Base Trim On FRP Walls - Flooring - Contractor Talk
Old 07-12-2015, 10:28 AM   #1
improving homes
platinumLLC's Avatar
Trade: Roofing/Remodeling
Rewards Points: 346
Have a small utility closet to do the floor in and the walls already have FRP panels on them all the way down to the floor. Would like to use tile for the base trim but worried about it sticking to the bumpy but slick FRP panels. Will thin set or construction adhesive work to stick tile to the FRP panels? Or something else?
platinumLLC is offline
Old 07-12-2015, 10:43 AM   #2
Texas Wax's Avatar
Rewards Points: 1,662
Re: Base Trim On FRP Walls
Power grab (quick 'hold') and silicone.
Texas Wax is offline
Old 07-12-2015, 11:39 AM   #3
MIKE ANTONETTI's Avatar
Trade: FLOORING CONTRACTOR
Rewards Points: 3,514
I called Mapei on this a couple years ago, they didn't have anything. Closest they could recommend was kerabond/Keralastic.
In butcher shop, deli, bakery of Publix we epoxied everything, it held the quarry base very well to FRP, kinda destroyed it for replacement pieces.
What we did on last commercial kitchen was cut the FRP 1/2" below height of base and bonded directly to drywall, yeah shoulda been cement board at a minimum.
MIKE ANTONETTI is offline
Old 07-12-2015, 07:00 PM   #4
improving homes
Rewards Points: 346
I thought about cutting out the frp but if its applied right it's almost sure to destroys the drywall when you pull it off.
Maybe I'll go pick up a sheet of frp and some different construction adhesive and epoxy and do a few test samples to see what will bond the best.
Old 07-12-2015, 07:08 PM   #5
RiverBG's Avatar
Trade: Home rehab specialist
Rewards Points: 764
What about pamtite? Never done it but that stuff sticks to everything.
RiverBG is offline
Old 07-12-2015, 08:43 PM   #6
If my PO asks,I set tile
Evan1968's Avatar
Trade: Commercial Tile Installs
Rewards Points: 1,160
When the FRP goes right to the floor we use Power Grab or Liquid Nails. Both work fine. If you want to go the thinset route Laticrete Platinum sticks to everything. Not ideal to stick tile to FRP but sometimes ya gotta do what ya gotta do.
Craig
Tile Installations Unlimited
"If you can't wow them with knowledge,baffle them with bullcrap."
Evan1968 is offline
Old 07-12-2015, 08:49 PM   #7
It's really not much traffic, the floor is holding the weight(one tile high) adhesive is preventing it from flopping over. The company I worked for bought epoxy by the tons per year.
The FRP adhesive may work, if it's designed to stick one side to (not sure about what the container says it sticks to) or sure what the back is made of. I would call manufacturer of Fiberglass Reinforced Plastic and ask them instead of spending one cent and time on a mock up.
The Following User Says Thank You to MIKE ANTONETTI For This Useful Post:
RiverBG (07-12-2015)
Old 07-12-2015, 08:54 PM   #8
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 704
Why not rubber base?
overanalyze is offline
Old 07-12-2015, 11:05 PM   #9
improving homes
Rewards Points: 346
That is another option I have been thinking about. Been thinking about picking up a pamtite gun.
I think I have a pail of that FRP adhesive at the shop I will see what it says on the back of what it sticks to. If I remember right it says something about one porous surface.
Rubber base isn't out of the questions. But does the rubber base adhesive stick to FRP?
Old 07-14-2015, 08:06 PM   #10
BKM Resilient's Avatar
Trade: Flooring
Rewards Points: 836
FRP glue is just CONSTRUCTION ADHESIVE. Yes, handled with proper understanding of the materials it will work.
Yes, rubber base will certainly adhere to FRP but so will ceramic tile with MANY choices of adhesive. I'm no expert on ceramic but off the top of my head I could think of at least a half dozen QUICK, CHEAP and EASY solutions for adhering ceramic tile base to FRP with no chance of complications.........in a small utility closet.
Epoxy
silicone
contact cement
multi-purpose glue
pressure sensitive glue
So it's really all about the BOND and the allowance between a non-porous surface and a semi-porous back/tile
Hell, if you play around enough thin set would work. It would be a matter of some ADDITIVE......giving it some breathing time and then maybe using something to hold the base in place whilst that bonding agent has a chance to set.
BKM Resilient is offline
The Following 3 Users Say Thank You to BKM Resilient For This Useful Post:
platinumLLC (07-15-2015), PrecisionFloors (07-15-2015), Rio (07-15-2015)
Old 07-15-2015, 07:49 AM   #11
Paul
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Rewards Points: 1,004
^^ what he said lol. You guys crack me up sometimes. The amount of time spent thinking about some of this stuff far exceeds the amount of time just Nikeing that **** out lol. I know - that word doesn't exist... But it does on my jobs. It's what I tell the help when they come to me with a thousand questions about something simple. "Just Nike that **** out and lets go home before midnight.."
