Cleaning Concrete Slab/Tack Strip Nail Removal - Before Installing Carpet - Flooring - Contractor Talk
Old 07-04-2019, 12:52 PM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 458
Pulled old carpet that had a lot of possible mold (urine stains?) and nicotine coming through the old foam pad. Leaving dark splotches on the concrete.
Might bleach do the trick?
Removing tack strip nails has scalloped the slab in some areas (stopped removing for now, so there are many nails left standing with no strips). Don't carpet people normally just go right over these "pullouts"? If the surface has to be patched, which I doubt, I'll hold off on any sealing if concrete -- yet, what type of sealer should be applied over concrete on grade?
Suggestions on treatment?
artinall is offline
Old 07-11-2019, 08:09 PM   #2
artinall's Avatar
Rewards Points: 458
Re: Cleaning Concrete Slab/Tack Strip Nail Removal - Before Installing Carpet
Pic of removed nails - by pulling.
Angle grinder doesn't seem feasible. Would be a heck of a lot of concrete dust or sharp edges left at top.
I'm guessing this is one reason for the change over to carpet adhesive.
Cleaning Concrete Slab/Tack Strip Nail Removal - Before Installing Carpet-tackstrip-nail-removal-7.11.19.jpg
artinall is offline
Old 07-11-2019, 08:21 PM   #3
Fire up the BBQ
griz's Avatar
Rewards Points: 438
lots of guys use an angle grinder to cut those nails.
floor guys will patch if necessary.
if they want to do it make certain it's not an extra.
use a product called "scoe10x" for the urine.
from experience bleach doesn't work so good.
griz is online now
artinall (07-11-2019)
Old 07-11-2019, 08:42 PM   #4
rrk's Avatar
Rewards Points: 3,316
Hit the nails sideways with a hammer, they will break or come out
Very easy
rrk is offline
Old 07-11-2019, 08:44 PM   #5
hdavis's Avatar
Rewards Points: 1,556
Bleaching a large area inside will get you chlorine for quite awhile. It isn't recommended.
hdavis is offline
Old 07-11-2019, 08:55 PM   #6
artinall's Avatar
Rewards Points: 458
Why's that?
You mean in the air (lungs) or on the concrete?
artinall is offline
Old 07-11-2019, 09:02 PM   #7
Fire up the BBQ
griz's Avatar
Rewards Points: 438
it is an irritant to eyes, mucous membranes & lungs.
other products are available that will give you superior results.
griz is online now
hdavis (07-11-2019)
Old 07-11-2019, 09:05 PM   #8
artinall's Avatar
Rewards Points: 458
Any in particular maestro?
artinall is offline
Old 07-11-2019, 09:07 PM   #9
Fire up the BBQ
griz's Avatar
Rewards Points: 438
start here:
https://www.scoe10x.com/reviews?gcli...BoCBUIQAvD_BwE
griz is online now
Old 07-11-2019, 09:15 PM   #10
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 888
When did bleach become the standard answer for mold ?,
Still "Shakin" the tree boss
sunkist is offline
Old 07-11-2019, 09:36 PM   #11
hdavis's Avatar
Just before people gassed themselves out....
hdavis is offline
Old 07-11-2019, 09:45 PM   #12
Idothat's Avatar
Trade: Home improvement of all types
Rewards Points: 654
Itís cheap , readily available , and it works.
Idothat is online now
Old 07-11-2019, 10:01 PM   #13
Fire up the BBQ
griz's Avatar
Rewards Points: 438
to whiten clothes....
griz is online now
Old 07-11-2019, 10:07 PM   #14
Idothat's Avatar
Rewards Points: 654
Bleach haters
The Following User Says Thank You to Idothat For This Useful Post:
griz (07-11-2019)
Old 07-12-2019, 06:29 AM   #15
artinall's Avatar
Rewards Points: 458
Bleach haters
Chlorine - this mainly for when its wet/going down/drying?
Shouldn't all be okay within a day or so?
artinall is offline
Old 07-12-2019, 06:57 AM   #16
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
Me - just use ammonia straight on spots, cut with water for the main area, then rinse/vacuum up with a wet/dry vac.
Nowadays, there's the enzyme products. Much easier on the human applying them.
SmallTownGuy is offline
Old 07-12-2019, 09:55 AM   #17
Idothat's Avatar
Rewards Points: 654
Iíve had no problems using bleach to remove surface mold/mildew to prepare surfaces for painting . Because of its caustic nature and poisonous fumes , it should be used sparingly indoors .
Bleach has its drawbacks and limitations. Mainly it can damage many organic materials ( such as wood and natural fabrics ) and will react with iron and other metals and can cause severe corrosion . Good ventilation is a must for indoor use.
Bleach has been my go to for mildew removal, for paint prep , because it is cheap , easy to find , and has immediate results .
I usually dilute bleach with water, 10 parts water to 1 part household bleach , and rinse with clean water . Ventilation is a must , and fumes will quickly dissipate .
I do not know if it will clean your stained concrete , based on my experience, I would test it and see.
There are certainly safer options ,for both the surfaces being treated and the people exposed to the fumes . Still , I have not found more effective options for the quick removal of surface mold and mildew.
Not trying to be contrary, only sharing my experience
Old 07-12-2019, 10:04 AM   #18
VinylHanger's Avatar
Rewards Points: 11,540
Bleach doesn't get rid of mold, it just bleaches it.
Lots of easy to use and effective products out there that work and don't have any bad side effects.
VinylHanger is online now
Old 07-12-2019, 10:13 AM   #19
Idothat's Avatar
Rewards Points: 654
I donít disagree that there are other products.
It would be nice if you share with us what they are , and your experience with using them
artinall (07-12-2019)
Old 07-12-2019, 10:25 AM   #20
hdavis's Avatar
Sodium percarbonate kills mold and mold spores. It's used in oxy type cleaners and deck cleaners. It also used to be part of the Microbium fogging solution, but I think that has been switched to just sodium carbonate.
hdavis is offline
Idothat (07-12-2019)
