Flooring Leveler - Flooring - Contractor Talk
Flooring Leveler
Old 11-24-2013, 01:02 PM   #1
Hardly Working's Avatar
Rewards Points: 812
Flooring Leveler
I'm preparing to do a small bathroom with marmoleum. The floor is completely out of whack and I need to use a good flooring leveler to help take out some of the voids. I want something with good adhesion and good smoothing characteristics. What would you consider to be one of the better products out on the market for me to use? This is only a small 10 by 10 bathroom so its not a really large job. The homeowner isn't that interested in it having to be perfectly level but I want it close because I don't want a call back if it starts to lift. the bathroom is located in the basement and is only for guests.
Hardly Working is offline
Old 11-24-2013, 01:29 PM   #2
tjbnwi's Avatar
Rewards Points: 4,734
Re: Flooring Leveler
What's the substrate?
I like SLC I use Mapie. If it is over wood I use the Mapie plastic lath. Make sure you prime the floor.
tjbnwi is online now
CarpenterSFO (11-24-2013), Floormasta78 (11-28-2013)
Old 11-24-2013, 09:14 PM   #3
ccoffer's Avatar
Rewards Points: 1,140
CMP makes the best stuff you can get, but they're mostly all the same. Ardex K-15 is sort of the industry standard bearer.
Whatever you buy, just make sure you mix it the way they say and prime the floor first. If you don't prime, it won't work right. It can't because the floor takes too much water out of the mix as soon as you dump it out.
ccoffer is offline
Old 11-24-2013, 10:18 PM   #4
Rewards Points: 812
It going over concrete.
Old 11-25-2013, 08:48 AM   #5
BKM Resilient's Avatar
Trade: Flooring
Rewards Points: 836
test for moisture
BKM Resilient is offline
The Following User Says Thank You to BKM Resilient For This Useful Post:
PrecisionFloors (11-25-2013)
Old 11-25-2013, 09:43 AM   #6
Paul
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Rewards Points: 1,004
Also use cold, clean, mineral free (no well water) water to mix with.... Warm water will make it set up in the barrel. You also would do well to have a helper with you. You have to move quick and a two bag mix can awkward to maneuver in tight quarters alone.
Precision Floors
(772) 237-9900
PrecisionFloors is offline
Old 11-25-2013, 09:44 AM   #7
tjbnwi's Avatar
Properly primed the SLC will bond very well to the concrete. No lath needed.
BKM is correct, check for moisture, If it below grade make sure the product is rated for the application.
If height is not an issue look at Dri-Core.
Old 11-26-2013, 12:57 AM   #8
Rewards Points: 812
No moisture problems. Concrete is 50+ years old and dry. SLC it is.
Old 11-26-2013, 02:53 AM   #9
Trade: Flooring
Rewards Points: 836
No guts no glory.
Ardex K15 is what I'd use all day every day.
By the way, I don't know what your level of expertise is on flooring materials, adhesives, underlayment, concrete slabs in a BASEMENT and the moisture issues our industry suffers. I don't want to insult your intelligence or belabor the obvious but basement slabs WILL have moisture issues unless there are very effective barriers underneath the concrete and up around the walls of the basement.
You need to test the slab for moisture.
I don't care if it's 1050 years old. In fact the older the slab the more unlikely it is that the slab was DESIGNED for a resilient floor. Who the hell was putting linoleum in their basement 50 years ago? Asphalt-asbestos tiles yes. Linoleum NO. Wonder why?-----tolerance for MOISTURE!
And did you know that self leveling products are an even WORSE idea than linoleum where there are moisture concerns. Yeah, that's a real bad idea. But good luck anyways.
Usually it's all OK. As flooring guys we get called and have to go look at ALL the failures so we get a very warped perspective. I'm aware of that but I want to let you know what could go wrong and WHY.
I assume that's kind of the things we all come here for-------not DOOM AND GLOOM-----just fair warning, right?
MIKE ANTONETTI (11-27-2013)
Old 11-26-2013, 12:56 PM   #10
Rewards Points: 812
Originally Posted by BKM Resilient View Post
No guts no glory.
