Gym Flooring Recommendations - Flooring - Contractor Talk
Old 01-08-2020, 11:30 AM   #1
Commercial Flooring Guy
Mitch15's Avatar
Trade: Flooring
Rewards Points: 66
What flooring would you recommend for a below ground, basement gym flooring?
Mitch15 is offline
Old 01-08-2020, 11:34 AM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 2,342
Re: Gym Flooring Recommendations
how was the slab installed?
what is the current rh of the slab?
what is the intended use of the gym?
how much money do you have?
griz is online now
Old 01-08-2020, 11:36 AM   #3
Mitch15's Avatar
Trade: Flooring
Rewards Points: 66
All good questions, I will find those out and get back to you.
Mitch15 is offline
Old 01-08-2020, 12:20 PM   #4
Fire up the BBQ
griz's Avatar
couple of more...
is the space conditioned 24/7?
any transition issues w/doors or hallways etc?
griz is online now
Old 01-08-2020, 12:27 PM   #5
Mitch15's Avatar
Trade: Flooring
Rewards Points: 66
This is a great list of questions. A buddy of mine just got into a brand new home and wanted to turn the basement into a pretty large home gym. I'll get answers to these questions and get right back to you.
Thanks,
Mitch15 is offline
Old 01-08-2020, 01:50 PM   #6
Fishindude's Avatar
Trade: Industrial
Rewards Points: 1,300
Big difference between what you need for weight lifting vs what is needed to play basketball on. Really need to understand the intended use.
Fishindude is offline
Old 01-10-2020, 09:49 AM   #7
Mitch15's Avatar
Trade: Flooring
Rewards Points: 66
Sorry for the delay. He is going to use it for weight lifting with no weights being slammed down on the ground.
Mitch15 is offline
Old 01-10-2020, 01:19 PM   #8
CharlieDelta's Avatar
Trade: Carpentry/Building/Remodeling
Rewards Points: 1,794
I just built a 24' x 24' pole barn and what I use for my gym flooring in there is the 3/4" rubber stall mats from Tractor Supply. You can usually buy them online.
Generally speaking- Almost every commercial gym on the planet uses the 3/" thick rubber stall mats.
CharlieDelta is offline
Old 01-10-2020, 01:21 PM   #9
Mitch15's Avatar
Trade: Flooring
Rewards Points: 66
That's probably what he is going to go with as well. Thanks!
Mitch15 is offline
