Floor Level Areas Before Hardwoods Installed - Flooring - Contractor Talk
Old 08-15-2018, 12:19 AM   #1
gowings's Avatar
Trade: Remodel and Repairs
Rewards Points: 983
What procedure is preferred to fix some dips in a plywood subfloor before Hardwoods are to be installed. I have some areas a client wants me to level out that are approx 2 ft round 1/8 inch deep before an installer comes in. Older home and I believe the sub floor was installed to cover over an asbestos tile floor. I was going to take out my Ardex feather finish compound and feather out the areas BUT the flooring installer happen to show up to look at the job and said the staples will blow the leveling compound apart .
gowings is offline
Old 08-15-2018, 07:05 AM   #2
madrina's Avatar
Trade: roofing and other envied trades
Rewards Points: 1,278
Re: Floor Level Areas Before Hardwoods Installed
Real hardwoods or manufactured hardwood?
madrina is offline
Old 08-15-2018, 07:09 AM   #3
madrina's Avatar
Pier and beam house? Shim the hell out of it under the plywood decking. Have fun. That's a job you'll wish you had turned down. Unless it's just that one spot...
And be careful under that house. Wires everywhere. My best friend just got electrocuted shimming a pier under one about 6 months ago. Killed him instantly.
madrina is offline
Old 08-15-2018, 02:08 PM   #4
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 412
I like using Luan which can be sanded to feather it, and for a thinner shim the cheapest Linoleum you can find. Scrap works. Staple it down some and the hardwood will keep it pinned in place. Some like to use roofing asphalt rolls...I don't.
Peter_C is offline
Old 08-15-2018, 04:33 PM   #5
avenge's Avatar
Rewards Points: 720
Last time I had to do that I used what was on the jobsite....Ram board in layers.
avenge is online now
Old 08-15-2018, 05:03 PM   #6
Focusing on solutions.
pinwheel's Avatar
I was on a job recently that required a lot of leveling. Contractor used 7/16 osb, stepped down with 2 layers of luan, stepped down to single luan, & to bridge between those steps, he used shingles. Came out good, but man he put a lot of work into leveling.
pinwheel is offline
The Following User Says Thank You to pinwheel For This Useful Post:
Peter_C (08-15-2018)
Old 08-15-2018, 05:22 PM   #7
Peter_C's Avatar
Rewards Points: 412
Pinwheel as you are a Master at hardwoods, what would you consider an acceptable divot in the floor? I suppose it also matters over how long of a distance said divot is. Is there a general rule you follow?
My take on it is the hardwood flooring can flex into minor deviations and most folks would never even notice unless on their hands and knees looking across the floor, or using a longer level. Dead flat floors on a remodel are nothing but a dream...
Peter_C is offline
Old 08-15-2018, 05:30 PM   #8
TheConstruct's Avatar
Rewards Points: 1,174
Joist crowned down between two crowned up. Cedar shingles with the wide ends meeting at the low spot. Glued down with PL, temporarily screwed until the glue set up and then power planed. Definetly a lot of work but beats having a rollercoaster floor.
TheConstruct is offline
The Following User Says Thank You to TheConstruct For This Useful Post:
Peter_C (08-16-2018)
Old 08-15-2018, 09:52 PM   #9
WBailey1041's Avatar
Trade: Gutters
Rewards Points: 1,599
Jiffset
https://www.homedepot.com/p/Jif-Set-...0001/202532185
WBailey1041 is offline
Old 08-16-2018, 12:20 AM   #10
gowings's Avatar
Rewards Points: 983
manufactured
gowings is offline
Hand stack roofs in snow load areas Ninjaframer Framing 25 09-09-2015 11:54 AM
Will Cat6 installed behind carpet baseboard pass inspection? scwalther Low Voltage 22 07-04-2012 09:45 AM
Can A/C be installed in home with boiler system and NO duct work? IHI HVAC 20 08-01-2011 09:59 AM
Oil stain - replacing Timbertech deck board installed w/ concealoc tivopaul Decks & Fencing 6 06-03-2011 10:30 PM
Now installing white oak hardwoods need help! Texwing Flooring 10 02-17-2009 08:16 AM
