardwood flooring "renovation"?
Supposedly there are huge fines, and there are training seminars for lawyers on how to effectively sue contractors violating this new law.
InterCounty is offline
Old 04-27-2010, 08:52 AM   #2
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Re: New Federal Lead Law - Are Floors Guys Affected?
Very good question!
Well, if we look at the rule, it says for homes with lead paint. I have not seen any mention of stain or clear coatings. So aside from dealing with a painted floor, my take is a typical stained floor does not fall under the RRP rule.
That said, I do believe we should wait for a certified remodeler who took the class to chime in before we go spreading misinformation.
Now that is not to say there isn't lead in these products. Hell, even ceramic tile can contain lead. But as long as these materials aren't include in the RRP guidelines, maybe we can learn something about the spirit of the law. Perhaps a bit of self-policing on the matter will be a good thing. I, for one, will definitely be more aware of how I contain dust during floor demolition.
Angus
angus242 is offline
Old 04-27-2010, 09:00 AM   #3
Rewards Points: 896
We had sanded a 100 yr old painted floor two weeks ago - with respirators on.
...I guess thats the last one we will ever do.
The laws says less then 6 sq feet of painted surface is ok.
So perhaps we can get away with a painted closet floor.
Now for installs Im going to have to add up the length and width of the base molding to see if it goes above six sq.
- or tell the HO to have the base and doors off before I get there.
Old 04-27-2010, 09:54 AM   #4
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Yep, that's the same issue I have....damn baseboards. I guess if I cannot get a HO to agree to the necessary steps of following RRP for baseboards, I'll just have to start being a hack and leave the base in place & tile to them. Add my own shoe.
Angus
angus242 is offline
Old 04-27-2010, 09:57 AM   #5
Flooring Installer
rusty baker's Avatar
Trade: flooring
Rewards Points: 108
As I understand it. It really does not apply to flooring except for removing moldings or refinishing floors that have never been refinished since 1978. Factor in the 6 sq ft rule, it basically will never apply to base moldings either. And if you run into a pre 1978 house, dont remove and reset base, just install shoe molding and you are around that problem.
But you may be required to have the certification.
Painters are a different story. They are definitely required to have the certification, if they paint anythig built before 1978
And some old stains did have lead content, according to a friend who is a painter.
Flooring installer since 1973
Armstrong certified
rusty baker is offline
Old 04-27-2010, 03:32 PM   #6
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 162
Definitions 745.103 (wrong subpart but based on the correct subpart - these terms also apply)
Lead-based paint means paint or other surface coatings that contain lead equal to or in excess of 1.0 milligram per square centimeter or 0.5 percent by weight.
Baseboards are the kicker when it comes to flooring, except for the hacks as mentioned above (carpet guys get off easy - the rest of you, your toast especially if you accidentally demolish a piece of trim)
Ceramic Tile "should be" excluded as it is not a friction surface
Lead-based paint hazard means any condition that causes exposure to lead from lead-contaminated dust, lead-contaminated soil, or lead-contaminated paint that is deteriorated or present in accessible surfaces, friction surfaces, or impact surfaces that would result in adverse human health effects as established by the appropriate Federal agency.
SLSTech is offline
Old 04-30-2010, 12:27 AM   #7
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,484
I just did my first flooring bid after rrp earlier this week. Took the class Monday.
Anyway. Added line items for debris disposal and rrp compliance and cleaning verification. I was turned down. The client said I was 30% higher than everyone else. She said "They said there's no lead in the finish." "Are they going to test for it?" "Uh, I don't know." This lady had previously told me all about how she wants to protect her child from harmful fumes etc... Still came down to price.
RRP requires presumption of the presence of lead unless you can prove that it is not present. I don't want to assume liability for the testing. I know the client won't pay for the testing. So I assume its presence in target housing. You basically have to clean as well or better than required by the reg's for an oil finish anyway.
Metro M & L is offline
Old 05-01-2010, 01:41 PM   #8
Gough's Avatar
Trade: painting
What I'll be doing in similar situation is using the LeadCheck swabs as allowed by the rule (at least until September, when the rule changes) AND taking a sample to my local analytic lab. That sample isn't part of RRP and I just want it for my records should a question ever arise.
