Flooring Over Heated Concrete Below Grade - Flooring - Contractor Talk
Old 07-12-2015, 10:06 PM   #1
Jams's Avatar
Trade: Roofer
Rewards Points: 6
Newbie here.
Getting ready to choose flooring for my basement. It's a new slab and will be used for a preschool. Wife doesn't like tile so that is out. Was figuring on some snap together of some sort.
I want something that can stand the heat and not hold the heat down.
Willing to hear any and all opinions. Thanks
Jams is offline
Old 07-13-2015, 04:19 AM   #2
pappagor's Avatar
Trade: general contractor
Rewards Points: 32
Re: Flooring Over Heated Concrete Below Grade
look at a concrete stain just did one and used elite crete it looked cool.
pappagor is offline
Old 07-13-2015, 06:00 AM   #3
GettingBy's Avatar
Rewards Points: 6,486
You need something with hi thermal conductivity and low thermal resistance, per inch of thickness.
Whatever the conductivity of paint or stain, the thickness is so small (0.004") that the effective conductivity is very high.
GettingBy is offline
Old 07-13-2015, 07:01 PM   #4
Box Builder
Morning Wood's Avatar
Rewards Points: 10,384
Tile is a no brainer over radiant. Otherwise as stated already dye he concrete. They also make some trowel on finishes that look pretty good but don't think they will hold up to preschool use that great.
Morning Wood is online now
Old 07-13-2015, 07:38 PM   #5
BKM Resilient's Avatar
Trade: Flooring
Rewards Points: 836
Pre-school?
You're going to want COMMERCIAL carpet or carpet tiles. The problem with carpet tiles would be the backings vary a lot and some would certainly FREAK OUT and fail if your slab is doing weird extremes of warm and cold. Normally I HATE......hate HATE carpet but this is one of those exceptions. I would look into Tredmore pad and do what we call a "double stick" install. I like to use commercial tack strip around these installs but it's not 100% necessary.
http://www.commercial-carpetcushion.com/tredmor.html
By all means consult with the carpet manufacturer as well as technical reps for the Tredmor pad to ensure your specific conditions meet their standards.
BKM Resilient is offline
The Following User Says Thank You to BKM Resilient For This Useful Post:
aptpupil (07-13-2015)
Old 07-13-2015, 11:49 PM   #6
aptpupil's Avatar
Rewards Points: 1,894
Tile or concrete in a preschool seems like a bad choice.
aptpupil is offline
Old 07-13-2015, 11:54 PM   #7
Fire up the BBQ
griz's Avatar
Rewards Points: 2,452
Actually an excellent choice...
Them little snot nosed goobers have all kind of accidents all day long.
Tile or concrete is very easy to clean up and sanitize.
Area rugs are used for floor time.
griz is online now
Old 07-14-2015, 07:18 AM   #8
Trade: Flooring
Rewards Points: 836
Public pre-schools/Kindergarten classrooms invariably get carpet on at least half the room. This week we're doing an elementary school and in the Kindergarten class they want us to demo all the carpet and a large section of ceramic tile. There will be a 5' row of VCT along the back by the sink, counter and entry and the rest is C&A direct glue down.
I was so surprised they wanted to burst out the tile I had the school call the District head guy to make sure that's what they want. Nothing wrong with the existing tile and we're going to demo it down and put VCT? That's just crazy but, YUP that's what we're gonna do.
Old 07-14-2015, 07:19 AM   #9
mikeswoods's Avatar
Trade: interior remodeling
Rewards Points: 2,664
If the daycare center is to be licensed--or might be,someday---
Check with the local heath department for any floor covering restrictions-----
It would be a shame to spent time and money only to have to rip it out because it will not meet code.
Griz is spot on---the ability to wash and sanitize is critical----
mikeswoods is offline
The Following User Says Thank You to mikeswoods For This Useful Post:
BKM Resilient (07-14-2015)
Old 07-14-2015, 08:58 AM   #10
madmax718's Avatar
Trade: General
Rewards Points: 3,276
the smaller groves and cracks of VCT is actually more sanitary than tile. During the cleaning/polishing, the cracks get filled, making it very easy to clean and polish. Its also drop resistant from chips and cracks. Tile has grout, and grout allows liquids to permeate, unless its sealed. Thats an on going thing. Grout is also "lower" in height than the tile, which can collect liquid, and allow a slower dry time.
I don't think I've seen a hospital that uses anything other than VCT in patient care areas.
madmax718 is offline
The Following User Says Thank You to madmax718 For This Useful Post:
Metro M & L (07-14-2015)
Old 07-14-2015, 02:51 PM   #11
GettingBy's Avatar
If the thermal resistance above the embedded heating element equals the resistance of the concrete below, half the heat will benefit the occupants.
Old 07-14-2015, 07:55 PM   #12
Trade: Flooring
Rewards Points: 836
REAL hospitals use sheet goods----HEAT WELDED and 6" coved up the walls. We put VCT in some exam rooms where the spilling of blood and other chemicals is significantly minimal in comparison to serious surgical procedures.
If I was to recommend ANY kind of resilient in K-6 (elementary school) without a doubt I would demand it be coved up the walls 6" and heat welded.
VCT is..............good enough for Walmart and trailer parks.
PrecisionFloors (07-15-2015)
Old 07-15-2015, 07:55 AM   #13
Paul
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Rewards Points: 1,004
Spoken like a real resilient mechanic I'm actually amazed vct still exists. The life costs/sft are astronomical compared to damned near anything else if the floor is maintained to any kind of standard. It's one of the most unforgiving floors prep wise ( again, if done right). Of course color and pattern combinations are limited only by imagination but I rarely see that as a reason for use. Cheap initial cost is about it.
Precision Floors
(772) 237-9900
PrecisionFloors is offline
Old 10-20-2015, 10:34 AM   #14
woodfloor's Avatar
Trade: flooring
Rewards Points: 86
There are a number of ways to add radiant heating to the concrete substrate. You can either put the heating coils in as you pour the concrete, or sandwich the heating coils between the concrete and a layer of plywood subflooring. Engineered wood planks are a good choice to install over radiant heated concrete because they have the ability to expand and contract with temperature changes. This type of flooring, with its tongue-and-groove construction, clicks together quickly to create a floating floor that isn’t attached to the concrete subfloor.
Wood Flooring New Jersey Phone: 201-330-0909
Wood Flooring New York Phone: 212-252-3838
woodfloor is offline
Need recommendations to fix newly but poorly finished concrete floor MikeGC Concrete & Paving 20 03-08-2014 07:11 PM
Grading & base InterCounty Masonry 8 06-11-2013 10:11 PM
concrete slab HUDSONVALLEYEXT Construction 4 06-04-2012 12:45 PM
?? About installing hardwood over concrete above grade?? maleko Flooring 16 03-03-2011 12:36 AM
Concrete Flooring Just-In-Time Flooring 5 12-03-2008 11:09 AM