I'll let you go ahead and rain on my parade.going with the Ardex and I'll let it set for about 4-5 days before I go and put the flooring down. It's just what I'm told to do. It's the boss's job and its not my name on the door just my name in front of the home owner.
Old 11-26-2013, 12:58 PM   #11
Rewards Points: 812
Thank you everyone for your input it's been much appreciated.
Old 11-26-2013, 09:20 PM   #12
Trade: Flooring
Rewards Points: 836
I work on the same terms. I don't call the shots. I dodge bullets. We take those kinds of risks all the time. Nothing wrong with them so long as all parties are up front.
When things don't work out MY BOSS suffers the financial side affects. I just have to face the repair work and unhappy customers.
I rain on parades all day every day professionally. It's what I do.
But seriously, it'll probably be OK.
Old 11-28-2013, 06:59 AM   #13
Orlando Car
Floormasta78's Avatar
Trade: certified floor covering installer.
Rewards Points: 1,154
LATICRETE NXT might just be another great choice, considering you can go up to 3 inches .. it has to be really good.. I've used it, not disappointed..
http://www.facebook.com/#!/certifiedfloorcovering
Certified Floor Covering
Serving All California
( 510 ) 760 - 6810
Floormasta78 is offline
Old 11-28-2013, 08:16 AM   #14
tjbnwi's Avatar
Push come to shove, put down Ditra over the SLC. It will mitigate the moisture vapor issue.
Old 11-28-2013, 10:35 AM   #15
ccoffer's Avatar
Yeah. If money is no object. What a pain in the ass. Ditra and then back fill all of it?(creating two global cold joints)
There are plenty of products out there that can be surface applied and hold down over twenty pounds. I think Durabond D-250 holds down 14 all by itself with one coat. Over twenty pounds with two coats.
ccoffer is offline
Old 11-28-2013, 10:50 AM   #16
Paul
I have to agree here. Ditra is a good product and there are times when it's perfect for the situation but there are plenty of times it makes no sense.
Precision Floors
(772) 237-9900
Old 11-28-2013, 09:55 PM   #17
tjbnwi's Avatar
The floor needs to be leveled no matter what. Mortar down the Ditra, pour the SLC on the Ditra if you really want to block the moisture. Set the tile on the SLC. At my cost, about $75.00 in additional material.
I just looked, the D-250 would cost me about 3 times what the Ditra would.
Old 11-29-2013, 09:32 AM   #18
ccoffer's Avatar
That could only be true if the Ditra was stolen. Even getting it direct from their Pennsylvania plant, Ditra costs well over a dollar a foot, and you still have to buy thinset to put it down with and you have to dump God only knows how much stuff on the floor to back fill it.
I think you need to buy a better calculator. Yours is broken.
BTW: This is about a 10x10 bathroom. But hey, you can always buy a bucket of watered down latex from Forbo for $500(!!??) hehe
ccoffer is offline
Old 11-29-2013, 04:17 PM   #19
tjbnwi's Avatar
If you can't get the Ditra for .75 a square foot you need to find a new supplier. You can order it on Amazon for $1.22 a square foot. At $122.00 for the Ditra it is still less expensive than the D-250. Reread my post it states "material", either product will take some labor. Add $7.00 for the bad of mortar.
According to the OP the SLC is getting poured no matter what. That cost is a wash. You would actually use less self leveling compound. The ribs of the Ditra take a space that the SLC will not have to fill. My calculator works very well, I can tell you over the 100 square feet there is 225 cubic inches of space that the ribs on standard Ditra will take. That is a space the SLC does not need to fill.
Old 12-04-2013, 08:52 PM   #20
ccoffer's Avatar
If you're getting Ditra for 75 cents, you're buying it at a pawn shop. What does your pawn shop charge for Hardi? 3 dollars a sheet?
ccoffer is offline
looking for flooring oppourtunities for the floors General Discussion 11 12-10-2012 02:59 PM
finishing flooring decorative strip zmusashi General Discussion 5 10-24-2012 11:02 AM
problem with epoxy quartz flooring fshrs1 Flooring 4 10-17-2012 04:31 PM
Should we frame flooring joists? DavidReid1985 Flooring 2 10-05-2012 10:31 PM