Gough is offline
Old 05-01-2010, 10:24 PM   #9
Pro Grade Flooring LLC
Ed4x4's Avatar
Trade: Flooring: Carpet, Wood, Laminate
Rewards Points: 77
Where could I find an official document of this law? I checked around on the EPA's site and couldnt find what I was looking for, only instructions and descriptions of what to look for.
EDIT::: Nevermind, found it.
Carpet, Wood, Laminate, Tile
Ed4x4 is offline
Old 05-01-2010, 10:30 PM   #10
frankster's Avatar
Rewards Points: 75
Compliance guide--great summary of how to determine if this rule applies to you: http://epa.gov/lead/pubs/sbcomplianceguide.pdf
frankster is offline
Old 05-02-2010, 10:36 AM   #11
Sean
SLSTech's Avatar
Rewards Points: 162
Be careful following any "published" book, webpage or advice - most are outdated and do not protect you from not following the regulation.
The official regulation is found on the E-CFR site (link to full regulation)
SLSTech is offline
Old 05-20-2010, 08:41 PM   #12
Willy is's Avatar
Trade: residential restoration
Rewards Points: 250
My understanding is that the federal rules are the minimum. I am from Iowa and due to increased amount of lead here the state opted for more stringent limits than the federal.
You have to be careful what you accept as fact; some info could be old, some could differ regionally.
Willy
Willy is is offline
Old 05-20-2010, 09:47 PM   #13
primetimeon's Avatar
Trade: general contractor
Rewards Points: 75
I got my certification without even taking a course. I filled out the form from the epa paid my $300 and got my cert. They did not even ask if I took a class.
primetimeon is offline
Old 05-20-2010, 09:53 PM   #14
Jaf's Avatar
Trade: Builder
Rewards Points: 250
To the OP, They did use lead in clear finishes back in the day. I was told in my class that clear finishes fall under the RRP laws.
To Primetimeon. Any company or individual can get the cert from the federal government for $300. Problem is, you need someone who took the class, to do the work. So, your not out of the woods, yet.
Jaf is offline
Old 05-20-2010, 09:55 PM   #15
Wood Butcher
bhock's Avatar
Trade: Remodels/Custom Cabinets/Granite Countertops
From my understanding you can get a cert. from epa without the classs but you still need to take the class.
bhock is offline
Old 05-20-2010, 10:27 PM   #16
Rewards Points: 75
How do they prove you took the class? All EPA shows is the cert. If the state checks all they will see is no cert or you have a cert.
Old 05-21-2010, 06:19 AM   #17
Jaf's Avatar
Trade: Builder
Rewards Points: 250
The principle owner of the business only needs the cert. But when your disturbing the paint, there has to be a trained (took the class) person on site. When you take the class they issue an I.D. that says you completed the class. Someone needs to have this on them, when your doing the work.
Also, if no one took the class, it may be obvious anyway. Since in theory, you'd have little idea on what needs to be done.... no?
Your half-way in, might as well go the whole way. The cert isn't going to cover you by itself.
Jaf is offline
Old 05-21-2010, 07:37 AM   #18
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 144
I just wanna know where there gonna find the money to pay all the big brother epa police to enforce every remodel job across the country? Everyone know's were bordering on bankruptcy already.
pinwheel is offline
The Following User Says Thank You to pinwheel For This Useful Post:
PrecisionFloors (05-21-2010)
Old 05-22-2010, 12:34 PM   #19
KG007's Avatar
Trade: Flooring & cabinetry
Rewards Points: 268
I took the course last week and just took a break from writing my company policy on how we are going to approach this. i'll try to bullet point the highlights.
1. This is an extremely onerous regulation on potentially ANYONE who does work for hire inside or outside any house built pre 1/1/1978. Potential fines are enormous for the residential contractor and the regulation is like using a steamroller to kill an ant, IMO.
2. To do work in lead paint environment, you must be a certified firm. to be a certified firm you pay a fee and register with EPA. I think it is $350. You do NOT have to be a certified person for the company to be certified, just pay the extortion to the government. HOWEVER, to be in compliance, you must have at least one certified person and all persons, employees or subs, on the site must receive training if they are not certified themselves.
