Bostich Stapler Not Sinking Staples - Flooring - Contractor Talk
Old 05-09-2015, 12:19 PM   #1
Rhode Island's Avatar
Trade: Genral Contractor
Rewards Points: 264
Hi guys. Hope someone can help or advise me. I had a very old no name floor stapler I had forever. The casting finally split in half and I had to toss the gun. One of the floor guys I use from time to time gave me a Bostich MIII. It's practically new, but I can seem to get the staples to sink far enough. I went from 2" to 1 1/2" staples and it didn't make a difference.
I tried regular Bruce hardwood at my house to get a feel for the gun. I had to set tons of staples to get the boards close and eliminate gaps. I wasn't using any of the spacers. i feel bad asking the guy that gave it to me because if it's broke I will feel like an idiot. I do enough floors to need it, but never had to trouble shoot staples not sinking.
Thanks for the help
Rhode Island is offline
Old 05-09-2015, 12:24 PM   #2
Creter's Avatar
Rewards Points: 1,966
Re: Bostich Stapler Not Sinking Staples
It doesn't appear to be hooked up to an air supply...
Creter is offline
Old 05-09-2015, 12:35 PM   #3
avenge's Avatar
It also doesn't work on counter tops.
avenge is online now
The Following User Says Thank You to avenge For This Useful Post:
Creter (05-09-2015)
Old 05-09-2015, 12:39 PM   #4
Rewards Points: 264
Haha...good thing I fixed the upside down picture. Something tells me they don't work that way either.
I usually run at 90lbs. At first I thought it was low, but once at 120lbs I figured something isn't right.
The Following User Says Thank You to Rhode Island For This Useful Post:
Creter (05-09-2015)
Old 05-09-2015, 12:46 PM   #5
Fire up the BBQ
griz's Avatar
Broken driver, bad O rings, dirty......
griz is online now
Old 05-09-2015, 01:13 PM   #6
Creter's Avatar
In all seriousness...is there a jam? Correct size staples? Decent manufacturer of staples? (obviously check without being attached to air supply)
Creter is offline
Old 05-09-2015, 01:28 PM   #7
Rewards Points: 264
He told he bought the gun as a back up. Used it maybe 2-3 times. I am using the correct Bostich staples with it. I didn't get a manual and can't find one online. There is no obvious adjustment on it. It drives them, just need another 1/8" more out of it.
Old 05-09-2015, 01:31 PM   #8
Fire up the BBQ
griz's Avatar
Is the driver the correct length, or has it been cut down or broken off?
griz is online now
Old 05-09-2015, 06:19 PM   #9
ccoffer's Avatar
Rewards Points: 1,140
Are you oiling it? It sounds like a busted driver.
ccoffer is offline
Old 05-09-2015, 09:37 PM   #10
Rewards Points: 264
I am religous about oiling all my air tools. With that said, I don't think I ever oiled this since I had it. Might be a good first step.
Old 05-09-2015, 10:46 PM   #11
Railman's Avatar
Trade: Railing
Rewards Points: 639
Maybe the piston bumper swelled up? I'd try taking about 1/8" off & see how that works.
I once bought a new 16ga gun that acted erratic, & it ended up having Teflon tape blocking up some air passages.
I'd tear it down & look for something obvious, & then grind down bumper.
Railman is online now
staples, legal or not hootrod351 Roofing 14 08-23-2013 09:31 PM
Bostich Cordless Angled Finish Nailer ? MF Custom Tools & Equipment 19 09-14-2012 10:08 PM
Staples and Cleats not going into BAMBOO???! Vadim Flooring 15 12-12-2011 10:12 PM
Staples for Paslode Gun Spencer Tools & Equipment 3 03-28-2011 01:38 PM
Need help bostich stapler sirfranky Flooring 5 10-29-2009 03:30 AM
