Flooring - Flooring - Contractor Talk
Flooring
Old 06-03-2015, 10:08 AM   #1
Expat's Avatar
Trade: Landscape/ Irrigation
Rewards Points: 8
Flooring
I've a question as wood working isn't my trade but have this DIY on my cabin.
I had a couple of mature black cherry trees go down on my property a couple of years ago and had them sawn and now dried to less than 5%. I want to use the planks for flooring. They're 3/4" finished by 6-10" wide and long enough not to need butt joints. The room is only 200' or so square.
As they are up to 15' long I feel that routing or sawing T&G joints might be problematic. Can I use un-glued biscuit joints ever foot or so instead? The sub floor is particle board and I planned on using sub floor adhesive and a brad nailer.
Expat is offline
Old 06-03-2015, 10:35 AM   #2
This space for lease
RangoWA's Avatar
Trade: General
Rewards Points: 4,628
Re: Flooring
I've done a bit of joinery but I'm not an authority. Biscuits are meant to be glued and probably not strong enough dry to do much good. But if you are nailing and gluing the boards down it doesn't seem necessary to me to join them. I think I'd like to pull up a board if it got damaged.
15' of routing or sawing shouldn't be a problem either if you wanted to go that way. You'd just need outfeed rollers for your table, the router could do it with a 1/2" roller bearing guide bit.
RangoWA is offline
The Following User Says Thank You to RangoWA For This Useful Post:
Expat (06-03-2015)
Old 06-03-2015, 12:02 PM   #3
mako1's Avatar
Rewards Points: 1,094
Re: Flooring
Sub floor adhesive and a brad nailer is not a good way to attach 6-10" cherry boards to your subfloor.This will not allow for any wood movement and you will have issues.
You said cabin.Is this a place that will only have heat in the winter while your are there?
mako1 is offline
The Following User Says Thank You to mako1 For This Useful Post:
KAP (06-03-2015)
Old 06-03-2015, 12:46 PM   #4
Expat's Avatar
Rewards Points: 8
Re: Flooring
It is my full time residence although I spend much of the winter overseas. The cabin is heated via wood stove from the ground level and the heat filters up to the second level where the flooring is to be installed.
Is subfloor adhesive not flexible enough? Your choice of attachment is?
Expat is offline
Old 06-03-2015, 12:54 PM   #5
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 94
Re: Flooring
There's a reason most flooring is milled to 5" or less. The wider the plank, the more prone to cupping/humping. If you don't mind the floor not staying dead flat, by all means, your planks will work. But be aware, you're going to get some pretty serious seasonal movement, especially with wood heat.
Particle board sub floor has almost no fastener holding power. Tear it out & replace it with a more suitable subfloor like OSB or plywood.
As for milling the edges, if you've got the edges straight, use a quarter inch slot cutter with top bearing on your router & use a spline to join the planks.
Its all doable, but not easily doable & might not have the results you want.
pinwheel is offline
The Following 2 Users Say Thank You to pinwheel For This Useful Post:
KAP (06-03-2015), MIKE ANTONETTI (06-04-2015)
Old 06-03-2015, 12:55 PM   #6
RangoWA's Avatar
Trade: General
Re: Flooring
I think that's a good point, your wood floor is going to go through dramatic temperature ranges. And humidity probably. Wood loves to move.
RangoWA is offline
Old 06-03-2015, 01:32 PM   #7
KAP's Avatar
Trade: Custom
Rewards Points: 36,642
Re: Flooring
The wider it is, the more movement you can expect...
KAP is offline
Old 06-03-2015, 01:50 PM   #8
Expat's Avatar
Rewards Points: 8
Re: Flooring
Thanks to all.
Actually the sub-floor is Norbord sub flooring - my typo.
I can do the slotted cut and spline, no problem.
Should I use any adhesive at all?
Expat is offline
Old 06-03-2015, 02:02 PM   #9
mako1's Avatar
Re: Flooring
No adhesive but something better than brads.
mako1 is offline
Old 06-03-2015, 02:07 PM   #10
Expat's Avatar
Rewards Points: 8
Re: Flooring
Thanks Mako'
I can countersink screws and plug. 2 screws 16" o.c. ok?
Expat is offline
Old 06-03-2015, 02:09 PM   #11
mako1's Avatar
Re: Flooring
I would think with splines that 24" OC would be fine and save you some work.
mako1 is offline
Old 06-03-2015, 05:12 PM   #12
pinwheel's Avatar
Rewards Points: 94
Re: Flooring
Thanks to all.
You can glue it, but don't expect the glue to hold it dead flat. Wood movement will pull glue loose. If you're going to screw it down & plug it, elongate the holes before putting the screws in to allow the wood to move as it expands & contracts. General rule of thumb I was taught, was most woods can move up to 1/8"/foot.
pinwheel is offline
The Following User Says Thank You to pinwheel For This Useful Post:
Expat (06-03-2015)
looking for flooring oppourtunities for the floors General Discussion 11 12-10-2012 02:59 PM
finishing flooring decorative strip zmusashi General Discussion 5 10-24-2012 11:02 AM
problem with epoxy quartz flooring fshrs1 Flooring 4 10-17-2012 04:31 PM
Should we frame flooring joists? DavidReid1985 Flooring 2 10-05-2012 10:31 PM
