I Did Something Terrible.. - Flooring - Contractor Talk
Old 10-05-2018, 02:54 PM   #1
andrewdouv's Avatar
Rewards Points: 16
A contractor buddy of mine, a guy in his late 60s, (I was 24 and a hardscaper at the time) hired me to help him as a laborer on a big project he was doing. We did a lot of different stuff, framing, windows, flooring, plumbing. It took me awhile to realize this guy I was working for was a quack. Mainly realized when we got to the floors- because I was the laborer, he was supposed to be the expert, but he basically had me go pick up a couple pallets of rough cut African Mahogany, gave me the name of a Mennonite guy expecting me to straighten, plane and sand the boards in that guys shop. Then he had me cut pressure treated plywood (not T&G), ramset and glue that to the concrete floor. Then lay this stuff down over top of it and finish it with tung oil. I asked about wood expansion, he told me glue, and top nail with my 16D finish nailer and stressed that I put the boards as tight as humanly possible. Going into 4 full BATHROOMS. Then I'm pretty sure he went and took a nap in his truck while I did all that. It looked beautiful when I was done, but he didn't want me to oil the boards on all 4 sides because I was going to glue (and topnail) the mahogany to the pressure treated subfloor and he thought the oil would mess with the glue, (probably true). So this stuff is only tung oiled on top for finish
After we did the floors, we started working on other stuff, and one of the bathrooms cupped and crowned like mad, I spent a full 10 hours hitting that bathroom again with a belt sander and then a palm sander and then another day refinishing it. The floors sat and looked fine for a couple weeks after that.. then we got kicked off the job when an inspector came through to look at the plumbing and most of it had to get ripped out. I'm sure it failed framing inspection and everything else. I have some real horror-show pictures that I took of things the contractor did while I was at the beach for a week. Too lazy to route a pipe around a joist or do the appropriate hole cut, and not having me there to do it for him, he cut the middle of a joist out completely in the basement thinking no one would notice. I fixed that myself, sister-ed the joist on both sides when I came back and cut his pipework out. I'm not liable for anything, even the homeowner knew my story from the very beginning that I was a hired helper with no background in carpentry. The contractor I worked for has no business owning tools. I'm not sure if I regret this whole experience, or if I'm glad to have seen how bad it really can get with some people.
But how bad did I do with these floors? Anyone do raw-wood to flooring? What was the correct way to do it? Its a shame cuz they looked beautiful when I left and I was proud of my work, but I realize now that cupping and crowning I saw is probably gonna come back.. especially once those showers are used
I'm getting in the mindframe that I want to take up contracting full time but I got a lot to learn since the first couple clowns I worked for were... clowns. What's the proper way to do this! and if I can contact the owner, to ask about the results, should I do it given the scenario?
andrewdouv is offline
Old 10-05-2018, 03:00 PM   #2
rrk's Avatar
Rewards Points: 2,330
Re: I Did Something Terrible..
Oh boy at least it looks neat and clean but all wrong. I don't have time right now to list the correct way but people will do that soon here.
It will all have to come out unfortunately
rrk is online now
andrewdouv (10-05-2018)
Old 10-05-2018, 04:33 PM   #3
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 429
So, lets install the finish flooring prior to the drywall.
Easy Gibson
Warren is online now
The Following 4 Users Say Thank You to Warren For This Useful Post:
andrewdouv (10-05-2018), Calidecks (10-06-2018), Seven-Delta-FortyOne (10-05-2018), spazman (10-05-2018)
Old 10-05-2018, 04:55 PM   #4
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,244
With no expansion gaps.
And probably without a moisture test on the concrete to boot.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
The Following User Says Thank You to TNTRenovate For This Useful Post:
Old 10-05-2018, 05:02 PM   #5
rrk's Avatar
the guy sleeping in the truck told him tight and it is tight
rrk is online now
The Following 4 Users Say Thank You to rrk For This Useful Post:
andrewdouv (10-05-2018), Calidecks (10-06-2018), tgeb (10-07-2018), TNTRenovate (10-05-2018)
Old 10-05-2018, 05:06 PM   #6
FloorsByAlex's Avatar
Trade: Flooring
Rewards Points: 128
Vapor barrier film on floor room up on walls 6" ramset 2x3s on the flat 16" OC to concrete over vapor barrier, 3/4" plywood or t&g plus asphalt paper. Never PT inside a house.... Ever.
Best generic solution w/o knowing all the specifics.
Sent from my LG-LS993 using Tapatalk
FloorsByAlex is offline
The Following 2 Users Say Thank You to FloorsByAlex For This Useful Post:
andrewdouv (10-05-2018), Metro M & L (11-20-2018)
Old 10-05-2018, 05:26 PM   #7
avenge's Avatar
Rewards Points: 720
Wtf?
avenge is online now
Old 10-05-2018, 06:18 PM   #8
rrk's Avatar
That floor will be toast by the time that house is finished
rrk is online now
Old 10-05-2018, 06:19 PM   #9
VinylHanger's Avatar
Rewards Points: 10,954
Why would you go and talk to the owners? You did what you were told. Walk away and move on. It is hour employers pro L em.
Honestly though, you do have lots to learn. You aren't ready to be a contractor. Put in 3 or 4 years first. At the least.
