Does SLC Shrink? - Flooring - Contractor Talk
Does SLC Shrink?
Old 09-30-2018, 03:43 PM   #1
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 5,684
Does SLC Shrink?
If I pour SLC on a floor that has a 1 1/2" jump in elevation, like a little curb, will it shrink a little after pouring to level things out, and maybe still have a 1/8" jump at that spot?
Half of all people are below average.
Golden view is online now
Old 09-30-2018, 03:44 PM   #2
edward trowelhands
Trade: Diplomat
Re: Does SLC Shrink?
No need for other SLC tips, I've successfully used it in "normal" cases.
Old 09-30-2018, 06:34 PM   #3
tjbnwi's Avatar
Rewards Points: 1,296
I do not believe it shrinks.
You could do it in lifts with proper priming between lifts.
tjbnwi is online now
Golden view (09-30-2018)
Old 09-30-2018, 07:30 PM   #4
Dan_Watson's Avatar
Rewards Points: 2,540
How big of an area?
Dan_Watson is online now
Old 09-30-2018, 07:51 PM   #5
edward trowelhands
Trade: Diplomat
Originally Posted by Dan_Watson View Post
How big of an area?
200 sf. old slab with a hump in the middle. 1/4 of slab was replaced after plumbing and is level, but falls off up to an inch and a half adjacent to the old slab in places.
Old 09-30-2018, 08:35 PM   #6
TheConstruct's Avatar
Rewards Points: 720
I did 20sqft a little while back, brought up lowest point 1 1\2" in two pours with primer after first pour. I dont believe it shrunk, negligable if it did as it was still to the top of the form I had at the exterior door RO.
TheConstruct is online now
5000 psi non shrink grout to level a sill BocaR Windows, Siding and Doors 3 01-26-2018 09:20 PM
45 cut boards ends shrink unevenly heavy_d Decks & Fencing 44 06-19-2016 07:41 AM
Splice tape/heat shrink CarpenterSFO Electrical 4 10-24-2013 09:36 AM
shrink ray TimelessQuality Off Topic (Non Trade) 2 05-19-2010 11:13 PM
How much shrink will you get with compaction cdub Excavation & Site Work 17 12-13-2008 05:20 PM
