Knife Marks On Trim - Flooring - Contractor Talk
Knife Marks On Trim
Old 07-12-2012, 06:09 AM   #1
Paintpimp's Avatar
Trade: Paint
Rewards Points: 75
Knife Marks On Trim
A little introduction, I'm a paint rep for a large paint company.
A builder of mine paints his trim and then has the carpeting installed. After the install he has to repaint all the trim again. The knives the layers are using leaves metallic or black marks on the trim and doesnt come off.
Is there a knife brand out there that doesnt do this?
They've tried duct tape on the knife to create a barrier and this left marks too, they were going to try tyvek tape next.
Is it a procedure error on the layers part?
Is it my paints fault?
Is it just part of life and needs to be redone each time?
Thanks for your help.
Paintpimp is offline
Old 07-12-2012, 06:13 AM   #2
summithomeinc's Avatar
Trade: Painter/Handyman
Rewards Points: 2,422
Re: Knife Marks On Trim
Get new installers. If it was all stained trim would they be beating it up with their tools? If they did they would be buying it. Lazy or inept installers is the issue.
I need more tools.
summithomeinc is offline
The Following 4 Users Say Thank You to summithomeinc For This Useful Post:
hdavis (07-12-2012), J M J (08-01-2012), MALCO.New.York (07-16-2012), Paintpimp (07-13-2012)
Old 07-12-2012, 06:31 AM   #3
r4r&r's Avatar
Trade: Contractor
Yep agree. I haven't done any serious carpet work in over 20 years I can install without damaging trim finish. Also I would be back charging the hell out of those installers as well.
r4r&r is offline
The Following 3 Users Say Thank You to r4r&r For This Useful Post:
donerightwyo (07-12-2012), hdavis (07-12-2012), Paintpimp (07-13-2012)
Old 07-12-2012, 06:45 AM   #4
Flooring Installer
rusty baker's Avatar
Trade: flooring
Rewards Points: 110
Yep, get new installers or teach these guys how to trim. A trimmer would work wonders. The installers are just laying their knife sideways and cutting against the trim. Wrong, wrong, wrong.
Flooring installer since 1973
Armstrong certified
rusty baker is offline
The Following User Says Thank You to rusty baker For This Useful Post:
Old 07-12-2012, 06:48 AM   #5
Groutface
Groutface's Avatar
Trade: flooring installer
Rewards Points: 524
Picture would be good but,definitely installer fault.....sounds more like a electric stapler too close to trim ehil stapling.......but they shouldn't be stapling anyway,unless its steps and stringers or upholstering something......
Groutface is offline
Old 07-12-2012, 07:01 AM   #6
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
ditto on the installers technique..
Just a side note though, blue painters tape on my saw base will protect most surfaces.
-Steve
TimelessQuality is offline
The Following 2 Users Say Thank You to TimelessQuality For This Useful Post:
Paintpimp (07-13-2012), We Fix Houses (07-12-2012)
Old 07-12-2012, 10:53 AM   #7
hdavis's Avatar
Rewards Points: 1,072
If I'm concerned I may damage trim on an install, I have a few small pieces of 1/8" hard board I can place as I go.
Could be the stretcher they're using, but there is still no excuse..
hdavis is online now
HollywoodFloors (07-17-2012), Paintpimp (07-13-2012)
Old 07-12-2012, 11:11 AM   #8
r4r&r's Avatar
Trade: Contractor
My guess is they use a stair tool to tuck around perimeter. They could spend a few bucks on a proper tool for that, hell the GC would probably pay for it if he didn't have to repaint base again.
r4r&r is offline
The Following User Says Thank You to r4r&r For This Useful Post:
Old 07-12-2012, 01:30 PM   #9
Groutface
Groutface's Avatar
Rewards Points: 524
I use stair tool........you use banana knife? I know the guy who trained me uses banana knife.......still being pretty careless if stair tool is used.....thumbsup
Old 07-12-2012, 01:36 PM   #10
donerightwyo's Avatar
Trade: custom builder
Rewards Points: 138
My bet is their wall trimmer has lost its plastic on the runner. There's no way to fix it but by a new one and keep it clean. Any tape just wears through and makes a bigger mess eventually.