VinylHanger is offline
Old 10-05-2018, 06:40 PM   #10
rrk's Avatar
He knows that, that is why he posted
"I'm getting in the mindframe that I want to take up contracting full time but I got a lot to learn "
He just needs a good teacher
rrk is online now
andrewdouv (10-05-2018), Calidecks (10-06-2018), MarkJames (10-06-2018), META (10-06-2018)
Old 10-05-2018, 09:13 PM   #11
andrewdouv's Avatar
Rewards Points: 16
Thanks you for a serious reply with some specifics. when you say ramset 2x3s, this would be like furring strips under the 3/4 ply correct? So the vapor barrier and asphalt paper basically sandwhich the subfloor and keep moisture out, that makes sense to me. What about the Mahogany floors, how should I have finished them, and how do I create proper expansion gaps? I get it if you guys don't wanna be my encyclopedia on flooring, I'm glad I now know that the work I did was fubar, and everything that guy was telling me to do was bad this confirms everything. I didn't really have anyone to ask before.
Also
"Honestly though, you do have lots to learn. You aren't ready to be a contractor. Put in 3 or 4 years first. At the least."
--- this is exactly my gameplan. I'm looking for a guy in my area who isn't a POS who I can work under for a few years and learn to do the trade properly. I wasn't expecting to learn how to do flooring on this forum, what I was expecting was someone to tell me exactly where I went wrong and possibly how they'd have done it.
Thanks everyone for the replies. I'm a new member and I'm looking forward to learning from your projects and eventually posting my own
The Following 3 Users Say Thank You to andrewdouv For This Useful Post:
asevereid (10-05-2018), META (10-06-2018), VinylHanger (10-06-2018)
Old 10-05-2018, 09:28 PM   #12
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 318
How long ago was this project?
While I understand your curiosity to see past work, and learn from it, which is commendable, in this situation you should just let it go.
From the very little that we saw in those pics, and your description of what took place, your former boss was not a professional builder at all. Forget what he taught you and move on.
There are plenty of excellent builders out there, even in Seattle I'm sure , and your best bet is to find one, and go to work for him.
As less and less folks want to learn the trades, the good tradesmen are in high demand, and if you have a good work ethic and a desire to learn, you should get picked up fast.
Good luck.
Old 10-05-2018, 09:29 PM   #13
andrewdouv's Avatar
Rewards Points: 16
No moisture test, I didn't know that was a thing til you mentioned it. Got the google education. jeez.
Old 10-05-2018, 09:38 PM   #14
andrewdouv's Avatar
Rewards Points: 16
This was beginning of 2017, on the east coast. I came out to seattle to work a couple contracts on fishing boats but I brought my truck and my tools and i've got a couple dead months in the winter. Right now I'm doing cutting and installing hardieplank siding for someone. But this is just a temporary gig. I'm gonna start looking seriously soon. I see a ton of ads for framers and laborers, but I think I'm better off trying to find a guy to take me as an apprentice than working for a company doing piece/rate hustle jobs (which there are a lot of).
Old 10-05-2018, 09:51 PM   #15
Trade: Highwayman
Rewards Points: 318
Be careful getting stuck on a piece work/specialized crew.
While you'll learn quick and get proficient at one thing, you'll get stuck with that one thing, and it'll limit your opportunities for other work, and keep you from becoming a well-rounded builder.
And during the inevitable downturns in this trade, the more you know, the better off you'll be.
The Following 3 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
andrewdouv (10-05-2018), rrk (10-05-2018), TNTRenovate (10-06-2018)
Old 10-06-2018, 06:37 PM   #16
META's Avatar
Trade: General and Trades
Rewards Points: 4,530
I started out working for a guy that did a mix of new and remodel homes. I learned a ton about building new, and altering existing structures.
People that build new construction will do well to have experience looking at a weathered and aged structure, the materials used, construction techniques of past, and how things have faired over time. You'll be prepared to build a better home with that experience.
Keep your attitude, you'll go far.
META is online now
The Following 2 Users Say Thank You to META For This Useful Post:
andrewdouv (10-07-2018), mrcat (10-06-2018)
Old 10-06-2018, 07:52 PM   #17
Trade: Flooring
Rewards Points: 128
Also
After Install... Treat like any other unfinished hardwood install. Sand everything down 40 grit up to 180 grit. With mahogony, use a grain filler. Then seal the floor. Screen buff it and the use oil based urethane probably 3 coats for mahogony. Buff and tack cloth between coats.
Only floor guys would know this stuff. GCs can care less about the actual process. Can't beat yourself up too much.
The Following User Says Thank You to FloorsByAlex For This Useful Post:
Old 10-06-2018, 08:52 PM   #18
mrcat's Avatar
Trade: Pole Barns, Residential Framing
Rewards Points: 722
That's exactly how I started out, worked for my uncle for three years, doing custom homes on the lake, with the occasional remodel.
Learned a little bit about everything from the footings to the trim and paint, the only things he subbed out were plumbing and electric, and I got to be the plumbers helper quite a bit when he was on site.
I thank him occasionally for the well rounded start I had, should thank him every time I see him probably.
Sent from my E6810 using Tapatalk
mrcat is offline
The Following 2 Users Say Thank You to mrcat For This Useful Post:
andrewdouv (10-07-2018), META (10-06-2018)
Old 10-07-2018, 02:21 PM   #19
andrewdouv's Avatar
Rewards Points: 16
Thanks, I've been reading a lot about this the last couple days. Tung oil is pretty nutty for a bathroom floor. I appreciate everyone's feedback. Once I get back on dry land I'll go through my laptop and look for some photos to add to the wall of shame. I know I got a photo of the joist cutout somewhere
Test - How many terrible practices can you find ??? theflynner Roofing 28 08-08-2019 11:01 AM
Terrible paint job WHSmike Drywall 20 03-25-2018 01:00 AM
Terrible slab rshewett12 General Discussion 17 04-03-2017 02:33 AM
Terrible Spalling on driveway NEFoamer Concrete & Paving 20 05-02-2016 06:33 AM
Brand New Haulmark Transport Rusting Apart – Poor Quality – Terrible Customer Service Armstrong334 Vehicles 8 08-17-2014 11:39 PM
