Carpeting Concerns W/Radiant Floor Heat - Flooring - Contractor Talk
Old 03-15-2011, 08:56 PM   #1
BEI's Avatar
Trade: Siding, Windows, Doors, Decks, Carpentry
Rewards Points: 75
Any carpeting contractors here that can advise on the best carpet types and padding to use with radiant floor heat? Floors are currently plywood with the heat tubes (Pex) running between the floor joists. Thanks in advance!
BEI is offline
Old 03-15-2011, 09:56 PM   #2
Groutface
Groutface's Avatar
Trade: flooring installer
Rewards Points: 524
Re: Carpeting Concerns W/Radiant Floor Heat
No real concerns if u follow these steps......make sure unlike tile that the heating is on when u install.....secondly make sure the carpet is climatized at least a couple hours before seaming or stretching...third maake sure u power stretch over floor heat every time... as far as type of carpet or pad med. End or better is always best in any install....always push that in my jobs ...hope this helps
Groutface is offline
Old 03-17-2011, 08:40 AM   #3
BEI's Avatar
Rewards Points: 75
We heard that the padding must be a certain type so as to allow the heat to pass thru it... true? I was planning on sculptured or a berber. Will that work? Thanks!
BEI is offline
Old 03-17-2011, 09:32 AM   #4
Groutface
Groutface's Avatar
Rewards Points: 524
I'm pretty sure that most padding would be adequate check with the salesperson or manufacturers recomendations......berber or sculpture would be fine! Climatizing it over the heated floor is key because u want to stretch at a temp that is gonna be consistant
The Following User Says Thank You to Groutface For This Useful Post:
BEI (03-19-2011)
Old 03-18-2011, 11:38 PM   #5
bobertone's Avatar
Trade: c-15
Smile
Go online toCRI/carpet and rug institute it should tell you everything there
bobertone is offline
The Following User Says Thank You to bobertone For This Useful Post:
BEI (03-19-2011)
Old 03-19-2011, 11:34 PM   #6
Groutface
Groutface's Avatar
Rewards Points: 524
Nice!
Garage slab 20' X 20' edge concerns HHC Concrete & Paving 35 08-10-2018 10:51 AM
Below grade attached garage, concerns new home owner Construction 1 09-06-2010 08:14 AM
Need your concerns! DaVinciRemodel General Discussion 24 01-27-2010 11:45 AM
Have some safety concerns dan442 Health & Safety 29 12-28-2009 08:23 PM
Has safety concerns gone to far? jkfox624 General Discussion 5 10-06-2009 10:12 PM
