Drilling Porcelain Tile - Flooring - Contractor Talk
Old 11-18-2011, 01:28 PM   #1
wyoming 1's Avatar
Trade: General contractor
Rewards Points: 520
I have to mount some fixtures (towel bars Ect.) to some porcelain wall tile and I was wondering what to drill it with. I have tried in the past with either carbide tipped bits or "tile" bits. They usally get so hot the carbite or tip falls out. Do they make a Diamond tip for porcelain?
wyoming 1 is offline
Old 11-18-2011, 02:34 PM   #2
Chief Reporter of Spam
Tech Dawg's Avatar
Trade: Kitchen and Bathroom Remodeling
Rewards Points: 1,290
Re: Drilling Porcelain Tile
Use an XCore bit in a rotozip for your pilot holes... Its pretty clean if ya got a steady hand
Todd
Alone Eagle Remodeling, LLC
Tech Dawg is offline
Old 11-18-2011, 02:51 PM   #3
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
You need a diamond coated bit. Carbide won't do it
Angus
angus242 is offline
The Following User Says Thank You to angus242 For This Useful Post:
Splinter hands (11-19-2011)
Old 11-18-2011, 03:29 PM   #4
manipulator of wood
I Mester's Avatar
Trade: general contractor
diamond bit. carbide u will be drilling away forever and going through endless bits.
I Mester is offline
The Following User Says Thank You to I Mester For This Useful Post:
Tom M (04-22-2012)
Old 11-18-2011, 03:56 PM   #5
Paul
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Rewards Points: 1,004
I have a set of diamond bits specifically for that task. Lennox actually makes a pretty decent set that you can pick up from Lowes for about 50 or 60 bucks. Four bits from 1/8 up to 3/8 I believe. Mine have held up very well. I use two drills when I am doing it. A small carbide in one drill just to get a pilot hole for the diamond bit. The diamond core bits tent to walk a bit on hard porcelain.
Precision Floors
(772) 237-9900
PrecisionFloors is offline
The Following 2 Users Say Thank You to PrecisionFloors For This Useful Post:
astor (11-18-2011), ROVACON (11-18-2011)
Old 11-18-2011, 07:12 PM   #6
KnottyWoodwork's Avatar
Trade: Trade work for money.
Rewards Points: 514
I'm not a tile guy by any means, but I use the diamond tipped bits at a slow speed. I use a 20oz bottle with a small hole in the cap for a lubrication applicator. It doesn't go quick, it's like drilling through metal. In a pinch I've used the arrowhead looking bits from lowes, they didn't seem too bad.
KnottyWoodwork is offline
Old 11-18-2011, 07:27 PM   #7
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
If you have time to order online & have shipped:
https://www.tiletools.com/department/hole-saws-54.cfm
Angus
angus242 is offline
Old 11-18-2011, 07:32 PM   #8
Want to play a game?
CrpntrFrk's Avatar
Trade: I do that too!
Rewards Points: 4,196
I am very sure the recommendations these gents have given you is what you need to lean to.
But.... if you are stuck with those crappy bits try spraying the bit while drilling with a spray bottle to keep it cool and it will get you thru the day.
CrpntrFrk is offline
Old 11-18-2011, 08:15 PM   #9
D.S.I.'s Avatar
Trade: REMODELING
Rewards Points: 277
Our friends at HD have a kit with they same generic diamond bit you find at any store, but it has a plastic container that keeps water on the bit. It comes with 10 double sided pieces of tape, one per hole, to hold the cup on. I ran out of tape before the bit was spent. Only like $15 for 1/4" & 5/16" too. I think the brand was Brutus or something like that.
D.S.I. is offline
Old 11-18-2011, 08:19 PM   #10
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
It is Brutus and made in China
If you go to the tool section, they also carry Ridgid diamond coring bits. A little more expensive but they are better than the Chinese crap and are made in the UK.
Angus
angus242 is offline
Old 11-18-2011, 10:40 PM   #11
wyoming 1's Avatar
Rewards Points: 520
Thanks Guys I have some time so I think I will order some. The closest HD is 2.5 hours away and the closest lowes is 4 hrs away.. got to love Wyoming.
Old 11-18-2011, 10:56 PM   #12
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Then the internet is your friend! Can't beat $5 shipping!
Angus
angus242 is offline
Old 11-19-2011, 12:12 AM   #13
Splinter hands's Avatar
That isn't a bad thing.
Splinter hands is offline
Old 04-17-2012, 11:05 PM   #14
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,500
http://menards.com/main/tools-hardwa...88-c-10079.htm
Thought would revive the thread and add a bit I bought for some hard ass porcelain I needed to drill through for my shower glass install. Bought this bit after I burned up the $34 xbit for my rot zip. This thing worked great! Used a small spray bottle to keep it cool while I drilled!
overanalyze is offline
Old 04-17-2012, 11:39 PM   #15
Orlando Car
Floormasta78's Avatar
Trade: certified floor covering installer.
Rewards Points: 1,154
I use CONCRETE DRILL BITS by bosh.
They last longer than any especially bit.
http://www.facebook.com/#!/certifiedfloorcovering
Certified Floor Covering
Serving All California
( 510 ) 760 - 6810
Floormasta78 is offline
Old 04-18-2012, 07:38 PM   #16
Groutface
Groutface's Avatar
Trade: flooring installer
Rewards Points: 524
Looks great!....thumbsup
Groutface is offline
The Following User Says Thank You to Groutface For This Useful Post:
Floormasta78 (04-22-2012)
Old 04-18-2012, 07:48 PM   #17
Always Learning
I tried the sds bits and they didn't touch this porcelain for some reason. I have had luck in the past with them.
The little core bit cut through real smooth.
Old 04-22-2012, 10:13 AM   #18
Orlando Car
$28 dollars, worth every penny. Drilled thru this porcelain like drilling thru soft wood.. Hilti bits are great
( 510 ) 760 - 6810
Old 04-22-2012, 10:28 AM   #19
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Running water to the cutting surface will reduced the chance of breaking tile, give you a smoother cut and extend the life of your coring bit.
+ YouTube Video
Angus
angus242 is offline
The Following 5 Users Say Thank You to angus242 For This Useful Post:
Dan_Watson (04-22-2012), Floormasta78 (04-22-2012), goneelkn (04-22-2012), TNTRenovate (04-22-2012), We Fix Houses (04-22-2012)
Old 04-22-2012, 10:58 AM   #20
Orlando Car
I carry a spray bottle. Works great in small areas
( 510 ) 760 - 6810
tile coming up clean [email protected] Tiling 14 07-18-2011 10:49 AM
ADS tile for driveway bridge mcdanie1 Excavation & Site Work 4 06-26-2011 09:26 PM
Tile Over Gypcrete Golden Rule Tiling 6 11-26-2010 04:00 PM
Cutting Porcelain Tile jerome8283 Flooring 7 03-24-2008 08:45 PM
Porcelain Tile jerome8283 Remodeling 10 10-08-2006 11:08 AM
