Hardwood Flooring Underlayment. - Flooring - Contractor Talk
Old 05-19-2015, 08:25 PM   #1
bluebird5's Avatar
Trade: Licensed G. C. carpenter, flooring, remodeling
Rewards Points: 694
I am about to lay some 4" soft maple over advantech subfloor which is over a crawlspace. I have had my 6 mill poly down for about a week. Subfloor is at 10% and the maple is at 6% moisture content.
I am wondering which underlayment to use. I do not want roofing felt. I really don't want aquabar either because I can smell the asphalt in it. Should I use a siliconized paper or a wax paper? I have also considered rosin paper.
Here is my thinking is that although these vapor retarder papers block or slow down moisture from the subfloor from entering the hardwood, eventually the moisture will get to the hardwood. So am I better off just using rosin so that the 2 woods get to the same moisture content and then sand and finish or are the vapor retarders better?
Will my hardwood eventually get to 10% or will the vapor retarder prevent this from happening?
bluebird5 is offline
Old 05-19-2015, 08:38 PM   #2
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 72
Re: Hardwood Flooring Underlayment.
You've already made your excuses for not using the proper hardwood paper. Go ahead & just use rosin paper & get ready for the client to call your back when their floor cups.
I personally won't lay a sanded floor without ASU or LSU hardwood paper under it. My reputation is way to valuable to risk a cupped floor. I also won't lay a sanded floor without making sure permanant HVAC has been turned on & running long enough to bring down the moisture content in the subfloor.
pinwheel is offline
Old 05-19-2015, 08:43 PM   #3
bluebird5's Avatar
Rewards Points: 694
I;m not trying to save money, I just want to use the right product. I usually use 15# felt, but I want to get away from the asphalt. What would you suggest? This is for my personal house.
Old 05-19-2015, 08:58 PM   #4
pinwheel's Avatar
Rewards Points: 72
Aquabar-B or ASU 15 hardwood paper. Also get the AC running & pulling moisture out of the sub floor before putting down the hardwood.
The flooring & subfloor will eventually find a balance in MC, but until they do, if you don't use a moisture hardwood paper, you're going to get cupping till they find that balance.
pinwheel is offline
The Following User Says Thank You to pinwheel For This Useful Post:
charimon (05-20-2015)
Old 05-19-2015, 09:12 PM   #5
bluebird5's Avatar
Rewards Points: 694
I am thinking of using this silicone paper which is usable over radiant heat. .47 perm without nails and 0.712 with nail holes. I believe that it is pretty close to the same perm of aquabar and has zero voc. Have you ever used this? What do you use over radiant heat?
http://www.lumberliquidators.com/ll/...PAPER/10021412
Old 05-19-2015, 09:23 PM   #6
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,484
I've torn out floors with asphalt next to rosin over crawl space. It's no contest, rosin is cupped with severe gaping from crushed grain following swelling; tar paper is flat with slight gapping.
Pin will tell you aquabar, I will tell you tar. Either way, it two guys who have been doing hardwoods for decades and a piece of plain paper is not going to work.
I've read 2 percent and 4 percent max difference between the substrates. I've laid many times with a four point difference and haven't had any problems. Make sure you read the manual on your moisture meter. They can be off by 2 to 6 percent depending on temperature and species. At least the lignos anyway.
Metro M & L is offline
Old 05-19-2015, 09:39 PM   #7
bluebird5's Avatar
Rewards Points: 694
Yes the moisture meter says it can be off plus or minus 2%. It also says that it will read less moisture in denser wood and higher moisture in less dense wood. So it is really hard to push into the maple floooring and I can shove it all the way into the advantech. So it is hard to truely know what the moisture content is.
Old 05-20-2015, 05:00 AM   #8
pinwheel's Avatar
Rewards Points: 72
You're worried about a little tar, yet you provide a link from lumberliquidators. Dude, that's laughable.
