Minwax Water Based For Stairs - Flooring - Contractor Talk
Old 05-07-2019, 10:59 AM   #1
rblakes1's Avatar
Rewards Points: 3,118
I'm going to be doing a set of tread caps in the next few weeks and had SW color match the laminate flooring that goes up to the stair case. I had them use the water base since I plan on finishing them before install. What I didn't realize is that minwax doesn't recommend water based for floors.
From what I read, the recommendation against water based is due to drying times and large areas. Since I'll be doing treads 1 or 2 at a time, does that negate the issue?
I was planning on top coating with Bona mega. 1-2 coats prior, final after install.
-Rich
rblakes1 is offline
Old 05-07-2019, 02:37 PM   #2
rservices's Avatar
Rewards Points: 376
Re: Minwax Water Based For Stairs
The waterbased poly's are a little faster, but a regular poly will look better and last longer.
rservices is offline
Old 05-08-2019, 10:45 AM   #3
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 1,319
Save yourself a headache. DO TEST SAMPLES FIRST. Have customer approve, cut sample in half, and you both sign each. CYA
rescraft is offline
The Following User Says Thank You to rescraft For This Useful Post:
rblakes1 (05-08-2019)
Old 05-08-2019, 03:27 PM   #4
tjbnwi's Avatar
Rewards Points: 3,452
This or get some Bona water based.
https://www.minwax.com/wood-products...ane-for-floors
https://www.bona.com/en-US/Bona-Prof...s-and-Sealers/
You can also use Zar Ultra Max.
tjbnwi is offline
rblakes1 (05-08-2019), rrk (05-08-2019)
Old 05-08-2019, 08:20 PM   #5
rrk's Avatar
Rewards Points: 1,626
Bona is good stuff
rrk is offline
Old 05-08-2019, 08:44 PM   #6
rblakes1's Avatar
Already have their approval on the stain color and sheen (satin)
-Rich
rblakes1 is offline
Old 05-08-2019, 08:48 PM   #7
rblakes1's Avatar
I was looking at the minwax when I was at SW.
For Bona i was planning on using Mega since it's not a 2 part and I'll only be going over roughly 60 sf times the number of coats
-Rich
rblakes1 is offline
trouble shooting water heater Tom M Plumbing 9 02-14-2016 10:12 AM
Bagged premixed lime mortar for tuckpointing wazez Masonry 158 10-28-2012 07:02 PM
Painting over oil based with water based ~Sparky~ Painting & Finish Work 6 10-07-2011 05:49 AM
Zar Water Based Poly-Pin Sized Bubbles- Dont Know Why??? UPDATE-PROBLEM SOLVED Spencer Painting & Finish Work 0 08-24-2011 07:40 PM
green acid stains + water based epoxy user50444 Flooring 7 08-10-2009 03:05 PM
