Epoxy For Tumbled Marble - Flooring - Contractor Talk
Old 12-20-2012, 09:23 AM   #1
CarpenterSFO's Avatar
Rewards Points: 2,044
Any opinions about epoxy grout for the walls of a tub surround, with tumbled marble? I'm not super-thrilled with the tumbled marble, which I see as a water-absorber, but the H.O. bought it himself, with someone else's advice. It will be sealed well. Urethane grout would be easier, but for availability and schedule reasons I probably need to go with epoxy. Any warnings about epoxy on tumbled marble? Should I seal before grouting?
It's over Kerdi over Hardibacker.
I'd appreciate any advice.
- Bob
Last edited by CarpenterSFO; 12-20-2012 at 10:09 AM. Reason: Needed to mention I was talking about grout
CarpenterSFO is offline
Old 12-22-2012, 07:54 AM   #2
DO IT RIGHT
the rock's Avatar
Trade: hard surface/carpentry/plumbing/electrical
Rewards Points: 75
Re: Epoxy For Tumbled Marble
We have installed thousands of tumbled marble showers and tub surrounds.Epoxy grout will work perfect for you.No need to pre seal as epoxy grout will not stain the stone..Make sure you follow the directions of the Mfg.Good luck.
the rock is offline
The Following User Says Thank You to the rock For This Useful Post:
Floormasta78 (12-22-2012)
Old 12-22-2012, 02:22 PM   #3
Orlando Car
Floormasta78's Avatar
Trade: certified floor covering installer.
Rewards Points: 1,154
I'm the epoxy grout king.. I love using that stuff. I always , and strongly recommend it in kitchen backsplash. You CANNOT GO WRONG.. As far as clean up, use a white scrubby to get into the pits, you won't get too much but enough to get it clean.
http://www.facebook.com/#!/certifiedfloorcovering
Certified Floor Covering
Serving All California
( 510 ) 760 - 6810
Floormasta78 is offline
The Following User Says Thank You to Floormasta78 For This Useful Post:
the rock (12-22-2012)
Old 12-22-2012, 07:58 PM   #4
Thanks for the advice. I've used epoxy with porcelain and ceramic tiles before, but not with stone. I had started to think of urethane as being the replacement for epoxy, but it's really not entirely. In this case, in addition to availability issues, the bath needs to be in service a couple days after grouting, which I believe is a point in favor of epoxy instead of urethane.
Burning the candle at both ends to get an owner into his house before the New Year. Tiled today, will grout Monday and Wednesday.
Thanks again.
- Bob
- Bob
Old 01-17-2013, 11:41 AM   #5
Just following up to say thanks. I'm not sure what I was worried about; the project is done, the epoxy and tumbled marble are looking and functioning great. The H.O.'s happy, too.
- Bob
The Following User Says Thank You to CarpenterSFO For This Useful Post:
Floormasta78 (01-17-2013)
Old 01-17-2013, 11:46 AM   #6
astor's Avatar
Trade: FI
Rewards Points: 704
pics Bob?
astor is offline
Old 01-19-2013, 12:03 AM   #7
Originally Posted by astor View Post
pics Bob?
Photos before sealing. It was a condo remodel with everything new in the bath. The owner had purchased the mural beforehand, and wanted it installed in the bath. But the folks who sold it hadn't mentioned, in fact they didn't know, that it was acrylic paint, not glazed. It wouldn't have lasted in the shower/tub, so we put it on the wall outside.
Epoxy for tumbled marble-bath-w-mural-1-version-2.jpg   Epoxy for tumbled marble-bath-w-mural-2-version-2.jpg
- Bob
Old 01-19-2013, 09:26 AM   #8
DO IT RIGHT
the rock's Avatar
Rewards Points: 75
Nice workmanship.
the rock is offline
CarpenterSFO (01-19-2013)
Garage Floor Epoxy We Fix Houses Painting & Finish Work 9 12-31-2012 11:37 AM
Best Epoxy Repair for Marble / Terrazzo We Fix Houses Tiling 0 10-25-2012 04:33 PM
problem with epoxy quartz flooring fshrs1 Flooring 4 10-17-2012 04:31 PM
Marble Wall / Floor Grout Maintenance ? We Fix Houses Tiling 4 08-14-2012 12:00 PM
Moisture Problems with Carrera Marble and Epoxy Grout Tallguy1 Tiling 4 10-13-2009 09:50 PM
