How To Remove Turf Glue From A Porous Exterior Concrete? - Flooring - Contractor Talk
Old 09-19-2019, 02:41 PM   #1
concretestain's Avatar
Trade: Concrete Resurfacing / Decorative Concrete
Rewards Points: 12
Hi guys,
I've spent all day yesterday trying to remove 300 sq feet of glue. I'm a concrete resurfacing contractor, and the client hired me to remove the glue and stain the floor.
I can normally remove glue of a 300 sq foot room, and prep the floor in two-three hours.
I tried pressure washing, and it didn't work. I tried several strippers from home depot (which all seemed very much the same), and pressure washing, but that also didn't work. Scraping is not an option because of the porosity.
I also tried grinding with a 10" grinder. Between the concrete being too porous, and the blades constantly getting clogged with residue, it did almost nothing.
I'm thinking I need to soften the glue up with some sort of chemical, and then pressure wash it. I just can't seem to find the right chemical.
Have you got any advice?
concretestain is offline
Old 09-19-2019, 03:11 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 12
Re: How To Remove Turf Glue From A Porous Exterior Concrete?
Check these guys out:
https://www.jondon.com/chemicals/aba...-removers.html
I've also seen the abatement guys use a soy based solvent that worked really well to remove glue from concrete.
griz is online now
concretestain (09-19-2019)
Old 09-19-2019, 03:22 PM   #3
Rewards Points: 12
Thanks for the link, I saw a video of those guys on youtube.
I'm not sure I understand the second part of your reply. I'm not familiar with the abatement guys, nor with the soy-based solvet. Do you care to expand on that?
Old 09-19-2019, 04:39 PM   #4
Fire up the BBQ
griz's Avatar
Rewards Points: 12
When removing asbestos VCT and the stubborn mastic (glue) the asbestos abatement guys use a soy based glue remover/dissolver.
California is VERY stringent on what solvents/chemicals can be used for various purposes, especially in schools.
First time I saw the soy solvent everyone, including the abatement guys, were leery as to how/if it would work.
Worked awesome.
griz is online now
The Following 2 Users Say Thank You to griz For This Useful Post:
BlueRidgeGreen (09-19-2019), concretestain (09-19-2019)
Old 09-19-2019, 04:59 PM   #5
Rewards Points: 12
Thanks a lot for the clarification! I'll call Sentinel and see which specific product they recommend
Old 09-19-2019, 07:14 PM   #6
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 15,295
I once used the soy-based stuff (Bean-e-doo) to remove black cutback adhesive on a concrete floor basement (used under 9x9 asbestos tiles), in order to prep for epoxy. The stuff was amazing. It softens the adhesive, and then you apply something to absorb the mess and scoop it up. I forget what they recommended, but something like sweeping compound or cat litter..whatever to absorb it. (Orange contractor solvent worked to clean up any remaining residue..if you run out of the soy stuff)
Then you reapply as needed for what you missed...clean it up...and finally you neutralize the floor with "Emerge". It came out great. Finish coat was one-part epoxy, and it was nice and tight for a long while.
Since it's environmentally-friendly, I would imagine that you could pressure wash it, but first wet the surroundings down...and rinse everything thoroughly afterward. This is just a hunch....but possibly worth a try.
MarkJames is online now
concretestain (09-23-2019)
Old 09-23-2019, 01:09 AM   #7
Rewards Points: 12
Thank you for your thorough reply. Unfortunately, I didn't get to try it out. I picked up a sample of the 747+, upon contacting Sentinel directly. By then, though, the customer got scared about the whole thing taking too long and decided to cancel. I really wanted to know if this would work for future references. And there's the money, of course.
I'm not sure why that happened since I specifically told him that I have gotten a free sample, and if it worked, I was going to charge him for the project as initially agreed upon. What are ya gonna do
Old 09-23-2019, 07:23 AM   #8
Larkin's Avatar
Trade: Painting and Flooring
Rewards Points: 2
I do a lot of concrete staining work as well. I normally use the carbide blades on a grinder to remove the thick adhesive. They are square blades with multiple sides meant for scraping adhesives and what not. Then I go back over it and grind the surface to open the pores and get the top layer that has glue soaked into it off. Just something to try for next time.
Larkin is offline