No, I've not used that paper.
pinwheel is offline
Old 05-20-2015, 05:46 AM   #9
mako1's Avatar
Rewards Points: 1,094
I think the 6% reading is off some on you're flooring.Especially in TN this time of year.Hardwwood is usually only dried to 7% to begin with and will usually rise some to a ambient MC.
mako1 is offline
The Following 2 Users Say Thank You to mako1 For This Useful Post:
bluebird5 (05-20-2015), PrecisionFloors (05-20-2015)
Old 05-20-2015, 09:53 AM   #10
Paul
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Rewards Points: 1,004
Over thinking once again. Use aquabar and be done with it. The smell dissipates pretty quickly. The over concern about v.o.c these days is getting ridiculous. I'm damned glad building this country was already done before this generation got here... Can you imagine anyone under the age of 40 throwing hot rivets or pipe fitting now a days...
Precision Floors
(772) 237-9900
PrecisionFloors is offline
The Following 3 Users Say Thank You to PrecisionFloors For This Useful Post:
charimon (05-20-2015), CO762 (05-22-2015), pinwheel (05-20-2015)
Old 05-20-2015, 11:20 AM   #11
mako1's Avatar
+1 I am 60 this year and been in the trades since 16.I should have been dead year ago with all of the stuff I've dealt with.Asbestise,all kinds of paints,solvents and other carcinogens including the dreaded milk for awhile just to name a few.
My dad was a salesman and never did any manual labor in his life .Died at the age of 51 with a heart attack and never partied near as much as I have.
Not saying to not take safe measures but don't be a prisoner in your own world either.
mako1 is offline
CO762 (05-22-2015), PrecisionFloors (05-20-2015)
Old 05-20-2015, 12:22 PM   #12
bluebird5's Avatar
Rewards Points: 694
So what to who sells a product. They didn't make it, they just sell it. If I bought aquabar from lumber liquidators would that be laughable too? If you have something available to you around the corner, are you not going to go there to get it or will you drive 30 miles to your "supply house" through heavy traffic for the same product? There are other brands of silicone paper, I just wanted to show you an example.
Old 05-20-2015, 03:14 PM   #13
Particulate Filter
Trade: Flooring
I drive across town to get the right tool, finish, lumber all the time. If it's worth doing, and everyone else does it for a living , it's worth arguing with them about what they have years of experience in. Wait, I'm don't think that's how that saying goes...
Old 05-20-2015, 03:21 PM   #14
pinwheel's Avatar
Rewards Points: 72
maybe next time you want flooring advice, you should start the thread saying you want us to agree with you & your choices rather than sharing our experience & expertise.
pinwheel is offline
Old 05-20-2015, 04:01 PM   #15
bluebird5's Avatar
Rewards Points: 694
Well I ended up getting the aquabar.
The Following User Says Thank You to bluebird5 For This Useful Post:
Metro M & L (05-25-2015)
Old 05-20-2015, 04:05 PM   #16
bluebird5's Avatar
Rewards Points: 694
No not asking you to agree. All I was asking about was if anyone had any experience with the silicone paper.
Old 05-20-2015, 04:32 PM   #17
Xtrememtnbiker's Avatar
Trade: General Remodeling
We've used the silicone paper. Because that's what the guy at LL sold us. Pin has me reconsidering.
Xtrememtnbiker is offline
Old 05-20-2015, 07:02 PM   #18
MIKE ANTONETTI's Avatar
Trade: FLOORING CONTRACTOR
Rewards Points: 3,514
I think Pin was referring to the excessive formaldehyde in LL products and you being concerned about VOC's
I personally don't like hardly any Chinese products with some exceptions, partly Americans are to blame as we all want cheap so we can buy other cheap stuff.
The air in our home is open to outside air a lot, mostly frickin allergies from pollen.
MIKE ANTONETTI is offline
The Following User Says Thank You to MIKE ANTONETTI For This Useful Post:
Best flooring option over old 3/4 hardwood floor. Spencer Flooring 61 02-09-2014 09:42 PM
3/4 T&G Hardwood floor underlayment options jdghandyman Flooring 19 07-31-2012 10:03 PM
hardwood flooring celcon Flooring 16 11-28-2010 07:51 PM
Price to install real hardwood flooring and remove carpet Handyman4u Flooring 15 02-21-2009 09:36 PM
Hardwood underlayment yamangold Flooring 3 02-02-2009 06:26 PM
