Laminate Over Pex - Flooring - Contractor Talk
Laminate Over Pex
Old 06-24-2019, 08:43 AM   #1
GothamTile's Avatar
Trade: Tile
Rewards Points: 4
Laminate Over Pex
Good Day all, new member first time post.
I have a client who has installed 1/2" PEX heat in their kitchen and wants to install lifeproof LVT floating floor over it. What is the best way to encase the PEX that works best with the flooring type?
I have encased PEX a hundred times in a mortar bed and then installed tile over it, but never LVT. I know that the mortar beds have a semi-loose surface (you can scratch it with your fingernail and it's like sand) so I am worried that you will hear crackling under your feet as you walk on a floating floor. Any ideas? Suggestions?
GothamTile is offline
Old 06-24-2019, 05:19 PM   #2
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 6,474
Re: Laminate Over Pex
Gypcrete or SLC would be great but expensive.
Some simply use plywood but you lose a lot of heat transfer.
You could do your mortar bed and then scratch coat it with something more solid, or pour 1/8" of SLC over it to smooth it out.
Golden view is offline
Old 06-26-2019, 11:19 AM   #3
GothamTile's Avatar
Trade: Tile
Rewards Points: 4
The customer is now asking if there is a concrete mix that they can purchase at home depot (cost effective), mix with water and pour over the PEX. Now I would imagine the most expensive way to pour is with a self leveler such as Henry 565, but can we use regular Quikrete or Sakrete? And if so, which one do you recommend that is cost effective, and will have a good heat transfer?
