Micro Fiber Concrete - Flooring - Contractor Talk
Old 11-07-2011, 08:52 PM   #1
go do it's Avatar
Trade: general contracting
Rewards Points: 258
our concrete contractor wants to use "micro fiber" in a slab that will have a polished concrete floor.
i am against the idea and insisting on the good old welded wire for reinforcement.
does anyone have any experience with micro fibers and polished floors?
go do it is offline
Old 11-07-2011, 09:01 PM   #2
cleveman's Avatar
Trade: custom home building
Rewards Points: 2,624
Re: Micro Fiber Concrete
My supplier got some smaller fiber in about 2005. I can hardly see it anymore, but it is more difficult to finish. I remember I had normal concrete once and I thought I was a helluva good finisher.
Just ask a supplier to point you to a job where the fiber stuff was used on a polished floor.
cleveman is offline
Old 11-08-2011, 12:30 AM   #3
go do it's Avatar
Rewards Points: 258
thanks i really don't want to end up with a fuzzy floor!
go do it is offline
Old 11-08-2011, 12:34 AM   #4
Fire up the BBQ
griz's Avatar
Rewards Points: 388
If you polish it , it won't be fuzzy...
Give up on the welded wire...ends up not doing anything.
Go rebar, on a grid, on dobies....
Ask your Concrete Contractor and/or supplier for examples.
griz is online now
Old 11-08-2011, 07:16 AM   #5
stonecutter's Avatar
Trade: Stonemasonry
Rewards Points: 2,356
It is commonly used for concrete counter tops and they are usually polished.
www.thewoodfiredenthusiast.com
stonecutter is offline
The Following User Says Thank You to stonecutter For This Useful Post:
Metro M & L (11-08-2011)
Old 11-08-2011, 09:05 AM   #6
DavidC
DavidC's Avatar
Rewards Points: 2,006
Yup, we put them in our counter tops. I see some fuzzing on the edges when the form is removed but it does grind or polish right off. Our current job is not being ground to expose the aggregate but does get a polishing and has no hair growing out of it.
The fibers we use are PVA and intended to help increase tensile strength and reduce cracking.
I'm of the opinion that they should not be used to solely replace steel reinforcement. We use both steel mesh and fibers in our counter tops.
Good Luck
www.CookContractingLLC.com
DavidC is offline
Old 11-08-2011, 09:10 PM   #7
go do it's Avatar
Rewards Points: 258
thanks for the reply's
we will have radiant heat in the slab so we will have welded wire anyway
and now i will add micro fiber to boot
we will be adding a plasticiser to reduce the water content because we have a 6mil vapor barrier. hopefully the plasticiser will help to reduce cracks.
any more crack reducing options?
go do it is offline
Old 11-08-2011, 09:29 PM   #8
Trade: Stonemasonry
Make sure you properly prep and compact your subgrade. This is probably more important than what mix design you use for the concrete because a bad base will cause the best poured slabs to crack.
Old 11-08-2011, 09:30 PM   #9
cleveman's Avatar
slow cure
cleveman is offline
The Following 2 Users Say Thank You to cleveman For This Useful Post:
CrpntrFrk (11-08-2011), DavidC (11-09-2011)
Old 11-09-2011, 03:56 PM   #10
go do it's Avatar
Rewards Points: 258
10/4 on the compacted slab
i had planned to be very vigilant during this phase
go do it is offline
Raised concrete deck Bearded Wonder Construction 10 12-07-2011 02:09 PM
I need a fence post mounted on a concrete pad. JT Wood Decks & Fencing 23 10-06-2011 11:42 PM
Recommendation on changing concrete color with breathable product? RDBD Specialty Coatings 0 06-07-2011 08:57 AM
Advice - concrete Pool Deck coping ejleonard Masonry 4 06-17-2008 04:18 PM
