Need Help Asap. Hardwood Over Concrete - Flooring - Contractor Talk
Old 02-11-2019, 03:16 PM   #1
Shaggyman89's Avatar
Trade: Renovations/Flooring
Rewards Points: 6
we are installing hardwood over concrete subfloor. The hardwood is separating when we are gluing it down even though we are taping it. What do we need to do so it doesn't separate while we are installing the hardwood?
It's 3/4 inch Hardwood by 3 &1/2
Shaggyman89 is offline
Old 02-11-2019, 03:32 PM   #2
Ed Hartmann's Avatar
Rewards Points: 214
Re: Need Help Asap. Hardwood Over Concrete
Not the kind of thing you should be trying to do if you don't know what you are doing.
Ed Hartmann is offline
Old 02-11-2019, 05:13 PM   #3
Rewards Points: 6
Thanks Ed, now do you have a solution or are you just sticking your nose into something it doesn't belong?
I'm a general contractor that has run into a problem. No I am not a master of every trade that my employees do. But I also don't go around posting stuff to pretend I'm smart.
Old 02-11-2019, 05:31 PM   #4
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 13,525
Did that once. We installed in stages, bracing it against the far wall with some perpendicular boards.
MarkJames is offline
TheConstruct (02-11-2019)
Old 02-11-2019, 05:36 PM   #5
Rewards Points: 6
Thanks Mark, yeah that's something I was sort of pondering. If I remember correctly that room is like a 18 ft long though.
Do you remember why it was not just staying in place? Where the tongue and groove just not tight enough?
Old 02-11-2019, 05:38 PM   #6
Rewards Points: 6
I'm going to the job site to see for myself, just wanted to have some insight and hopefully get a game plan together before I get there.
Old 02-11-2019, 05:38 PM   #7
Rewards Points: 6
18' wide
Old 02-11-2019, 05:42 PM   #8
MarkJames's Avatar
Not the straightest boards, as I recall. So snugging one end pushed out the other.
Old 02-11-2019, 06:16 PM   #9
Texas Wax's Avatar
Rewards Points: 1,662
Hardwood?
Helps if you're more specific, prefinished/engineered or unfinished raw wood?
...as the page loads, so go the days of our lives, at CT
Texas Wax is offline
Old 02-11-2019, 08:08 PM   #10
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,335
Lighten up, man. He's actually giving you good advice.
Hardwood flooring is somewhat of a specialty, not something normally all that well done by "generalists". We don't know you. Nice introduction.
Tinstaafl is online now
The Following 4 Users Say Thank You to Tinstaafl For This Useful Post:
dprimc (04-05-2019), pinwheel (02-11-2019), rselectric1 (02-15-2019), TNTRenovate (02-12-2019)
Old 02-11-2019, 08:17 PM   #11
Hack
asevereid's Avatar
Rewards Points: 354
Did you seal the concrete at all before placing the flooring?
What kind of glue?
Maybe too much glue was applied and it's swelling the material a bit?
Sent from my SM-G903W using Tapatalk
How to figure your pricing:
http://goo.gl/Il8c2
L+M+O+P/ Pricing, Estimating, And Success
Charging tree fiddy per lineal BOB
asevereid is offline
The Following 2 Users Say Thank You to asevereid For This Useful Post:
Fouthgeneration (02-12-2019), overanalyze (02-11-2019)
Old 02-11-2019, 08:29 PM   #12
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 676
Lets get a few more details before I give you any input. I've laid quite a bit of hardwood over concrete.
What glue are you using? Is it wet lay, or let skin then lay? Are you laying it tongue towards glue, or grove towards glue? Are you laying above grade, or basement?
pinwheel is online now
The Following 4 Users Say Thank You to pinwheel For This Useful Post:
asevereid (02-11-2019), BlueRidgeGreen (02-18-2019), overanalyze (02-11-2019), TNTRenovate (02-12-2019)
Old 02-11-2019, 09:27 PM   #13
Rewards Points: 6
First off sorry I got snappy.
If someone has advice im VERY appreciative, but to assume I dont have any experience and to just comment on that point alone without a solution is arrogant and ignorant which I have time for neither.
My lead installer is experienced but not as much in concrete installation.I wasnt there when he "started"( all boards were pulled back up) so wasnt able to assess the situation in person.
