Eliminating Subfloor Squeaks For Good - Flooring - Contractor Talk
Old 04-23-2019, 01:22 PM   #1
Joe65070's Avatar
Trade: Handyman
Rewards Points: 2
We have a 26 year old Burnstead house in the Pacific Northwest. The floors were a bit squeaky when we bought the house 5 years ago. The squeaking has increased quite bit in the years since we bought the house. Pretty much the entire second floor has squeaks. We are hoping to fix the squeaky subfloors when we pull out the the old carpet, before putting in a new carpet.
The solution advised on the Internet seems to be putting in screws about 12 inches apart to properly fasten the subfloor boards to the joists. Does that sound like the right and complete solution?
- Should the screws be closer together than being 12 inch apart?
- Should we be using any other material in addition to the screws, for example, injecting liquid nails / glue? I am not sure if glue was used when the subfloors were originally installed.
- Subfloor appear to be 1/2 or 3/4 inches thick plywood. Should I consider adding another layer of subfloor to make sturdier while screwing it down?
- Will the squeaks go away after using screws or will they eventually come back - how soon?
Joe65070 is offline
Old 04-23-2019, 08:19 PM   #2
rblakes1's Avatar
Rewards Points: 3,344
Re: Eliminating Subfloor Squeaks For Good
2" grk screws if you want to do it by hand, or you could pick up a Simpson quick drive screw gun with collated screws if you want to save your back.
I go every 8" or so. In persistent spots, screw until the squeak goes away
I wouldn't bother attempting to inject glue. If it's 3/4, that's fine, I've never seen carpet laid over just 1/2"
-Rich
rblakes1 is offline
The Following User Says Thank You to rblakes1 For This Useful Post:
Joe65070 (04-23-2019)
Old 05-05-2019, 03:55 PM   #3
woodspike's Avatar
Rewards Points: 688
i have good results with this method
woodspike is offline
The Following 4 Users Say Thank You to woodspike For This Useful Post:
avenge (05-05-2019), Bull Trout (05-05-2019), greg24k (05-07-2019), Jay hole (05-05-2019)
Old 05-05-2019, 04:50 PM   #4
Jay hole's Avatar
Trade: General contractor
Rewards Points: 1,683
I have a client that had really squeaky floors and we installed 1/4 backer board in thin set and its been squeak free for years!!!!
Jay hole is online now
Old 05-07-2019, 12:27 AM   #5
3bar's Avatar
Trade: carpenter
Rewards Points: 492
put screws, and the more the better.
and avoid screws where the very top has a smooth shank. could squeak more. i'd probably use an exterior galvanized srcew as they have a rougher finish.
3bar is offline
Old 05-07-2019, 05:42 AM   #6
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 5,232
I’d use these, you might get away with #8 but the #10’s have some serious holding power:
https://www.menards.com/main/hardwar...4423023661.htm
Big Johnson is offline
Old 05-07-2019, 05:55 AM   #7
General Contractor
greg24k's Avatar
Rewards Points: 8,420
Remove the second floor and re-frame the floor sub-structure, glue down new 3/4" plywood and you only need to put screws every 6" O.C along the edges and 12" O.C over intermediate supports.
greg24k is offline
The Following 2 Users Say Thank You to greg24k For This Useful Post:
heavy_d (05-07-2019), rblakes1 (05-07-2019)
Old 05-07-2019, 06:43 AM   #8
rselectric1's Avatar
Rewards Points: 884
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer that you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractors to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If you're not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.DIYChatroom.com/register.php/
We apologize for any inconvenience that this may have caused. This thread has been closed.
rselectric1 is offline
eliminating radiators Tom M Plumbing 2 05-30-2015 08:27 AM
eliminating spray gun splattering saucedo80 Painting & Finish Work 11 11-02-2010 01:47 PM
eliminating switched outlet in a room pzeiler Electrical 2 04-19-2010 11:50 PM
Eliminating moisture in walls CharlesD Windows, Siding and Doors 2 05-25-2009 10:59 PM
eliminating Power vents 1contractor Plumbing 1 03-05-2009 02:09 PM
