Need To Bring Down Mc ASAP - Flooring - Contractor Talk
Old 12-28-2018, 03:06 PM   #1
Brenin's Avatar
Trade: Builder
Rewards Points: 8
I need to install some maple flooring that a homeowner purchased. It was milled up locally about ten years ago and was stored in a storage unit until about four weeks ago. It’s been in the heated home with fans and a dehumidifier and is stuck around 12% while the subfloor is 6%. Is there any way to speed things up or some fancy underlayment I don’t know about? The flooring is variable width. About 1000 sq ft
Brenin is offline
Old 12-28-2018, 05:22 PM   #2
WBailey1041's Avatar
Trade: Gutters
Rewards Points: 1,569
Re: Need To Bring Down Mc ASAP
Time is your friend unless you want it to warp or crack. Is it still in the package? Is it wrapped in plastic? How is stacked? Have you checked the moisture of other hardwoods in the room? If they have actual hardwood trim or casing or baseboards check that then report back. Also, I would be hesitant to use a dehumidifier.
Is the local mill still operating? You might give them a call and see if they’ll run it through their kiln again.
WBailey1041 is offline
Old 12-29-2018, 11:09 AM   #3
Brenin's Avatar
Trade: Builder
Rewards Points: 8
Thanks, it was just banded, not wrapped. I popped the bands on Thursday and stickered it. The trim and paneling in the house is poplar and redwood, both reading similar to the flooring actually. Unfortunately the mill closed a while back.
Brenin is offline
Looking for best solution to bring water into New Garage Big_Ben Plumbing 4 09-16-2014 09:03 PM
drywall subs needed ASAP estimating2013 Help Wanted or Looking For Work 4 04-27-2013 06:46 PM
White wood on deck?? Jcstorm Decks & Fencing 6 01-30-2013 12:15 PM
