Laminate Floor Question.... - Flooring - Contractor Talk
Old 09-12-2018, 11:30 AM   #1
Radical Basement Dweller
Robie's Avatar
Rewards Points: 5,486
Good customers of mine have had their 1st floor flooded 3 times in the past year. The last was yesterday after the creek flooded and came in the house.
It's a hallway, bedroom and 'game room"...all concrete slab.
The last time it happened, after everything was repaired/replaced, etc, etc...they had vinyl plank put down...specifically...
Mannington Vinyl Plank
Margate Oak Waterfront (how fitting)
Laminate Rigid Click
Aquabarb paper under the floor and on top of the concrete.
I'm putting in an industrial dehumidifier today. They were busy last night with vacuums, mops and squeegees.
My question... can this product be taken up...dried out and be re-installed with new paper after everything also gets dried out?
Thanks.
Immigration is not supposed to change the character of the nation.
Immigration is supposed to change the character of the immigrant.
Robie is online now
Old 09-12-2018, 11:44 AM   #2
Frank Castle's Avatar
Rewards Points: 424
Re: Laminate Floor Question....
I think the edges will curl.
If this is the third time it's flooded, I would acid stain the concrete and take the flooring problem out of the equation for next time.
Just my .02
Adapt, Improvise, Overcome.
Frank Castle is offline
The Following 2 Users Say Thank You to Frank Castle For This Useful Post:
Robie (09-12-2018), TheConstruct (01-31-2019)
Old 09-12-2018, 11:48 AM   #3
Robie's Avatar
Just my .02
House has been there 40+ years...never a flooding problem until lately.
They have messed with culverts upstream and this is the result.
This is going to end with attorneys, city and county engineers and all that goes along with that combination.
Robie is online now
Frank Castle (09-12-2018)
Old 09-12-2018, 12:16 PM   #4
Fire up the BBQ
griz's Avatar
Rewards Points: 1,138
Thanks.
Your post is somewhat confusing.
Is it vinyl plank or laminate?
It can be taken up, whether it will cooperate and allow for a decent
re-install is another question.
griz is offline
Robie (09-12-2018)
Old 09-12-2018, 12:25 PM   #5
Robie's Avatar
She had a leftover box stored.
I dunno. She texted me with what she said the box read.
The website says:
Margate Oak A refined, reclaimed wood visual, Margate Oak's detailed graining makes this luxury vinyl plank floor a must for any interior that coverts modern rustic elegance. A sensible floor with a brilliant design, this surface is as durable and functional as its beauty.
I'll take a look when I get there.
Robie is online now
Old 09-12-2018, 12:29 PM   #6
Fire up the BBQ
griz's Avatar
LVP should not be effected by water.
with a little luck & gentle persuasion at demo pretty good odds it will go back together ok.....maybe.....sorta....
griz is offline
The Following 2 Users Say Thank You to griz For This Useful Post:
Old 09-12-2018, 12:54 PM   #7
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 1,005
What is the cost trade-off of removing, drying, cleaning and reinstalling the existing, instead of dumping the old and putting in new----labor vs material cost.
Just a thought.
rescraft is offline
The Following 3 Users Say Thank You to rescraft For This Useful Post:
Robie (09-12-2018), TheConstruct (01-31-2019), Xtrememtnbiker (09-12-2018)
Old 09-12-2018, 02:49 PM   #8
avenge's Avatar
Rewards Points: 420
With vinyl plank what I'd be concerned with if it locks back together properly once it's been taken apart. I have issues with the ends not always locking together even when new.
avenge is offline
The Following 2 Users Say Thank You to avenge For This Useful Post:
Old 01-12-2019, 06:18 PM   #9
FloorFreak's Avatar
Trade: Flooring
Rewards Points: 18
This, vinyl is plastic... relatively impervious to moisture. If you're gentle, you should be fine but you'll likely need a few extra boxes.
FloorFreak is offline
Old 01-31-2019, 08:53 PM   #10
Zen life's Avatar
Trade: c54 & c6
Rewards Points: 18
10%-20% more
obey the nature of things and you will walk freely and undisturbed - https://www.choicegraniteinc.com
Zen life is offline
Old 01-31-2019, 09:15 PM   #11
TheConstruct's Avatar
Rewards Points: 720
Despite being non porous, I think the right course of action with grey water would be to clean the planks with an antimicrobial solution before reinstalling. The labour of gentle demo and cleaning sounds to me like it might out weigh going new, as was mentioned above.
TheConstruct is online now
Unconventional Request: Re: Laminate Stair Nosing Jack Dobson Flooring 9 08-28-2015 04:54 PM
Laminate to tile back splash nwksremodeler Kitchens & Baths 2 10-29-2012 01:10 PM
vapor barrier and laminate with pad attached bluebird5 Flooring 9 07-14-2012 07:28 PM
Need one box of Easylock II or Swiftlock Red Cherry laminate flooring. Ethos Flooring 1 06-04-2012 03:01 PM
best blade for cutting laminate platinumLLC Flooring 12 05-07-2009 10:12 PM