It is above grade, did not seal it.
We are using bostic duragrip.
We are doing a wet lay.
What does it mean to have the tongue or groove toward the glue? And which should I do in this situation?
We have done it before many times with no problems but he said it just would not. stay together and there were small separation gaps.
Old 02-11-2019, 09:29 PM   #14
Rewards Points: 6
Nah man I didnt seal it. Possible he used too much but he used the size trowel listed on the bucket for our size hardwood.
Old 02-11-2019, 10:05 PM   #15
pinwheel's Avatar
Rewards Points: 676
Wet lay is incredibly hard to get tight & stay tight. Prefinish, or site sand? Always lay wet lay backwards. Push the tongue into the groove instead of conventional, otherwise you'll be plowing glue into the groove & never get it tight.
Prefinish, tape is your only real way to keep joints closed & don't be wallering around on flooring that's already laid. Never lay more than 2' at a time without securly anchoring the laid flooring. I prefer to lay 2' & get it tight & let the glue set before going further, otherwise you'll waller it out of position. If you don't have a long reach hardwood floor jack, get one so you can push the flooring tight together. If the floor is site sand, get it tight & lay scraps perpendicular & screw them down to hold the floor tight so you can keep laying beyond 2' at a time. The screw holes can be filled when you put down your trowlable filler.
One more thing, if you don't have a commercial hot glue gun like a pam tite, get one. Use hot glue & floor glue on the starter plank. Lay it the day before you want to start laying so you have a good first course anchor. You can also use the hot glue on the last course of your 2' run to anchor the wet laid progress till the glue sets. Glue down floor is not a money maker by the sq ft, it's really hard to make good time.
Keep asking questions, I'll answer them if I can.
The Following 10 Users Say Thank You to pinwheel For This Useful Post:
asevereid (02-11-2019), BlueRidgeGreen (02-18-2019), dprimc (04-05-2019), Frank Castle (02-12-2019), MarkJames (02-11-2019), onmywayup (02-16-2019), overanalyze (02-11-2019), tgeb (02-12-2019), TheConstruct (02-11-2019), Xtrememtnbiker (02-11-2019)
Old 02-11-2019, 10:13 PM   #16
Rewards Points: 6
Thanks! Great info!. So how long should I let it "skin" before I install the boards.
And yeah its prefinished, I'll get some stronger tape tomm. Normally use the blue I'll get some frog tape.
Old 02-11-2019, 10:19 PM   #17
pinwheel's Avatar
Rewards Points: 676
Blue tape is sufficient, don't be stingy with it & don't be wallering the flooring on wet glue. I haven't used the glue you're using, so what's the label say about laying into a skin coat? I know Bosticks best can be laid wet or skined. I prefered to lay into a skin because it didn't slip around as much.
Old 02-11-2019, 10:23 PM   #18
Rewards Points: 6
I'll have to check it when I get there tomorrow. Again thank you for your advice.
The Following User Says Thank You to Shaggyman89 For This Useful Post:
Old 02-11-2019, 10:24 PM   #19
Hack
asevereid's Avatar
Rewards Points: 354
Pin, you're awesome
http://goo.gl/Il8c2
The Following 8 Users Say Thank You to asevereid For This Useful Post:
BlueRidgeGreen (02-18-2019), Fouthgeneration (02-12-2019), Frank Castle (02-12-2019), onmywayup (02-16-2019), overanalyze (02-11-2019), pinwheel (02-11-2019), TheConstruct (02-11-2019), Xtrememtnbiker (02-11-2019)
Old 02-11-2019, 10:50 PM   #20
Rewards Points: 214
Its not to pretend I'm smart. I live by it. I sub out what I am not excellent at. I have plenty of work, I make money off my subs, and I care about my reputation. If you want to run your mouth about my feedback how about a picture of this "professional" install
Novice question - hardwood flooring and exterior threshold furlong General Discussion 29 08-15-2015 08:57 AM
Sealing Stamped Concrete Bill Butler Masonry 1 06-02-2013 04:51 PM
Concrete footing removal 18withtools Demolition 19 01-29-2013 07:34 PM
hardwood over concrete methods. Rich D. Flooring 17 11-05-2011 03:06 PM
Polished concrete.. is it better than Hardwood ? AcademyHardwood Flooring 33 04-27-2011 12:29 PM
