Engineer Floor Issue. Is There Filler? - Flooring - Contractor Talk
Old 04-11-2019, 01:56 PM   #1
woodspike's Avatar
Rewards Points: 688
Have a large home where they're taking a large island out.
The engineer following has to be filled in this area (about 4x8 feet)
It's not lining up on the last run.
I have a 1/16 or 3/32 space left.
It's a drift wood style . Lots of grey/dark brown/ light brown.
Is there any way to nicely fill that line?
It's right in the middle of this room.
I don't think grey caulk will look good. Or tan.
Suggestions)
woodspike is offline
Old 04-11-2019, 02:00 PM   #2
woodspike's Avatar
Rewards Points: 688
Re: Engineer Floor Issue. Is There Filler?
Can you mix different color caulks together to make a different color ?
Old 04-11-2019, 02:08 PM   #3
John the Builder
SmallTownGuy's Avatar
Rewards Points: 4,508
Suggestions)
You are working on a home with engineered flooring.
The kitchen island was removed.
This leaves an area approx 4 x 8 feet that had to be filled with the same flooring product.
When this was done, the last run left a gap approx 1/16 to 2/32 wide, right in the middle of the room.
What can be done?
I don't have an answer. Seems to me, if you properly staggered the cut ins, and used the same product, it would HAVE to line up.
Me, I'd be getting a piece of 2 by lumber, wrapping it with a towel or similar and bang on those infill boards until the gap reduced and was spread more evenly between the runs.
SmallTownGuy is online now
The Following User Says Thank You to SmallTownGuy For This Useful Post:
hdavis (04-11-2019)
Old 04-11-2019, 03:28 PM   #4
Lettusbee's Avatar
Rewards Points: 908
Gaps wont line up if island was not parallel to wall where layout started
Sent from my SM-N960U using Tapatalk
Lettusbee is offline
The Following User Says Thank You to Lettusbee For This Useful Post:
pinwheel (04-11-2019)
Old 04-11-2019, 04:16 PM   #5
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 15,257
Any chance it will acclimate and eventually fit better?
MarkJames is online now
Old 04-11-2019, 10:31 PM   #6
woodspike's Avatar
Rewards Points: 688
can`t tell you why .
i totally understand what your saying .it seemed like the lines weren't running perfectly straight. so as i put a line in , it wouldn't lay right on each end. like there was a bow going on
but there is a small line-gap i need to deal with.
i`ll check with a flooring company , this can`t be first time its happened
Old 04-12-2019, 06:36 AM   #7
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 5,228
Take it out and do some accent area with Herringbone and a strip of border all around.
Big Johnson is offline
Bull Trout (04-12-2019)
Old 04-13-2019, 12:48 AM   #8
rblakes1's Avatar
Rewards Points: 3,344
I'm reading this as you put ask the rows in, and after the last new row, there's a small gap to the original floor? That should be easily taken up by laying a couple rows a hair loose. Over 4' that's like the thickness of a playing card each row, it wouldn't even be noticeable
-Rich
rblakes1 is offline
The Following User Says Thank You to rblakes1 For This Useful Post:
SmallTownGuy (04-13-2019)
Old 04-13-2019, 12:49 AM   #9
rblakes1's Avatar
Is everything dry fit, or already installed?
-Rich
rblakes1 is offline
Free standing tub filler - D in Mpls Plumbing 1 11-04-2017 08:33 AM
Architect, Engineer, Blueprints, Contractor Responsibility?? shesbros General Discussion 4 03-14-2017 09:48 AM
auto box filler icerock drywall Drywall 6 09-06-2012 02:52 PM
How many actually involve a Structural Engineer on Projects rdr8887 General Discussion 32 07-24-2012 06:49 PM
