Grout Cleaning Advice/Help ? - Flooring - Contractor Talk
Old 04-22-2014, 10:35 AM   #1
MTN REMODEL LLC's Avatar
Trade: Remodel and new build Colorado @ 7651 FT
Rewards Points: 1,428
Good morning.... (Not really for me... I've got alot of grout to clean/freshen)
Wanted to ask everyone as to their recommendations as to best way to clean up dirty grout... and any pro's/cons or things to be carefull about.
I have both a kitchen floor and bathroom tile counters to clean.
The kitchen floor has a light tan grout and the bath an off white grout.
To date, they have just been scrubbed/cleaned with KaBoom degreaser, with minimal success.
I know some commercial operations (maybe Coit carpet cleaners) clean grout somehow... anyone know what they do or use.
I suspect the grout was originally sealed many years ago. It is a sanded grout.
Thanks for any help/advice/your experience.
Best
Never stop learning (xcep fer speling en typeing)
MTN REMODEL LLC is offline
Old 04-22-2014, 10:50 AM   #2
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 4,082
Re: Grout Cleaning Advice/Help ?
Guy that use to work for me had a machine that would use an acidic cleaner and had two motorized scrubbing heads.
Inner10 is offline
The Following 2 Users Say Thank You to Inner10 For This Useful Post:
MTN REMODEL LLC (04-22-2014), Osito (04-22-2014)
Old 04-22-2014, 02:45 PM   #3
CarpenterSFO's Avatar
Rewards Points: 2,044
Hot water, degreaser, brush, let it soak, do it over again, and again. If it's stained, then bleach, which compromises the grout some if it's a cement grout. We have a jet steam cleaner, but I don't think it does any better than a brush. My favorite brush for the job is a fingernail brush with a handle that you can grip. Horrible work. Krud Kutter's my current favorite cleaner.
I sure like epoxy and urethane grouts - they pretty much make grout cleaning a thing of the past.
- Bob
CarpenterSFO is offline
The Following User Says Thank You to CarpenterSFO For This Useful Post:
Old 04-22-2014, 04:17 PM   #4
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Hot water, OxyClean, white scrubbie. If that doesn't clean it, it's not going to get clean.
Any acid will help clean but also start compromising the grout.
Considering a good cleaning (degreaser too with fresh water rinse) and then a grout colorant. This one is epoxy based so onced colored, you get a MUCH better seal on the original cementitious grout:
http://www.custombuildingproducts.co...-colorant.aspx
Angus
angus242 is offline
The Following 2 Users Say Thank You to angus242 For This Useful Post:
CarpenterSFO (04-22-2014), MTN REMODEL LLC (04-22-2014)
Old 04-22-2014, 04:25 PM   #5
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,070
Second...oxyclean does a pretty decent job but the white scrubby is key...you only use a green scrubby once.
And I have used that colorant a few times as well. Goes on pretty easy. I just brush on with an artists brush and wipe off any that gets on the tile with a damp clothe.
Tried & True on Facebook
Tried & True Website
TNTRenovate is online now
The Following User Says Thank You to TNTRenovate For This Useful Post:
Old 04-22-2014, 05:04 PM   #6
charimon's Avatar
Trade: Tile and Tool junkie
Rewards Points: 1,168
I Use Viper Venom http://interlinksupply.com/index.php...FaLm7Aod8FgA9Q spray it on let it dwell 15-30 min. I
rinse and recover using a turbo hybrid wand http://www.jondon.com/turbo-hybrid-t...t-cleaner.html hooked to a Hotsy 555 and a pumper vac. Works great.
210Deg water at 1800psi is hard to beat on tile.
"The key is to allow only the complexity that the customer is willing to pay for."
charimon is offline
The Following User Says Thank You to charimon For This Useful Post:
Old 04-22-2014, 08:23 PM   #7
Bob, Angus,Rob,Chair..... Thank you for the ideas.
(Chair... Thanks for the info... little above my need/capacity for one residential redo.)
So, I just got back from playing with Oxyclean and Clorox.
...(Bob, actually I was using Krud-cutter before... don't know why I got mixed up and called it Ka-boom... it took up alot of dirt,,, but not that great on the grout)).
Oxy did better, but Corox really cleaned up the grout stains REALLY.!!!
I guess my first question to you guys would be... how bad do you think that bleach compromizes the grout. The grout has been down for many years and is fully competant right now.... Would I expect it to crack/crumble at this stage.
Depending on your guys advise, I may go ahead with Custom's colorant,... more so for grout integrity, rather than color aesthetics.
I'm reluctant to follow up with the colorant if I don't need to, for both the time/work, but more so, because the tile is a very rough/ textured (non-skid) porceline .... and I'm afraid of being able to clean the tile with an epoxy based colorant.
Thanks again
Peter
Old 04-22-2014, 09:14 PM   #8
mbryan's Avatar
Trade: water restoration
Rewards Points: 552
Most of the grout cleaning is the high pressure tool. Of course you need product but the pressure is the biggest thing. To the best of my knowledge many of the original grout cleaning products, ie viper venom, were relabeled floor stripper. Don't think they changed their formulation too much since then unless it's a green product... Make sure you do a good job rinsing it as any product left behind will cause issues with resoiling down the road.
mbryan is offline
The Following User Says Thank You to mbryan For This Useful Post:
Old 04-22-2014, 09:37 PM   #9
Originally Posted by MTN REMODEL LLC View Post
...how bad do you think that bleach compromizes the grout...
Just rinse well.
- Bob
Old 04-22-2014, 09:40 PM   #10
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Bleach can permanently, well, bleach the grout...as in remove color from the pigment.
Angus
angus242 is offline
The Following User Says Thank You to angus242 For This Useful Post:
Old 04-22-2014, 11:11 PM   #11
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
I've used a product called "Totally Awesome Tile Grout Cleaner" and it works great.
m1911 is offline
The Following User Says Thank You to m1911 For This Useful Post:
MTN REMODEL LLC (04-23-2014)
Grout Cleaning Systems....... Again HandyHails Tiling 76 03-24-2013 02:56 PM
festool cleaning kit.. Rich D. Tools & Equipment 9 03-10-2013 08:32 PM
PROOF that cleaning ladies don't know how to clean wood floors lawndart Flooring 4 09-20-2012 07:46 PM
Pressure Washing & Window Cleaning Tips Jas2012 New Member Introductions 13 08-14-2012 05:22 PM
Grout cleaning and epoxy grout colorant? D.S.I. Tiling 4 08-05-2011 09:37 PM
