Cutting 18” X 36” Vinyl Tile - Flooring - Contractor Talk
Old 04-20-2019, 07:31 PM   #1
JonM's Avatar
Rewards Points: 1,242
I am looking for some ideas in order to scribe and break 18” x 36” vinyl tile (commercial grade) I am thinking of some type of jig or any other offerings you folks may have. I have over 5000 sq ft with a large number of partition walls for a dentist office.
Thanks in advance
JonM is online now
Old 04-21-2019, 07:40 PM   #2
spazman
spazman's Avatar
Trade: floorcovering installer
Rewards Points: 108
Re: Cutting 18” X 36” Vinyl Tile
How thick is it? Depending on what its made of, some can be heated with a heat gun and cut with a utility knife. Others need to be sawn. I use a jigsaw for cuts with curves or a lot of ins and outs. Get a diamond blade made for ceramic tile. You might check with a tool rental place to see if they have a shear big enough for what you are working with to do the straight cuts at the walls. It’s way quicker than sawing and not as messy.
spazman is offline
Old 04-21-2019, 10:00 PM   #3
Designer/Contractor
Rio's Avatar
Rewards Points: 1,876
"see if they have a shear big enough for what you are working with to do the straight cuts at the walls."
That's what I was thinking, seems like it would be a good way to go.
Rio is offline
Old 04-22-2019, 04:34 AM   #4
JonM's Avatar
It's only 3mm thick vinyl, similar to 12 x 12 tiles you see on the floors of stores.
JonM is online now
Old 04-22-2019, 06:33 AM   #5
BeforeChristoff's Avatar
Trade: RENOVATIONS
Rewards Points: 118
Thanks in advance
There are a number of vinyl tile cutters on the market. Lowes for one.
BeforeChristoff is offline
Old 04-22-2019, 07:22 AM   #6
rrk's Avatar
Rewards Points: 1,636
The only method I have seen used was a propane torch with the shorter squatty bottle. They leave it on, run the tile over it and cut it, they were working fast also. I think there was a shear there also but most of the time they used the torch which they moved with them on a dolly.
rrk is online now
Old 04-23-2019, 04:41 PM   #7
JonM's Avatar
This is what I came up with
JonM is online now
Old 04-23-2019, 06:21 PM   #8
rrk's Avatar
they cut much easier if they are very very warm
rrk is online now
Old 04-29-2019, 04:12 PM   #9
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Framing, siding, decks
Rewards Points: 13,540
I bet that a set of nibblers would work wonders
A&E Exteriors is offline
Old 04-29-2019, 04:14 PM   #10
https://www.jbtoolsales.com/malco-ts...xoCbJMQAvD_BwE
Old 04-29-2019, 04:33 PM   #11
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 1,202
For like commercial floor , Armstrong 1/8 12x12, I have use a carbide scribe tool made for it. Scribe and snap worked great.
Randy Bush is offline
The Following User Says Thank You to Randy Bush For This Useful Post:
asevereid (04-30-2019)
Old 04-29-2019, 08:55 PM   #12
TheConstruct's Avatar
Rewards Points: 1,008
Watch your fingers! I made myself a nice little fillet o' finger doing the same thing about a month ago.
TheConstruct is offline
Old 06-13-2019, 09:04 AM   #13
jmalehorn's Avatar
Trade: Flooring
Rewards Points: 16
For irregular shapes and scribes I would usually just use a heat gun to heat up and cut with a utility knife
jmalehorn is offline
The Following User Says Thank You to jmalehorn For This Useful Post:
rusty baker (06-13-2019)
Health Side effects of cutting Vinyl Siding MarkGreer General Discussion 19 09-11-2014 11:02 AM
Ceramic tile in bathroom with vinyl flooring clau24 Tiling 5 11-11-2013 06:46 PM
homeowner has linoleum over concrete wants vinyl tile Blindsman Flooring 19 01-24-2011 08:08 PM
Vinyl Limestone Enriched Luxury Tile BHR Flooring 0 08-04-2009 08:32 PM
