Carpet Seam Repair - Flooring - Contractor Talk
Carpet Seam Repair
Old 01-24-2020, 08:37 PM   #1
zmusashi's Avatar
Trade: carpentry, remodeling
Rewards Points: 59
Carpet Seam Repair
I ironed a seam to remove a section of carpet in order to do mold remediation and other work, when I rolled it back into place and used the iron to re-glue the seam on the existing seam tape, the seam was imperfect despite re-stretching with Robinson kicker.
Can I use any kind of adhesive to lay in a strand of the white carpet between the green strands to cover the seam, which now looks like double green, not green-white-green? I can dry fit the strand that came out to look pretty good, and I saw a squeeze-bottle product at Lowe's that will dry clear... Any advice appreciated! I am not a flooring pro. Clearly. Last pic being the dry fit using 5-1 tool.
Carpet Seam Repair-img_2221.jpg   Carpet Seam Repair-img_2222.jpg   Carpet Seam Repair-img_2223.jpg
zmusashi is offline
Old 01-24-2020, 08:52 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 1,936
Re: Carpet Seam Repair
just my .02 cents worth but i would hire a PRO floor guy before you end up replacing a room full of carpet.
griz is online now
The Following 2 Users Say Thank You to griz For This Useful Post:
Calidecks (01-24-2020), zmusashi (01-24-2020)
Old 01-24-2020, 11:06 PM   #3
GC/carpenter
Calidecks's Avatar
Rewards Points: 8,916
It would be money well spent. At least get an assessment before you chance ruining it to the point of no return.
Mike.
_______________
Calidecks is online now
Old 01-25-2020, 10:44 AM   #4
Mike-B's Avatar
Rewards Points: 1,236
The best repair would be to cut the seam apart. Remove existing tape. Re-cut the seam on at least one side. Then redo the seam.
If you have a power stretcher, you could set it up to push toward the seam to close it up. Take a couple bites along the seam length. Pound a couple nails in about 2' away from the seam before releasing tension off the stretcher and moving/taking another bite.
If you don't have a power stretcher it may require pulling carpet off the tack strip so you can close the gap at the seam. Once seam is complete, stretch it back into place.
OR
https://www.robertsconsolidated.com/...t-seam-sealer/
Probably your best bet for trying to glue in that little strand. It will look great if done correctly but chances of it lasting the life of the carpet is much lower than a proper repair.
Sent from my SM-G970U using Tapatalk
Mike-B is online now
The Following User Says Thank You to Mike-B For This Useful Post:
zmusashi (01-28-2020)
Old 01-25-2020, 12:36 PM   #5
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 1,885
How long (inches) is the repair? My carpet guys does this quite a bit w/Berber style. It's usually from the closet installers, when they drill for the bottom floor track. Terrifying to look over your shoulder and see a new "runway" that wasn't there before. That, and your drill bit looks like the stick you used to wind your kite string on.
Go to your wholesale flooring supplier--they carry an adhesive just for repairs like this. HD/Lowes products are inferior. Good luck.
rescraft is offline
The Following User Says Thank You to rescraft For This Useful Post:
Old 01-25-2020, 06:59 PM   #6
rrk's Avatar
Rewards Points: 4,858
I have only done that one but I have been a bystander as it was happening to others numerous times years ago. That line zips across the room lightning fast. They were always too lazy to peel up the carpet before drilling through the floor
rrk is online now
Old 02-20-2020, 02:35 AM   #7
Fatmike's Avatar
Rewards Points: 44
Probably got it fixed. The other thing to consider is the secondary backing usually gets damaged when removing old tape. That’ll need repaired also otherwise you have delamination and your seam will come apart. I would re cut seam both sides either detatch from wall or use a min/crab stretcher it will allow you to bring the seam together, if detach isn’t to difficult.
Fatmike is offline