3. Any house or residential dwelling built prior to 1/1/78 is automatically considered to have lead paint UNLESS proven otherwise. The testing has to be done by a certified person (more extortion money to take the class).
4. Exclusions are for a) areas that don't contain lead paint (i.e., rooms that don't) {which means you have to test each room}, b) energency renovations, c) minor repairs and maintenance, d) renovations performed by the homeowner.
5. "Minor" means interior work disturbing less than 6 sq ft of painted surface per room, or < 20 SF on exteriors.
6. The "opt out rule" supposedly goes away 7/26/2010 and there will be no exceptions.
7. The opt out rule is for those who meet all criteria of: a) the owner lives in the house, b) no child under 6 resides in the hose, c) no pregnant woman lives in the house, d) no child-occupied facility exists on the property, and d) the owner signs a written opt out.
8. Lead was used in some old varnishes and stains, so I'm told.
9. You must provide the owner (and residents if rental or common areas) with the EPA pamphlet "Renovat Right" not more than 60 days in advance of starting work. They have to sign for it, or if not you have to send it certified/return receipt at least 7 days in advance. (Rentals, apartment buildings, etc., you have to get this to everyone with written proof of doing so.)
My personal reading of this means flooring only would not fall under this IF painted surfaces over 6 SF are not disturbed, i.e., no baseboard removal, and hope the shoemold is not over a collective 6 SF, and any sanding is not of a floor with lead on it. IF you stir up dust in any way you are screwed - the trainer on this claims "the lead dust migrates thru drywall or plaster and is absorbed into the wood framing members, and will go thru floors, so if there is another dwelling below you have to warn them, get the pamphlet to them, make sure there are no kids or pregnant women, etc." Thus plastic to contain the dust.
So, if you create dust taking up old flooring, a jerk inspector can potentially claim you are stirring up lead dust and stick you. This COULD include carpet take-up, since carpet gets dusty and they can claim it is contaminated. YOU have to prove otherwise if they want to be jerks. To get old flooring out you supposedly have to encapsulate it in plastic, use a HEPA vac to clean it off, and somehow get it out without "containimation" of other rooms. Standards on HEPA vacs, respirators, tools you can use (no power tools without HEPA filters), how you have to fully suit up, clean up, etc.
LOTS and LOTS of extensive crap on exactly how you have to set up work sites, clean up, signs for restricted area, homeowner cannot be in work areas unless accompanied by a certified person AND fully suited up, etc. You need to take the course to learn all of it. Have to have plastic on the floors, etc. Doesn't matter if it is stupid or the opposite of what OHSA says, we are the ones who get ****ed.
HUD applicable house is WORSE.
My policy, written today, says we add a line item for $8 for ALL jobs for regulatory burden; will not accept any HUD job period; have a lead testing charge for all pre-1978 jobs of $24 for 1-3 tests, $48 for 4-6 tests, etc. (You may have to do a dozen or more tests in a big job. All "dissimiilar" surfaces have to be tested and one positive makes it all a lead job.) I now requre an opt out or we may not do the job. I estimate cost can add 5% on the simplest job, double the cost or more of some jobs.
How many people are interested in starting a campaign to get Congress to rein in EPA? (Assuming they listen to anything other than themselves talk.)
KG007 is offline
Old 05-22-2010, 12:51 PM   #20
Gough's Avatar
Trade: painting
In your application, did you notice the part where you had to attest that you will only employ "appropriately certified individuals"? Part of the documentation that you must have includes not only the firm certification, but also the certification of the indivudual who took the RRP class.
Gough is offline
EPA Lead Based Paint Certification Training THIS MONTH--Indianapolis ChrWright General Discussion 14 11-16-2011 05:36 PM
Hud announces $13 million in grants to protect kids from lead paint Brickie General Discussion 22 05-15-2010 02:09 PM
April EPA Lead Rule Question flatlander745 Health & Safety 5 05-13-2010 01:48 PM
Is there any Online lead that allow you to preview the lead before buying? Leonardorribeio General Discussion 0 03-15-2010 09:03 AM
Lead with a great budget Five Star General Discussion 9 02-26-2009 12:29 PM