donerightwyo is online now
The Following 2 Users Say Thank You to donerightwyo For This Useful Post:
Paintpimp (07-13-2012), Railman (07-17-2012)
Old 07-12-2012, 02:13 PM   #11
r4r&r's Avatar
Trade: Contractor
Depends on how you use the stair tool and how right tack strip is to the wall and base to floor. If you are just slamming it down with your hand u can damage the base pretty good. If you're using a mallet then shouldn't do anything. If the base is high enough just run it flat with the corner stuffing the carpet under the trim. Either way how hard is it to see you're trashing the base and figure it out and don't do it that way.
Most of my carpet days were relays from water damage. Done a little new install but not much.
r4r&r is offline
The Following 2 Users Say Thank You to r4r&r For This Useful Post:
Groutface (07-12-2012), Paintpimp (07-13-2012)
Old 07-12-2012, 06:23 PM   #12
Flooring Installer
Trade: flooring
Rewards Points: 110
If it is a black scratch, they are probably laying a razor knife on it's side and cutting against the base. It will leave a scratch that looks like a black line all the way down the base from one end to the other. 40 years in this business and have seen many installers trim that way. They don't know if you are going to hand trim, bend the carpet over and cut from the back side.
Armstrong certified
Old 07-12-2012, 07:04 PM   #13
Groutface
Groutface's Avatar
Rewards Points: 524
That's crazy......y use the base.......greenhorns......laughing.......5 different ways u could do it without ****in up.......sad
Old 07-12-2012, 10:45 PM   #14
bconley's Avatar
Trade: Kitchen and bath design+remodel
I mask off the base with cardboard before the carpet installers get there, just the rough backing of the carpet scraping against the baseboards ruins the paint.
Its a pain but less of a pain repainting and worrying about back charges.
bconley is offline
The Following User Says Thank You to bconley For This Useful Post:
Old 07-13-2012, 06:17 AM   #15
Paintpimp's Avatar
Trade: Paint
Rewards Points: 75
I don't have a picture. It's definetly a metallic/gray look. Sounds like its a technique and craftsmanship issue. Next house I'll take a picture and post it to this thread and gather your responses. You guys are great thanks again!
The Following User Says Thank You to Paintpimp For This Useful Post:
Groutface (07-13-2012)
Old 07-16-2012, 11:00 PM   #16
Handle It!
MALCO.New.York's Avatar
Rewards Points: 2,000
Musta got lost in Translation...
Ultimate Wisdom---------
MALCO.New.York is offline
Old 07-17-2012, 06:21 AM   #17
Allfloorremoval's Avatar
Trade: Flooring
Two weeks a helper then "poof" the think they are mechanics!!!!
Allfloorremoval is offline
Old 07-17-2012, 11:35 AM   #18
Railman's Avatar
Trade: Railing
Rewards Points: 1,157
When I asked a good installer what causes this, he said the same thing. The edge trimmer, or whatever it's called, has worn out plastic protector. Once it's worn out, it's metal on paint.
Joe
Railman is offline
Old 07-17-2012, 12:03 PM   #19
Flooring Installer
Trade: flooring
Rewards Points: 110
Joe
That's possible, but I have a trimmer I have used since 1983. It came out without a plastic on the edge and has never left marks.
Armstrong certified
Old 07-17-2012, 04:22 PM   #20
Groutface
Groutface's Avatar
Rewards Points: 524
My Roberts gt has no plastic either.....thumbsup
Another Azek trim ? (Lone) redwood Carpentry 26 03-08-2015 03:12 PM
Trim carpenter to Trim contractor, pros and cons ? GregThCarpenter General Discussion 26 05-17-2012 08:36 PM
Installing new floors, with old trim Scoots Flooring 31 03-29-2012 03:02 PM
Funny Craigslist ad for paint work... Splinter Painting & Finish Work 14 06-10-2009 05:43 AM
Custom Trim jfrench General Discussion 11 04-12-2009 08:44 PM