Precision Floors
(772) 237-9900
PrecisionFloors is offline
Old 07-15-2015, 09:12 AM   #12
Perhaps then there shouldn't be a book 450 pages on how to set a tile, none of which say setting on top of FRP, next year the book will be 451.
Old 07-15-2015, 09:53 AM   #13
improving homes
Rewards Points: 346
I don't like to "Nike" stuff when I'm not 100% sure it is the correct way to do it. I don't like call backs and was just asking others to see if they had advice based on their experience. Just trying to avoid just slapping("Nikeing") it out and have it not hold up and get called back to fix it. Plus I haven't even started this job yet so it doesn't hurt anything to ask before hand, not holding me up one bit.
Thanks for all the suggestions.
Old 07-15-2015, 10:10 AM   #14
Nike'ing, I like it, nike'n(slapping)my bitch, just Kidn, Trump and Nike lawyers, I will cease and desist.
Old 07-15-2015, 02:14 PM   #15
Designer/Contractor
Rio's Avatar
Rewards Points: 1,922
Had a project where we needed to bond hard neoprene to wood and where we got the neoprene the salesman said this stuff is waterproof and very sticky, will stick to anything (sounds like a potential tar baby situation)
http://cimindustries.com/products/cim-product/cim-1000/
Rio is offline
Old 07-15-2015, 03:50 PM   #16
Paul
Kerdi Fix and NobleSealant 150 will also work very well. Look I'm not saying their isn't a time and place to get technically specific and uber anal about the what's how's and why's of something but ffs we're talking about a few feet of tile base in a utility room. It needs to not fall down. Damn. Caulking would probably work. If I felt the the need look at the tcna manual for that small of a problem to solve, it's time to hang up the trowel.
Precision Floors
(772) 237-9900
The Following User Says Thank You to PrecisionFloors For This Useful Post:
overanalyze (07-15-2015)
Old 07-15-2015, 06:07 PM   #17
Quarry base or any for that matter takes a beating, wheeled carts bash into them on a continual basis. Whatever holds it should be solid behind, my perspective as well is to do it once and never be back. We continually replaced base, usually we busted a pallet apart, dug out whatever fell apart behind it, screwed the board to studs and retiled it.
I think Platinum is asking some good questions, ones that make money. In this trade, leaps and bounds are what's needed to stay afloat.
I think we are all missing the science behind all the products we use, maybe there is a science forum for us common folk.
Old 07-15-2015, 06:26 PM   #18
Paul
Sorry. From his first post I didn't realize he was tiling the laundry facility at Cowboys stadium. My bad. I thought he asked what would stick tile base to frp in small utility closet. Not a stupid question by any means. My point was sometimes you guys turn a 20 min job into 4 days of research, $400 in supplies, an in-depth review of the msds and product data sheets, and a call to tech support... Stick the **** to the wall already lol. Now I'm starting to see how govt bureaucracies get so huge lmao.
For the most part I agree with you Mike. I'm just busting balls while being a little bit serious too
Precision Floors
(772) 237-9900
Old 07-15-2015, 06:54 PM   #19
My concerns are information not transferred, or the experience we have.
I say epoxy, but that's just A&B, we used Aerosil to fluff it up, make it stand up, & stick.
The purpose of FRP, is so stuff doesn't stick to it, I'm not sure if front is same as back, I don't think it is. So to bond to glossy surface sometimes scuffing up is the answer, sometimes a chemical overcomes the need to do that, I don't always have success with that method, many things have come apart.
My question is what's the surface of FRP, what will bond to it, easily, with keeping cost down. I haven't researched the manufacturers (FRP) recommendations.
So -"construction adhesive" I guess that falls under any type of building that requires adhesive would be considered "construction adhesive".
Last I checked(years ago) the FRP adhesive by volume was nowhere near the same price as "liquid nail" or I'd be filling up tubes with FRP adhesive. The formulas are different, it may be same base chemicals but different recipe.
Paul, I think I could work behind any of your jobs and not even think anything out of the norm, some jobs, I ask myself wtf was this guy thinking.
Disclosure- I did call Mapei last week, we were running out of Congoleum SU-100 adhesive and if Mapei had a substitute, they did not. I said I had Eco 360 and that's held down every solid vinyl I've tried it on, well it didn't work too well on the edges.
Old 07-15-2015, 07:11 PM   #20
Trade: Flooring
Rewards Points: 836
Coincidentally I was recently working on the laundry facility at Unversal Studios/NBC Los Angleles. Holy CRAP what a huge joint and clusterF of workers every day/night. We put 2MM Nora with waterjet cut stuff to direct the crowds and borders and such----all heat welded. Very sweet stuff.
Trim prep nakarsten Painting & Finish Work 20 08-11-2012 07:40 PM
Tiling suggestion needed for block walls user61815 Kitchens & Baths 1 05-17-2010 10:35 PM
Installed base for door trim - am I insane? wallmaxx Finish Carpentry 13 10-07-2009 06:20 PM
paint trim then walls MattCoops Painting & Finish Work 16 03-30-2008 04:53 PM
Proposals...... AAPaint Painting & Finish Work 3 08-25-2007 08:47 AM
