Cement Backer Board Over Concrete Slab - Flooring - Contractor Talk
Old 12-20-2010, 06:44 PM   #1
gtimk4's Avatar
Trade: designer
Hi! All, I have a question regarding the hardie cement backer board apply on concrete slab.
The kitchen that Im working on has concrete slab, Im putting a 3/8 porcelain tile in the kitchen floor. I want to raise the floor as much as possible to match the adjacent living room floor level (about 1-1/8).
So Im planning to apply thin set over concrete slab, then put hardie backer board over it, then lay down thin set on top, and put the 3/8 porcelain tile at last. (the whole assembly may not be 1-1/8 but close enough for me)
I know that hardie manuf. wont warranty their product if it applies on the concrete slab directly. I also know that many people in the forum points out that I should not do it either. Here are my questions:
1) If I dont care about the factory warrant, do you guys think that it is OK to use hardie backer board over concrete? If not, why?
2) How do I secure the board to the slab, would thinset be enough, or do I need to put additional screws to the slab?
3) What screw should I use?
4) What is the better way to raise the floor other than using backer board? I try not to use self-leveling concrete or similar method since it is too difficult for me to do. Do you guys have other recommendation?
Thanks a lot for your help
gtimk4 is offline
Old 12-20-2010, 06:47 PM   #2
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Re: Cement Backer Board Over Concrete Slab
I don't see a big issue going directly over a clean concrete slab.
However, using CBU over concrete is a big no-no. If you need to raise the height, use a SLC (self-leveling compound).
Angus
angus242 is offline
Old 12-20-2010, 07:10 PM   #3
Mike Finley's Avatar
Trade: Bathroom Remodeling
Rewards Points: 2,000
He said leveler is too hard for him to do.
Easy is what he needs.
I'd just lay all the hardi down and duct tape the joints.
Mike Finley is offline
Old 12-20-2010, 07:38 PM   #4
Chief Reporter of Spam
Tech Dawg's Avatar
Trade: Kitchen and Bathroom Remodeling
Rewards Points: 1,282
Mike, I'll bet ya a roll of duct tape that Angus will disable this conversation and send it to the DIY chatroom....
Todd
Alone Eagle Remodeling, LLC
Tech Dawg is offline
Old 12-20-2010, 09:08 PM   #5
Paul
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Rewards Points: 1,004
No. Packaging tape is what you want to use. It's like a moisture barrier too
Precision Floors
(772) 237-9900
PrecisionFloors is offline
Old 12-20-2010, 09:40 PM   #6
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,654
two layers of tile, duh.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 12-20-2010, 09:53 PM   #7
Flooring Installer
rusty baker's Avatar
Trade: flooring
Rewards Points: 86
Just use cardboard, cheaper and it's going to fail anyway.
Flooring installer since 1973
Armstrong certified
rusty baker is offline
Old 12-20-2010, 10:15 PM   #8
Builder/Remodeler
ChrWright's Avatar
Trade: Builder/Remodeler
Rewards Points: 2,030
Why on earth would you not care about the manuf. warranty???
Do you care how long your installation lasts?
Do you care about who pays for the fix if there's a problem?
Is this for your own house or someone else's?
Christopher Wright, CR: President @ WrightWorks, LLC
www.WrightWorks.net - Facebook - Instagram - Carmel Remodeling
Indianapolis Kitchen Remodeling Contractor - Master of the Home Feature
ChrWright is offline
Old 12-20-2010, 11:27 PM   #9
Tile Contractor
Bud Cline's Avatar
Rewards Points: 518
I smell the fragrance of a DIY'er that thinks he is smarter than the rest of us and can learn some trade secrets by lying about his trade. I think you guys are being hoodwinked.
TO OUR VALUED CUSTOMERS:
Please manage your children.
Any children unattended throughout the day
will be given a Free Mountain Due at our regular quiting time.
Bud Cline is offline
Old 12-20-2010, 11:35 PM   #10
Anderson's Avatar
Trade: Home improvement contractor
Rewards Points: 1,196
Come on Angus, You didn't recommend Ditra XL that will get him a 1/4
Anderson is offline
Old 12-20-2010, 11:37 PM   #11
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Actually, 5/16"
Angus
angus242 is offline
Old 12-20-2010, 11:44 PM   #12
Anderson's Avatar
I won't doubt you if you say so.
Anderson is offline
Old 12-21-2010, 12:56 AM   #13
Lenny Ambrosino
MasterBuilt's Avatar
Trade: General Building, Maintenance & Repair
Rewards Points: 75
I'm siting here trying to come up with something witty to type but you guys are too good!
Lenny Ambrosino
Master Built Construction
MasterBuilt is offline
The Following User Says Thank You to MasterBuilt For This Useful Post:
tazmanian (12-21-2010)
Old 12-21-2010, 07:43 AM   #14
Flooring Installer
Trade: flooring
Rewards Points: 86
Exact same post is on the DIY board.
Armstrong certified
Old 12-21-2010, 09:46 AM   #15
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractor's to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If your not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.diychatroom.com/register.php/
We apologize for any inconvenience that this may have caused. This thread has been closed.
Angus
angus242 is offline
Tags
backer board , tile backer board , underlayment
Cement Board ? Abaco83 Tiling 16 11-30-2010 09:14 AM
building a shower bench when using backer board on walls? wopachop Tiling 70 04-08-2010 08:19 PM
Shower- backer board and mud base JKRasku Tiling 30 01-31-2010 02:02 PM
Fiber cement board rainscreen Burch9901 Commercial Construction 3 01-11-2010 08:21 AM
cement board as shower pan pgc555 General Discussion 121 10-25-2009 04:33 PM
