Commercial Kitchen Grout - Flooring - Contractor Talk
Old 02-14-2015, 12:35 AM   #1
aptpupil's Avatar
Rewards Points: 1,894
Regrout job in commercial kitchen. Will do job during off hours (10p-8a), but next morning it will receive plenty of heavy traffic. I can put down melamine to minimize abuse, but if you've worked in a kitchen you know how it goes with spilled water, keg deliveries, etc. One portion is in walk-in frig so it will be cold and humid shortly/during after install.
Question is: what grout would you go with? Anything that will work?
aptpupil is offline
Old 02-14-2015, 06:55 AM   #2
Doer of Many Things!!!
gideond's Avatar
Trade: Paint and Floor Covering Retailer
Rewards Points: 1,135
Re: Commercial Kitchen Grout
Laticrete Spectralock 2000 IG. This is the kind of application it's made for.
gideond is offline
The Following 3 Users Say Thank You to gideond For This Useful Post:
aptpupil (02-18-2015), CarpenterSFO (02-14-2015), Floormasta78 (02-17-2015)
Old 02-14-2015, 07:30 AM   #3
MIKE ANTONETTI's Avatar
Trade: FLOORING CONTRACTOR
Rewards Points: 3,514
Company I use to work for did all Publix supermarkets, deli/meat/bakery depts. Along with the storage and distribution centers. They bought epoxy direct from manufacturer. Different hardners would give you varying working times, so you mix smaller areas before setup time in a 4-1 ratio. Depending on temperature faster set when hot,vice versa. Didn't want to bond to wet areas and grease of course.
MIKE ANTONETTI is offline
The Following User Says Thank You to MIKE ANTONETTI For This Useful Post:
charimon (02-15-2015)
Old 02-14-2015, 12:32 PM   #4
CarpenterSFO's Avatar
Rewards Points: 2,044
SpectraLock IG might be the best grout choice, but you aren't going to meet SpectraLock's time-to-service requirements (http://www.laticrete.com/Portals/0/d...ts/LDS0300.pdf). I don't think you'll meet anyone else's requirements, either.
- Bob
CarpenterSFO is offline
The Following User Says Thank You to CarpenterSFO For This Useful Post:
Old 02-15-2015, 12:13 AM   #5
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,268
I can't think of any. He needs to cover it for a week to be sure.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
The Following User Says Thank You to TNTRenovate For This Useful Post:
CarpenterSFO (02-15-2015)
Old 02-15-2015, 07:28 AM   #6
There's got to be a product for the need! The epoxy we used would set in under 5 minutes. You had to do small areas per mix. We used the black but found out adding color separately you could control the amount of pigment and use way less in order to make cleanup easier.
I've been out of that loop at least 10 years now, I'm sure there have been improvements.
Craig Harimon was going to get into this, not sure if he wants to divulge proprietary secrets.
Old 02-15-2015, 01:07 PM   #7
GO Remodeling's Avatar
Rewards Points: 96
Chem-crete makes Chem-freezer epoxy grout for freezers. They recommend a primer, I think. Never used the products . Just did an interenet search.
GO Remodeling is offline
The Following User Says Thank You to GO Remodeling For This Useful Post:
MIKE ANTONETTI (02-15-2015)
Old 02-15-2015, 01:13 PM   #8
Hair Splitter
Trade: General
I found this one CEG-Lite from Custom Building Products. 7 hour cure time before light traffic.
http://www.custombuildingproducts.co.../ceg-lite.aspx
Old 02-15-2015, 07:30 PM   #9
I think that's about what SpectraLock IG's is, too. It would probably work, but there'd be no warranty protection. How much that matters would depend on the customer, for me.
- Bob
Old 02-15-2015, 09:11 PM   #10
ccoffer's Avatar
Rewards Points: 1,140
Isn't this situation why that furan stuff exists?
ccoffer is offline
Old 02-16-2015, 06:29 AM   #11
As far as I know Furan is for different types of chemical resistance. I've done it once I believe the area was where they cleaned out milk tank trucks.
I'd say fast setting epoxy, if it gets wet it may turn a little white, but it's hard to get out the door before places open up and go into operation. It needs to look pretty before you go, after that it's whatever. You just want to make sure it doesn't track when walked on.
Old 02-16-2015, 06:44 AM   #12
gideond's Avatar
CEG-Lite is a nightmare to work with anyway. At least compared to Spectralock or Opticolor. Unless they've updated the formula in the last couple of years.
gideond is offline
The Following User Says Thank You to gideond For This Useful Post:
Old 02-16-2015, 08:21 AM   #13
Hair Splitter
Trade: General
Why is it a nightmare?
Old 02-17-2015, 06:48 AM   #14
gideond's Avatar
Most of the easy epoxies use sand as the solid component. The CEG Lite actually used a sanded grout mixed with epoxy. It was a nasty sticky nightmare to apply and damn near impossible to get clean. Now that was 2 or three years ago, maybe longer if I'm not recalling correctly. They could have updated the formula by now to make it more like the competition. We only used it once and would never use it again.
gideond is offline
Old 02-17-2015, 07:00 AM   #15
I agree with your conclusion. The manufacturers tweak their formulas because they don't work in the real world, New and Improved are code for that old stuff didn't work correctly.
A letter of apology, an explanation of new formula, and some freebies may help.
Old 02-17-2015, 11:19 AM   #16
improving homes
platinumLLC's Avatar
Trade: Roofing/Remodeling
Rewards Points: 352
Would TEC power grout work for something like this? It says open to traffic in 4 hours. I've used it for some jobs and really like it but never for a commercial kitchen that needs to be walked on in a couple hours. Maybe those with more knowledge can say if it will work or not.
http://www.tecspecialty.com/products...l#.VONplfnF-50.
platinumLLC is offline
Old 02-17-2015, 02:46 PM   #17
Not for areas of grease and cleaners, grease and cleaners will destroy portland/hydraulic grout. I've seen holes in the ground in between hollowed out grout joints.
Deep fat fryers are notorious for these areas needing regrout. I personally didn't like that type of work, though I didn't get the profit, just the hourly rate.
Old 02-19-2015, 10:58 PM   #18
charimon's Avatar
Trade: Tile and Tool junkie
Rewards Points: 1,168
http://www.laticrete.com/portals/0/tds/tds144.pdf
here is some info
"The key is to allow only the complexity that the customer is willing to pay for."
charimon is offline
Grout or silicone ? power Masonry 6 04-21-2013 06:16 AM
If you were a commercial builder, would you pay 10% for referrals? Brandon L Business 73 12-06-2012 11:44 AM
Marble Wall / Floor Grout Maintenance ? We Fix Houses Tiling 4 08-14-2012 12:00 PM
Google Seminars For Success... Ivinni Marketing & Sales 193 02-07-2009 08:22 PM
bouncy kitchen floor, will grout crack? kmd Tiling 3 01-26-2007 10:23 PM
