Flooring Suggestions Anyone - Flooring - Contractor Talk
Old 12-14-2010, 04:42 PM   #1
fixerman's Avatar
Trade: Residential
I need a flexible T type molding that is around 22 feet in length and 2 inches wide. There are 3 large curves going L, R, L.
I plan to epoxy or silicone it in place, I just need a material that will accept the curves and be one long piece.
The internet has not turned up much yet.
Thanks
fixerman is offline
Old 12-14-2010, 08:09 PM   #2
Keeyter's Avatar
Trade: Home Remodels
Rewards Points: 851
Re: Flooring Suggestions Anyone
This depends alot on what type of materials you are adjoining it to, height allowances, desired finishes, yada yada
Keeyter is offline
Old 12-14-2010, 09:53 PM   #3
fixerman's Avatar
Trade: Residential
One side is stone tile and the other is Laminate flooring. It is quite uneven which is why i need 2+ inches width in a T style.
fixerman is offline
Old 12-14-2010, 11:50 PM   #4
Paul
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Rewards Points: 1,004
No such animal exists that I'm aware of. The longest you will find are 12 footers. I doubt it will look very appealing either....
Precision Floors
(772) 237-9900
PrecisionFloors is offline
Old 12-15-2010, 12:24 AM   #5
Keeyter's Avatar
Rewards Points: 851
Industrial Look with a good metal worker that can custom you a peice. Regardless what you do, with that length and profile it will have to be custom.
Keeyter is offline
Old 12-15-2010, 11:42 AM   #6
Floor Surgeon's Avatar
Trade: Hardwood flooring
Rewards Points: 75
I am pretty sure you will have to go custom. I have spent many hours looking for something just like you are describing. We have a sub that is a master at custom wood. Not cheap, but we build the expense in at the beginning. I am rooting for you to find a simpler option, but am not optimistic.
Floor Surgeon is offline
Old 12-15-2010, 03:20 PM   #7
edson group inc's Avatar
Trade: hardwood flooring
Rewards Points: 83
check Flexition dot com. I'm not sure if they have the length you need as one piece but they should have the profile you want.
edson group inc is offline
Old 12-15-2010, 05:39 PM   #8
RhodesHardwood's Avatar
Trade: Hardwood Floors
Rewards Points: 594
I agree. Get it custom, or it will not look too good.
RhodesHardwood is offline
Old 12-24-2010, 10:53 PM   #9
Done Wright Flooring
Donewright's Avatar
Trade: Flooring sales and installation
Rewards Points: 25
Their are some transitions that are available at any desired length you need it cut at but for the most part they are flat rubber pieces mostly used in commercial settings for vinyl ends to concrete. But sadly what you probably need will be at the twelve foot length. Search around something like that might just work. Good luck
Donewright is offline
The Following User Says Thank You to Donewright For This Useful Post:
Frankwhoa (12-27-2010)
Old 12-24-2010, 11:51 PM   #10
Flooring Installer
rusty baker's Avatar
Trade: flooring
Rewards Points: 110
http://www.flexitions.com/
Flooring installer since 1973
Armstrong certified
rusty baker is offline
Old 12-27-2010, 02:05 PM   #11
Multi-Craft ContractorLLC
Frankwhoa's Avatar
Trade: LA Home Improvement Contractor #554161
Rewards Points: 29
1) You're local flooring wholesaler (Daltile, Bixco) not retailer (flooring store) should have an assortment of vinyl 'cap' transitions of numerous styles, colors, and shapes that you can get to work or even a metal one you may be able to modify.
2) Tape up some cardboard, cut out a template, and make one out of wood!
You're probably going to have to get a little creative.
Frankwhoa is offline
Old 12-27-2010, 02:17 PM   #12
fixerman's Avatar
Trade: Residential
It looks like Flexitions molding will do the job. The homeowner cares not about price. The molding I need from Flexitions will be around $550. I agree that wood is the obvious choice, but the transition is so out of whack that wood is not the best material for this job.
fixerman is offline
Old 01-05-2011, 04:15 PM   #13
jadefloors.com's Avatar
Trade: Floor Installer
It might be a little late(I just joined today) but formica makes a flexible molding to match their laminate
jadefloors.com is offline
Old 01-05-2011, 04:38 PM   #14
fixerman's Avatar
Trade: Residential
Tell me more about these formica moldings if you will. Where to buy, how flexible, etc..
fixerman is offline
Tags
flexible transition , flooring , rubberized , t-molding
need some flooring suggestions Farmer Boy Flooring 7 07-17-2012 03:43 PM
Air waves under new vinyl flooring geospec Flooring 44 07-11-2012 05:50 AM
Mullican Flooring Sold at Lowe's GHI General Discussion 2 05-19-2010 03:09 PM
laminate flooring placement nwksremodeler Flooring 7 06-19-2009 09:24 AM
